31User Properties Reference for Siebel Hospitality
This chapter documents the specific user properties for the Siebel Hospitality application. The following topics are included in this chapter:
About User Properties for Siebel Hospitality
User properties are object definitions that are added as children to an applet, business component, control, field, or list column to configure specialized behavior beyond what is configured in the properties of the parent object definition.
Some Siebel Hospitality functionalities are driven by user properties. You can customize these functionalities through their respective user properties. With user properties, you can control UI behavior, change default settings or leave them as they are, and enable or disable functionalities.
This topic lists user properties that are specific to Siebel Hospitality. For more information about user properties, and user properties that apply to all Siebel Business Applications, see the chapter on user properties in Siebel Developer's Reference.
This topic describes the user properties supported for all functionalities of Siebel Hospitality. This topic describes the following business service user properties:
Open Day Async
Use this user property to open event checks asynchronously.
Value |
Y |
Parent Object Type |
SHM Invoice Process business service |
Usage |
All the event checks for the same function date and the same property are opened asynchronously. |
Parallel Quote Generation
Use this user property to create quotes in parallel.
Value |
Y |
TNT SHM Quote Service business service |
Usage |
If this user property is active, all quotes are generated simultaneously. |
User Properties for Arrival Date Modifications
This topic describes the user properties supported for the arrival date modifications functionality in Siebel Hospitality. This topic covers the following subjects:
Applet User Properties for Arrival Date Modifications
This topic describes the following applet user property:
Named Method: ShowDatePopup
This user property allows you to call an applet method, on the call of the ShowDatePopup method on the applet.
Value |
INVOKE, ShowPopup, TNT SHM Arrival Date Popup Applet, Edit |
Opportunity List Applet, Quote List Applet, TNT SHM Affiliate Opportunity List Applet, and TNT SHM Cluster Quote List Applet applets |
Usage |
This user property allows you to call the ShowPopup applet method, with the pop-up applet name and applet mode as arguments, to launch the pop-up applet on the call of the ShowDatePopup method. This method is called when a user clicks the Modify Arrival Date applet method menu item. |
Business Component User Properties for Arrival Date Modifications
This topic describes the following business component user properties:
Arrival Date BC Name
The value of this user property contains the name of the field that holds the business component name to be used for booking during a change to the arrival date. This user property is used in C++ code.
Value |
TNT SHM Function |
TNT SHM Function business component |
Usage |
The value of this user property contains the name of the field that holds the business component name to be used for booking during a change to the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
Value |
TNT SHM Quote Room Block Line Items |
TNT SHM Quote Room Block Line Items business component |
Usage |
This user property value contains the name of the pop-up applet that is used for function instructions. This user property is used in C++ code.
Value |
TNT SHM Arrival Date Popup Applet |
Opportunity, TNT SHM Affiliate Opportunity, TNT SHM Sub Opportunity, and Quote business components |
Usage |
The value of this user property contains the name of the pop-up applet that is used for function instructions. This user property is used in C++ code for arrival date modifications functionality. |
Arrival Date SearchSpec
The value of this user property contains the searchspec string to be applied to the TNT SHM Function business component to filter the functions that are frozen during a change to the arrival date. This user property is used in C++ code.
Value |
[Freeze Flag] <> 'Y' |
Usage |
The value of this user property contains the searchspec string to be applied to the TNT SHM Function business component to filter the functions that are frozen during a change to the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
Day Number: Room Block Refresh BC Name
This user property passes the room block-related business component names to be refreshed during a change to the arrival date. This user property is used in C++ code.
Value |
TNT SHM Room Block;TNT SHM Oppty Rapid Room Block Capture Line Items |
Opportunity business component |
Usage |
This user property passes the room block-related business component names to be refreshed during a change to the arrival date. The value TNT SHM Oppty Rapid Room Block Capture Line Items is appended to the existing value. This user property is used in C++ code for arrival date modifications functionality. |
Field Name: Arrival Date
This user property value contains the name of the field that is used for the arrival date. This user property is used in C++ code.
