- Select the work product or document.
- Display WP & Doc Details, then click the Files tab.
- Click Launch next to the appropriate Location field.
Note
- Only P6 Professional users can open private location documents. Public location documents can be viewed by all project participants.
- If the selected work product or document has been added via a P6 installation with a configured content repository, the detail fields are read-only and the document cannot be opened from P6 Professional.
Display work product and document details in the WPs and Docs window
