To configure P6 Integration API and P6 to work together, you will need to set the P6 Integration API settings in the Primavera P6 Administrator.
Note: For more information on the Primavera P6 Administrator see Primavera P6 Administrator Setup Tasks.
To set your Integration API server settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Integration API Server.
- In the Session Timeout field, enter the number of minutes when an idle connection will end.
The default value is 120.
Enter a value between 1 and 24d.
- In the Security Authenticate Mode field, select one of the following modes:
Username Token Profile
SAML Token Profile
The default value is Username Token Profile.
- To configure RMI settings:
- Select Enable to enable the RMI server. You need to enable the RMI server only if you are using P6 Integration API.
- P6 Integration API supports three modes. Depending on the mode you are using, do one of the following:
- Select Enable Compression to enable compression service mode.
- Select Enable SSL to enable SSL service mode.
- Select Enable Standard Service to enable Standard service mode.
- In the Registry Port field, enter the port for the RMI Registry. The default value is 9099.
- Depending on which mode you enable, set the corresponding port for that mode:
- In the Compression Service Port field, enter the port to use for Compression service mode. A setting of 0 indicates that any available port will be used. If the server will be accessed across a firewall, you must set this to a specific port.
The default value is 0.
- In the SSL Service Port field, enter the port to use for SSL service mode. A setting of 0 indicates that any available port will be used. If the server will be accessed across a firewall, you must set this to a specific port.
- In the Standard Service Port field, enter the port to use for Standard service mode. A setting of 0 indicates that any available port will be used. If the server will be accessed across a firewall, you must set this to a specific port.
- In the File Location field, enter the full path to the Keystore file.
- In the Keystore Password field enter the Keystore password.
