The Maximum Session Timeout setting is the maximum length of time that a user can connect to the application server (regardless of activity) before P6 EPPM times it out.
To set your session timeout:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Session Management.
- In Maximum Session Timeout, enter the amount of time a user session can remain open before it times out.
The default value is 1d.
Enter a value between 1m and 24d.
Note: Changes to this setting require you to restart the P6 server.