Value |
Hospitality Start Date |
Opportunity, TNT SHM Affiliate Opportunity, and TNT SHM Sub Opportunity business components |
Usage |
The value of this user property contains the name of the field that is used for the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
Value |
Arrival Date |
Quote business component |
Usage |
Field Name: ChildFuncBCToRefresh
The value of this user property contains the name of the field that holds the function agenda-related business component name to be refreshed during a change to the arrival date. This user property is used in C++ code.
Value |
ChildFuncBCToRefresh |
TNT SHM Affiliate Opportunity and TNT SHM Sub Opportunity business components |
Usage |
The value of this user property contains the name of the field that holds the function agenda-related business component name to be refreshed during a change to the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
Field Name: ChildRoomBcToRefresh
The value of this user property contains the name of the field that holds the room block line items-related business component name to be refreshed during a change to the arrival date. This user property is used in C++ code.
Value |
ChildRoomBcToRefresh |
Usage |
The value of this user property contains the name of the field that holds the room block line items-related business component name to be refreshed during a change to the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
Field Name: Function Instructions
This user property value contains the name of the field that is used for function instructions. This user property is used in C++ code.
Value |
Function Instructions |
Opportunity, TNT SHM Affiliate Opportunity, TNT SHM Sub Opportunity, Quote, and TNT SHM Arrival Date VBC business components |
Usage |
The value of this user property contains the name of the field that is used for function instructions. This user property is used in C++ code for arrival date modifications functionality. |
Field Name: RoomBlock Instructions
This user property value contains the name of the field that is used for room block instructions. This user property is used in C++ code.
Value |
RoomBlock Instructions |
Usage |
The value of this user property contains the name of the field that is used for room block instructions. This user property is used in C++ code for arrival date modifications functionality. |
Shift Functions
This user property is used to send instructions to the code as to whether or not to shift functions during the in-line modification of an arrival date. The default value is Y.
Value |
Y or N |
Usage |
This user property is used to send instructions to the code as to whether or not to shift functions during the in-line modification of an arrival date. This user property is used in C++ code. The default value is Y. |
Shift RoomBlocks
This user property is used to send instructions to the code as to whether or not to shift room blocks during the in-line modification of an arrival date. The default value is Y.
Value |
Y or N |
Usage |
This user property is used to send instructions to the code as to whether or not to shift room blocks during the in-line modification of an arrival date. This user property is used in C++ code. The default value is Y. |
Shift SubOpportunities
This user property is used to send instructions to the code as to whether or not to shift subopportunities during the in-line modification of an arrival date. The default value is Y.
Value |
Y or N |
Usage |
This user property is used to send instructions to the code as to whether or not to shift subopportunities during the in-line modification of an arrival date. This user property is used in C++ code. The default value is Y. |
Sub Opportunity SearchSpec
The value of this user property contains the searchspec string to be applied to the Opportunity business component to retrieve the subopportunities during a change to the arrival date. This user property is used in C++ code.
Value |
[Relationship Type LIC] = 'Sub-Recurrence' |
Usage |
The value of this user property contains the searchspec string to be applied to the Opportunity business component to retrieve the subopportunities during a change to the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
User Properties for Function Space Diary
This topic describes the user properties supported for the Function Space Diary functionality of Siebel Hospitality. This topic covers the following subjects:
Applet User Properties for Function Space Diary
This topic describes the following applet user properties:
Abbreviation Fields | ABBR 0
Use this user property to get the abbreviated field values according to the field value selected in the Display drop-down list in the Function Space Diary.
Value |
Function Type Abbr;Business Type Abbr |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet applets |
Usage |
Gets the combination of abbreviations of the actual fields from the TNT SHM Function Booking VBC business component. The name of the user property must end with ABBR x (where x indicates 0,1,2...), which matches the language independent code (LIC) of the selection in the Display drop-down list in the Function Space Diary. |
Abbreviation Fields | ABBR 1
Value |
Setup Style Abbr;Expected Num Abbr |
Usage |
The usage is the same as the Abbreviation Fields | ABBR 0 user property. |
Abbreviation Fields | ABBR 2
Value |
Event Manager Abbr;Sales Manager Abbr |
Usage |
Abbreviation Fields | ABBR 3
Value |
Quote Name Abbr;Function Name Abbr |
Usage |
Abbreviation Fields | ABBR 4
Value |
Function Status Abbr;Meal Period Abbr |
Usage |
Actual and Abbreviation Field 1
Use this user property to define the actual field and the corresponding abbreviation in the Function Space Diary.
