You can use Global change to search for blank fields.
- Choose Tools, Global Change.
- Click New, or select an existing specification and click Modify.
- In the If section, specify a data item in the Parameter field.
- Specify a criteria in the Is field.
- Type " " (two quotation marks separated by a space) in the Value field.
