Modify publication settings to specify constraints on your report publishing jobs.
To configure your publication settings:
Note: The default settings should be the optimal settings for most environments. Change them only if your environment requires different settings.
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Services/Publication/Settings.
- To configure General Data:
- In the Page Size field, enter the maximum number of rows of general data a job can process. This applies to each business object that falls under the general category; general data is not time-distributed (spread), not hierarchical, and not in a blob. When using this setting, each business object processes separately.
The default value is 32.
Enter a value between 1 and 8192.
- In the Max Job Count field, enter the number of processes used for this service on your server.
The default value is 1.
Enter a value between 1 and 20.
- To configure TimeDistributed:
- In the Page Size field, enter the maximum number of rows of time-distributed (spread) data that a job can process. This applies to each business object that falls under the time-distributed category. When using this setting, each business object processes separately.
The default value is 16.
- To configure Blob Data:
- In the Page Size field, enter the maximum number of rows of blob data that a job can process. This applies to each business object that falls under the blob category. When using this setting, each business object processes separately.
The default value is 25.
- To configure Log:
- In the Security Level drop-down menu, select the level of information contained in the log file for all publication services. The ranges are inclusive. For example, select debug to log all messages; select info to log details about what runs, exceptions, and warnings; select warning to log both warning and error level messages.
The default value is info.
Select info, debug, warning, or error.
- In the Global Service Log File Cap (Success) field, enter the number of logs to retain for successful global publication services. This will retain a log for each global service. If set to 5, the last 5 successful service runs will be retained for each global service.
The default value is 5.
Enter a value between 1 and 25.
- In the Global Service Log File Cap (Fail) field, enter the number of logs to retain for failed global publication services. This will retain a log for each global service. If set to 5, the last 5 failed service runs will be retained for each global service.
- In the Project Service Log File Cap (Success) field, enter the number of logs to retain for successful Publish Project jobs. This will retain a log for each project service. If set to 5, the last 5 successful service runs will be retained.
- In the Project Service Log File Cap (Fail) field, enter the number of logs to retain for failed Publish Project jobs. This will retain a log for each project service. If set to 5, the last 5 failed service runs will be retained, per project.