Value |
Function Type;Function Type Abbr |
Usage |
The TNT SHM Function Booking VBC business component has been configured in the Item Business Component applet user property for all the parent object types (mentioned in the previous row). The first part of the user property value represents the actual field value of the TNT SHM Function Booking VBC business component. The second part of the user property value represents the abbreviation of the corresponding actual field. If the value is available, then the corresponding abbreviation is displayed in the label and tooltip in the Function Space Diary in place of the actual field value. |
Actual and Abbreviation Field 2
Use this user property to define the actual field and corresponding abbreviation in the Function Space Diary.
Value |
Business Type;Business Type Abbr |
Usage |
The usage is the same as the Actual and Abbreviation Field 1 user property. |
Actual and Abbreviation Field 3
Value |
Setup Style;Setup Style Abbr |
Usage |
Actual and Abbreviation Field 4
Value |
Expected Num;Expected Num Abbr |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary and TNT SHM Function Space Diary Total Availability Applet Applets |
Usage |
Actual and Abbreviation Field 5
Value |
Event Manager;Event Manager Abbr |
Usage |
Actual and Abbreviation Field 6
Value |
Sales Manager;Sales Manager Abbr |
Usage |
Actual and Abbreviation Field 7
Value |
Quote Name;Quote Name Abbr |
Usage |
Actual and Abbreviation Field 8
Value |
Function Name;Function Name Abbr |
Usage |
Actual and Abbreviation Field 9
Value |
Function Status;Function Status Abbr |
Usage |
Actual and Abbreviation Field 10
Value |
Meal Period;Meal Period Abbr |
Usage |
CanModifyLayout
Use this user property to allow users to modify the applet UI layout through the Columns Displayed option.
Value |
N |
TNT SHM Property Projected / Blocked List Applet applet |
Usage |
Controls the Columns Displayed option in the Siebel Business Applications standard applet menu. To enable the Columns Displayed applet menu item, change the value to Y. |
Color Code Major Axis 1
Use this user property to specify the time scale for which the color coding and icons are displayed in the major axis of the Function Space Diary.
Value |
2 |
Usage |
Defines the time scale for which the color coding and icons are displayed in the major axis of the Function Space Diary. The value 2 represents the LIC value for the Day/Day-Part time scale. |
Color Code Major Axis 2
Value |
4 |
Usage |
Defines the time scale for which the color coding and icons are displayed in the major axis of the Function Space Diary. The value 4 represents the LIC value for the Day/Hour time scale. |
Color Code Major Axis 3
Value |
8 |
Usage |
Defines the time scale for which the color coding and icons are displayed in the major axis of the Function Space Diary. The value 8 represents the LIC value for the Day/Half-Hour time scale. |
Color Code Major Axis 4
Value |
16 |
Usage |
Defines the time scale for which the color coding and icons are displayed in the major axis of the Function Space Diary. The value 16 represents the LIC value for the Day/Quarter-Hour time scale. |
Color Code Major Axis 5
Value |
128 |
Usage |
Defines the time scale for which the color coding and icons are displayed in the major axis of the Function Space Diary. The value 128 represents the LIC value for the Week/Day/Day-Part time scale. |
Color Code Major Axis 6
Value |
256 |
Usage |
Defines the time scale for which the color coding and icons are displayed in the major axis of the Function Space Diary. The value 256 represents the LIC value for the Month/Day-of-week/Day Part time scale. |
Color Code Minor Axis 1
Use this user property to specify the time scale for which the color coding and icons are displayed in the minor axis of the Function Space Diary.
Value |
1 |
Usage |
Defines the time scale for which the color coding and icons are displayed in the minor axis of the Function Space Diary. The value 1 represents the LIC value for the Week/Day time scale. |
Color Code Minor Axis 2
Value |
32 |
Usage |
Defines the time scale for which the color coding and icons are displayed in the minor axis of the Function Space Diary. The value 32 represents the LIC value for the Month/Day-of-week time scale. |
Delimiter
Use this user property to specify the delimiter when a combination is selected in the Display LOV of the Function Space Diary.
