- Select the WBS element.
- Display WBS details, then click the WPs & Docs tab.
- Select one or more work products or documents.
To display the WPs & Docs tab, right-click in the Details area and choose Customize WBS Details. In the Available Tabs section, select WPs & Docs, click , then click OK. - Click Remove, then click Yes.
Tip
- To view detailed information about or open the document before you remove it, select the document, then click Details.
