You can now deploy the newly merged Repository Definition (.rpd) file in Oracle Business Intelligence (OBI). To deploy the newly merged Repository Definition (.rpd) file, complete the following steps:
- Open a terminal or command prompt window and go to your BI Domain tools folder. For example:
C:\Oracle\Middleware\Oracle_Home\user_projects\domains\bi\bitools\bin
- Use the data-model-cmd.cmd command (with Windows) or the data-model-cmd.sh command (with UNIX or Linux) in the terminal or command prompt to upload the newly merged Repository Definition file using your WebLogic administrator credentials (the -U and –P parameters). For example:
data-model-cmd.cmd uploadrpd –I C:\Temp\OraclePrimaveraAnalytics162.rpd –W Admin123 –U weblogic –P weblogic1 –SI ssi
You should receive a message indicating that the RPD Upload completed successfully.
- Log in to the OBI Enterprise Manager URL with an account that is a member of the WebLogic Administrator group (for example, weblogic):
http://<server>:<port>/em
where <server> is the server name or IP address of the server where OBI is installed and running, <port> is the listening port number for OBI, and /em is the default context for OBI Enterprise Manager.
- Click the Target Navigation Tree icon at the upper left corner of the scree to expand it.
- Click the arrow icon next to the Business Intelligence leaf node to expand the folder.
- Click the biinstance hyperlink, which appears below the leaf node, to display the properties and available configuration options for this deployment of OBI on the right side of the screen.
- Click the Availability parent tab
- Click the Processes child tab.
- Click the Restart All link to restart all components of this OBI deployment.
- When the confirmation window appears, click Yes.
When the OBI deployment restarts, a confirmation message appears.
- Click Close.
- Click the user menu (for example, weblogic) located at the upper right of the screen directly below the browser toolbar, and select Log Out.