Value |
Usage |
Specifies the delimiter when a combination is selected in the Display LOV in the Function Space Diary. |
Example |
Board Meeting/Conference, if Function Name/Function Type is selected in the Display LOV of the Function Space Diary. |
Enable Color Icon
Use this user property to enable or disable color coding in the Function Space Diary.
Value |
Y |
Usage |
Turns color coding on or off in the Function Space Diary. If the value is N, no color icons are displayed. |
Icon Display Fields 0
Use this user property to associate an icon with specific special events.
Value |
Holiday;301 |
Usage |
Associates an icon with specific special events. Icon identifier 301 is associated with Holiday and configured in the C++ code. |
Icon Display Fields 1
Value |
Special Day Event;302 |
Usage |
Associates an icon with specific special events. Icon identifier 302 is associated with Special Event and configured in the C++ code. |
Icon Display Fields 2
Value |
Sell Note;303 |
Usage |
Associates an icon with specific special events. Icon identifier 303 is associated with Sell Note and configured in the C++ code. |
Item Color Toggle Activate Fields
Use this user property to activate fields that are used in the function booking color scheme based on the Item Color Toggle Field user property value.
Value |
Function Status;Quote Status |
TNT SHM Function Space Diary Total Availability Applet, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary applets |
Usage |
This user property is used to activate all the fields that could be returned as the value of the Item Color Toggle Field user property. |
Item Color Toggle BC Name
Use this user property to define business components for toggle colors.
Value |
TNT SHM Gantt AX Admin Function Status Color |
Usage |
This user property is used in C++ code to return the toggle color codes configured in the Function Space Administration screen, Function Status Color Schema applet. Define similar user properties if any other toggle colors are available. For example, if you want to define toggle color codes for Quote Status, then define a similar user property such as Item Color Toggle BC Name 1 with a value of TNT SHM Gantt AX Admin Quote Status Color. |
The field name is defined in the TNT SHM Gantt AX Date Time Interval PopUp VBC business component. The value is the status field in the TNT SHM FSI Booking business component, based on the selected booking color scheme.
Value |
Booking Color Toggle Field |
Usage |
This user property is used to return the status for which a toggle color is defined. |
Example |
If the function color booking scheme is selected as Quote Status, then the Booking Color Toggle field returns a value of Quote Status. This value is the field name in the TNT SHM FSI Booking business component. If the field does not exist, then you must configure the field in the TNT SHM FSI Booking business component. The value of the status field is returned in C++ code to identify the associated color code, if it is defined in the Function Space Administration screen, Quote Status Color Schema applet. |
Item Time Display Toggle Time Label 9
Use this user property to display the Expected Number of Attendees field in the Booking Label when Expected Num is selected in the Display LOV of the Function Space Diary.
Value |
Expected Num |
Usage |
If the value is available, the value of the Expected Num field is displayed in the Booking Label when Expected Num is selected in the Display LOV of the Function Space Diary. The name of this user property must end with x (where x indicates 0,1,2...). |
Item Time Display Toggle Time Tooltip ABBR 0
Use this user property to get the abbreviated field values in the tooltip according to the field value selected in the Display LOV in the Function Space Diary.
Value |
Booking Set Up Tip;Booking Tip - Abbreviation;Booking Tear Down Tip;Booking Tear Down Tip |
Usage |
Gets the combination of abbreviations of the actual fields from the TNT SHM Function Booking VBC business component and displays the resulting value in the tooltip. The name of the user property must end with ABBR x (where x indicates 0,1,2...), which matches the LIC of the selection in the Display LOV in the Function Space Diary. |
Max X Pages
This user property is used to configure the number of horizontal pages for which Function Space Diary information is to be displayed.
