You can use Oracle database as a content repository with your P6 EPPM installation.
To configure the Oracle database as your content repository:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Database/Instance[n]/Content Repository.
Note: Changes to these settings require you to restart the P6 server.
- In the Type field, select Oracle Database.
This option will save documents and associated information in the P6 database schema. This option is only applicable if you are using an Oracle database on-premises.
- In the Maximum document size field, enter the maximum size in KB for documents that can be uploaded to P6. The default is 10240 KB. Enter a value between 0 and 1048576.
- In the Invalid Document Types field, enter the file extensions of documents that are not permitted in P6. A list of file extensions can be separated with either commas or spaces.
For example:
exe,bin,sh
.exe .bin .sh
- In the Connection Maintenance Interval field enter the frequency at which the connection to the content repository is validated. The default is 10 minutes. Enter a value between 1 second and 24 days.
Note: Ensure that the Enable Cloud Storage field is set to false.
- Restart the P6 server.
