- Choose Enterprise, OBS.
- Click the OBS Name column label to display the OBS hierarchy.
- Select the OBS element you want to delete, then click Del/Merge.
If the OBS element you want to delete has work breakdown structure (WBS), issue or threshold assignments, you are prompted to merge the element with its parent OBS. - Click Yes.
Note
- If you delete a parent OBS element, all of the elements contained in the parent element are deleted.