Value |
2 |
TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary, TNT SHM Function Space Diary Total Availability Applet, TNT SHM Function Space Diary - Business Type, TNT SHM Function Space Diary - Function Type, TNT SHM Function Space Diary - Meal Period, TNT SHM Function Space Diary - Quote Name, TNT SHM Function Space Diary - Setup Style, TNT SHM Order Item Category Inventory Availability Gantt Chart Applet, TNT SHM Order Item Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Category Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Inventory Availability Gantt Chart Applet |
Usage |
This user property is used to configure the number of horizontal pages for which Function Space Diary information is to be displayed. |
Max Y Rows Per Page
This user property is used to configure the number of visible function spaces for which Function Space Diary information is to be displayed.
Value |
15 |
Usage |
This user property is used to configure the number of visible function spaces for which Function Space Diary information is to be displayed. |
Month Day View
Use this user property to specify the time scale in which to display information for the whole month in the Function Space Diary.
Value |
64 |
Usage |
Defines the time scale in which to display information for the whole month in the Function Space Diary. The value 64 represents the LIC value for the Month/Day time scale. |
OnDoubleClick Invoke BC
Use this user property to configure the business component to retrieve the double-click event details when a user double-clicks the Function Space Diary grid. When the double-click event occurs, Siebel Hospitality sends data, such as time, property, and function space, to a business service method, which is configured through the OnDoubleClick Invoke Service and OnDoubleClick Invoke Service Method user properties.
Value |
TNT SHM Gantt AX Date Time Interval PopUp VBC |
Usage |
Specifies the business component to get parameters, such as time and function space, from the business component when double-clicked in the Function Space Diary. |
Use this user property to configure the business component to retrieve the double-click event details when a user double-clicks the Function Space Diary grid. When the double-click event occurs, Siebel Hospitality sends data, such as time, property, and function space, to a business service method, which is configured through this user property and the OnDoubleClick Invoke Service Method user property.
Value |
SHM Function Service |
Usage |
Calls a business service to retrieve the double-click event details from the method defined in the OnDoubleClick Invoke Service Method user property. |
Use this user property to configure the business component to retrieve the double-click event details when a user double-clicks the Function Space Diary grid. When the double-click event occurs, Siebel Hospitality sends data such as time, property, and function space to a business service method, which is configured through the OnDoubleClick Invoke Service user property and this user property.
Value |
OnDoubleClickFSDInfo |
Usage |
Defines the business service method that is called when double-clicked in the Function Space Diary. This business service method must be defined in the service that is configured in the OnDoubleClick Invoke Service user property. |
Small Red Triangle Comment Icon
Use this user property to associate the bitmap identifier with the Small Red Triangle icon (a three-cornered flag, which is red) displayed in the Function Space Diary for special events.
Value |
304 |
Usage |
Associates the bitmap identifier with the Small Red Triangle icon displayed in Function Space Diary for the Month/Day time scale. The value 304 represents the Small Red Triangle configured in C++ code. |
Special Date BC Name
Use this user property to define the business component from which special day event details can be retrieved.
Value |
TNT SHM Property Special Dates Action business component |
Usage |
Defines the business component from which special day event details can be retrieved. The special day data is retrieved from this business component and displayed in the respective Day columns in the Function Space Diary. |
Special Day Description
Use this user property to retrieve the descriptions of special days, if any, in a tooltip in the Function Space Diary.
Value |
Holiday Desc;Sell Note Desc;Special Event Desc |
Usage |
Indicates whether or not to display special day descriptions in a Function Space Diary tooltip. By default, the values are descriptions for three special days and have one-to-one mappings with the values of the Special Day Type user property. The combination can be modified by removing or adding new entries in accordance with the value of the Special Day Type user property. |
Example |
Holiday Desc;Special Event Desc |
Special Day Type
Use this user property to display the descriptions of special days, if any, in a tooltip in the Function Space Diary.
Value |
Holiday;Sell Notes;Special Events |
Usage |
Indicates whether or not to display special day descriptions in a Function Space Diary tooltip. By default, the values are three special day types. The combination can be modified by removing or adding new entries. |
Example |
Holiday;Special Events |
Views Displaying Across The Months
Use this user property to calculate the End Date/Month information, which is used to display Y-Axis header information (Month and Year) in the Function Space Diary.
