To set your WCCC settings:
Note: Ensure the settings you entered in when you configured the content repository match the settings you enter below.
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Database.
- Select your Instance from the drop-down list.
- Expand Content Repository.
- In the Type field, select OracleWCCC.
- In the Maximum document size field, enter the maximum size in KB for documents that can be uploaded to P6. The default is 10240 KB. Enter a value between 0 and 1048576.
- In the Connection Maintenance Interval field enter the frequency at which the connection to the content repository is validated. The default is 10 minutes. Enter a value between 1 second and 24 days.
- In the Host field, enter the machine name or IP address of the content repository server.
- In the Port field, enter the IntradocServerPort number of the content repository server. By default, this is 4444.
- Go to WCCC_Home
\ucm\cs\config\. - Edit the config.cfg file.
- Find the IntradocServerPort line, which contains the port number.
- Go to WCCC_Home
- In the Oracle Home field, enter the location of the framework folder.
For the framework folder, use the following format:
/<FolderName>
For example:
/P6EPPM
- In the Oracle Security Group field, enter the name of the Security Group assigned to the document folder created in WebCenter for P6 EPPM documents, as specified when you configured the content repository.
For Example:
Enter Oracle Security Group as Public.
- In the Oracle Security Account field, enter the name of the Security Account for P6 EPPM documents, as specified when you configured the content repository.
If you did not enable security accounts, leave this setting blank.
- In the Oracle Document Type field, enter the document type for P6 EPPM documents, which can be either an existing document type or a new one, as specified when you configured the content repository.
For example:
Enter the Document Type as Document.
- In the Metadata Prefix field, enter the prefix added to P6 EPPM metadata fields, as specified when you configured the content repository. For example, Prm.
- In the Admin User field, enter the user name with administrative privileges, as specified when you configured the content repository. This setting is required.
- From the Authentication Mode drop-down menu, select the authentication mode used to access the content repository server. P6 EPPM users cannot access content repository functions if you do not configure this setting.
If you choose "Multiple User", all P6 EPPM content repository-related user names must match the equivalent content repository user name. For example, a P6 EPPM user named "Joe" must have an equivalent user named "Joe" in the content repository.
If you choose "Single User", the administrative user specified in the setting above must have access to all appropriate SharePoint libraries to browse to documents outside of the P6 EPPM home folder.
- Restart the P6 Server.
