Configuring Publication Services in Services Settings
If you are running services and P6 on the same server, you should keep the defaults. If you have scheduling work that needs to be done immediately, you should set the Interval low (for example, 10s) and the Concurrent Threads high. Remember that if the server is actively applying the service, all users will experience delays in the application.
To configure your publication settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Services/Publication/Services.
  4. You can use Project Arbiter to automate submitting Publish Project services for eligible projects to the service queue. To configure Project Arbiter:
    1. Select Active Mode if you want jobs processed continuously until all jobs finish. Leave this field clear if you want each job processed according to the Interval.
    2. In the Interval field, enter the amount of time the service will wait before running the next available job.
      The default value is 10s.
      Enter a value between 1s and 24d20h31m23s647.
    3. In the Concurrent Threads field, enter the number of processes used for this service on this server. A value of 0 indicates that this service will not run on this server.
      The default value is 1.
      Enter either 0 or 1.
  5. To configure Publish Project:
    1. Select Active Mode field if you want jobs processed continuously until all jobs finish. Leave this field clear if you want each job processed according to the Interval.
    3. In the Concurrent Threads field, enter the number of processes used for this service on this server. A value of 0 indicates that this service will not be run on this server.
      The default value is 2.
      Enter a value between 0 and 20.
  6. To configure Publish Enterprise Data:
    Note: Publish Enterprise Data, Enterprise Summaries, Resource Management, and Security will recalculate data and store it in physical fields in the Extended Schema tables, and will perform other data denormalization tasks. For example, duration fields are calculated fields in the existing P6 schema tables, but will be recalculated and stored as physical fields in the extended schema tables when a project is published.
  7. To configure Publish Enterprise Summaries:
  8. To configure Publish Resource Management:
  9. To configure Publish Security:
  10. To configure Publish Resource Role Assignment:
Related Topics
About the Primavera P6 Administrator Services Settings
Configuration for ASAP and Scheduled Services
Configuring Services Settings
Configuring Publication Settings in Services Settings
Configuring Delete Published Data in Services Settings
Configuring Infrastructure Services in Services Settings
Configuring Job Services in Services Settings
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