Value |
256 |
Usage |
In the Function Space Diary, on some time scales, it might not be possible to identify for which month and year the data is displayed. For such time scales, month and year information is displayed on the Y-Axis Header. By default, the value is 256, which is the LIC value for the Month/Day-of-week/Day Part time scale. To support other time scales, append each value with a semicolon (;) delimiter. |
Example |
256;64;128 |
Views Having No Y-Axis Header
Use this user property to hide the Y-Axis Header information in the Function Space Diary
Value |
1;32 |
Usage |
In the Function Space Diary, on some time scales, it might not be necessary to display information on the Y-Axis header. By default, the value is 1;32. These numbers are LIC values for certain time scales. |
Views Having Space Crunch for Icons
Use this user property to define the time scales for which there is insufficient space to display more than two icons in the same column header in the Function Space Diary.
Value |
1;128 |
Usage |
Defines the time scales for which there is insufficient space to display more than two icons in the same column header. In this case, C++ code adjusts the space. Currently there is insufficient space for two time scales (Week/Day and Week/Day/Day Part) when there are more than two icons in the same column header. The values 1 and 128 represent LIC values for Week/Day and Week/Day/Day Part respectively. |
Weekend Admin BC Name
Use this user property to define the business component from which to retrieve weekend details for a given property. The Function Space Diary uses these weekend details to decide whether a day is a weekday or a weekend day, to display the correct color and icon in date column headers.
Value |
TNT SHM Weekend Admin |
Usage |
Defines the business component from which weekend details can be retrieved. The weekend data is used to decide color and icon to display in day columns in the Function Space Diary. |
Y-Axis Header Display Format
Use this user property to determine the format for the date to be displayed on the Y-Axis header in the Function Space Diary for some time scales.
Value |
MMMM YYYY |
Usage |
Specifies the Y-Axis header display format in the Function Space Diary, for example, August 2008. This user property is applicable only if month and year are displayed on the Y-Axis header. |
TNT SHM Compact Function Space Diary Applet User Properties
This topic describes the following user properties for the TNT SHM Compact Function Space Diary applet of the Function Space Diary:
Booking Drop Conflict Popup Default
If the pop-up applet name is not specified in the Booking Drop Conflict Popup Name user property, then this user property is used to specify the default selection option in the booking conflict pop-up window.
Value |
Option |
TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary, TNT SHM Function Space Diary Total Availability Applet |
Usage |
When a booking conflict occurs, a user can select either the OK, Option, Overbook, or Cancel option in the booking conflict pop-up window. If the pop-up applet name is not specified in the Booking Drop Conflict Popup Name user property, then this user property is used to specify the default option. |
This user property is used to specify the applet name for the booking conflict pop-up window.
Value |
TNT SHM Booking Option/Overbook Popup Applet |
Usage |
This user property is used to specify the applet name for the booking conflict pop-up window. |
DateTime Popup Name
This user property is used to specify the applet used to query for function space bookings in an interval.
Value |
TNT SHM Gantt Chart Query DateTime Interval Form Applet |
TNT SHM Order Item Category Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Category Inventory Availability Gantt Chart Applet, TNT SHM Order Item Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Inventory Availability Gantt Chart Applet, TNT SHM Function Space Diary Total Availability Applet, TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary - Business Type, TNT SHM Function Space Diary - Meal Period, TNT SHM Function Space Diary - Function Type, TNT SHM Function Space Diary - Quote Name, TNT SHM Function Space Diary - Setup Style |
Usage |
This user property is used to specify the applet used to query for function space bookings in an interval. |
Day Assignment Business Component
This user property is used to specify the business component that supports the function for assigning all the category bookings on a selected diary date to a specific space.
Value |
TNT SHM Function Space Diary Assign Day VBC |
TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary Total Availability Applet, TNT SHM Function Space Diary, TNT SHM Function Space Diary - Business Type, TNT SHM Function Space Diary - Meal Period, TNT SHM Function Space Diary - Function Type, TNT SHM Function Space Diary - Quote Name, TNT SHM Function Space Diary - Setup Style |
Usage |
This user property is used to specify the business component that supports the function for assigning all the category bookings on a selected diary date to a specific space. |
Day Assignment Date Field Name
This user property is used to specify the field from which the day assignment date is retrieved.
Value |
Date |
TNT SHM Function Space Diary - Quote Name, TNT SHM Function Space Diary - Function Type, TNT SHM Function Space Diary - Setup Style, TNT SHM Function Space Diary - Business Type, TNT SHM Function Space Diary - Meal Period, TNT SHM Function Space Diary Total Availability Applet, TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary |
Usage |
This user property is used to specify the field from which the day assignment date is retrieved. |
Day Assignment Popup Applet
This user property is used to specify the pop-up applet to be used for day assignments.
Value |
TNT SHM Function Space Diary Assign Day Popup Form Applet |
TNT SHM Function Space Diary - Quote Name, TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary - Business Type, TNT SHM Function Space Diary - Meal Period, TNT SHM Function Space Diary - Setup Style, TNT SHM Function Space Diary - Function Type, TNT SHM Function Space Diary Total Availability Applet, TNT SHM Function Space Diary |
Usage |
This user property is used to specify the pop-up applet to be used for day assignments. |
This user property is used to specify the pop-up applet to be displayed when a booking conflict occurs.
Value |
TNT SHM Option/Overbook Popup Applet |
Usage |
This user property is used to specify the pop-up applet to be displayed when a booking conflict occurs. This applet will display selection options such as Option, Overbook, and so on. |
End Date
This user property is used to specify the field name from which the effective end date of the function is retrieved.
Value |
End Date |
Usage |
This user property is used to specify the field name from which the effective end date of the function is retrieved. |
Function Drop Conflict Popup Default
If the booking conflict pop-up applet is not specified, this user property is used to specify the default operation to be performed when a booking conflict occurs.
Value |
OptionFunction |
Usage |
If the booking conflict pop-up applet is not specified, this user property is used to specify the default operation to be performed when a booking conflict occurs. |
Function Drop Conflict Popup Name
Value |
TNT SHM Function Option/Overbook Popup Applet |
Usage |
Grid Background Color
This user property is used to set the background color of the Function Space Diary Grid.
Value |
16777215 |
Usage |
This user property is used to set the background color of the Function Space Diary Grid. |
Grid Line Color
This user property is used to set the line color of the Function Space Diary Grid.
Value |
13421772 |
Usage |
This user property is used to set the line color of the Function Space Diary Grid. |
Grid Line Style
This user property is used to specify the style for the Function Space Diary Grid lines.
Value |
0 |
Usage |
This user property is used to specify the style for the Function Space Diary Grid lines. |
Ignore Case Sensitivity
This user property is used to control the case sensitivity for comparing function space strings and the string entered in the Go To field.
Value |
Y |
Usage |
This user property is used to control the case sensitivity for comparing function space strings and the string entered in the Go To field. |
Ineffective Field
This user property is used to specify the field from which the Function Space Diary retrieves the information about whether or not the function space is ineffective.
Value |
Is Ineffective |
Usage |
In the Function Space Diary, if a function space is ineffective, then the Diary displays the ineffective bar. This user property is used to specify the field from which the Diary retrieves the information about whether or not the function space is ineffective. |
Item Admin Color BC Name
This user property is used to specify the business component from which colors for different function space statuses are defined in the Function Space Administration view.
Value |
TNT SHM Gantt AX Admin Function Status |
Usage |
This user property is used to specify the business component from which colors for different function space statuses are defined in the Function Space Administration view. |
Item Admin Color BO Name
This user property is used to specify the business object from which colors for different function space statuses are defined in the Function Space Administration view.
Value |
System Preferences |
Usage |
This user property is used to specify the business object from which colors for different function space statuses are defined in the Function Space Administration view. |
Item Admin Special Control BC Name
This user property is used to specify the name of the business component from which information about specialized controls such as setup time pattern and tear-down time pattern is collected.
Value |
TNT SHM Gantt AX Admin Specialized Controls |
Usage |
This user property is used to specify the name of the business component from which information about specialized controls such as setup time pattern and tear-down time pattern is collected. |
Item BC Assignable Field
This user property is used to specify the field from which the required value (Assignable) is retrieved.
Value |
Assignable |
Usage |
This user property is used to specify the field from which the required value (Assignable) is retrieved. |
Item BC Dependency Field
This user property is used to specify the field from which the required value (Dependency) is retrieved.
Value |
Dependency |
Usage |
This user property is used to specify the field from which the required value (Dependency) is retrieved. |
Item BC Drillable Field
This user property is used to specify the field from which the required value (Drillable) is retrieved.
Value |
Drillable |
Usage |
This user property is used to specify the field from which the required value (Drillable) is retrieved. |
Item BC Editable Field
This user property is used to specify the field from which the required value (Editable) is retrieved.
Value |
Editable |
TNT SHM Function Space Diary Total Availability Applet, TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, TNT SHM Order Item Category Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Category Inventory Availability Gantt Chart Applet, TNT SHM Order Item Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Inventory Availability Gantt Chart Applet |
Usage |
This user property is used to specify the field from which the required value (Editable) is retrieved. |
Item BC Inventory Status Field
This user property is used to specify the field from which the required value (Inventory status) is retrieved.
Value |
Inventory Status |
Usage |
This user property is used to specify the field from which the required value (Inventory status) is retrieved. |
Item Border Style Fields
This user property is used to specify the dimensions for the duration bars in the Function Space Diary.
Value |
7;3;11;0 |
TNT SHM Function Space Diary - Business Type, TNT SHM Function Space Diary - Function Type, TNT SHM Function Space Diary - Meal Period, TNT SHM Function Space Diary - Quote Name, TNT SHM Function Space Diary - Setup Style, TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary, TNT SHM Function Space Diary Total Availability Applet, TNT SHM Order Item Category Inventory Availability Gantt Chart Applet, TNT SHM Order Item Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Category Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Inventory Availability Gantt Chart Applet |
Usage |
Each booking item is displayed as a time duration bar on the Function Space Diary page. The bar is composed of four smaller bars, representing setup time, configured space booking, tear down time, and a time block that is currently not used in the application. This user property is used to specify the dimensions for each of these bars. |
Item Border Style No Setup Time Fields
This user property is used to specify the dimensions for booking items in the Function Space Diary when there is no setup time for the function space.
Value |
0;7;11;0 |
Usage |
Each booking item is displayed as a time duration bar on the Function Space Diary page. The bar is composed of four smaller bars, representing setup time, configured space booking, tear down time, and a time block that is currently not used in the application. This user property is used to specify the dimensions for booking items when there is no setup time for the function space. |
Item Border Style No Teardown Time Fields
This user property is used to specify the dimensions for booking items in the Function Space Diary when there is no teardown time for the function space.
Value |
7;11;0;0 |
Usage |
Each booking item is displayed as a time duration bar on the Function Space Diary page. The bar is composed of four smaller bars, representing setup time, configured space booking, tear down time, and a time block that is currently not used in the application. This user property is used to specify the dimensions for booking items when a user deselects the turn time flag on the applet. |
Item Border Style No Turn Time Fields
Value |
0;15;0;0 |
Usage |
This user property is used to specify the business component used by the booking item.
Value |
TNT SHM Compact Function Booking VBC |
TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary, TNT SHM Function Space Diary - Business Type, TNT SHM Function Space Diary - Function Type, TNT SHM Function Space Diary - Meal Period, TNT SHM Function Space Diary - Quote Name, TNT SHM Function Space Diary - Setup Style, TNT SHM Function Space Diary Total Availability Applet, TNT SHM Order Item Category Inventory Availability Gantt Chart Applet, TNT SHM Order Item Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Category Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Inventory Availability Gantt Chart Applet |
Usage |
This user property is used to specify the business component used by the booking item. |
Item Drag Method
This user property is used to specify the method name when a booking item is selected and (without releasing the selection) moved to the Gantt chart.
Value |
InvokeDragItem |
Usage |
This user property is used to specify the method name when a booking item is selected and moved to the Gantt chart. |
Item Drilldown Assignment
This user property is used to specify the drill-down link for each bar in the Function Space Diary booking item.
Value |
Item Drilldown;Item Drilldown;Item Drilldown;Item Drilldown |
Usage |
Each booking item is displayed as a time duration bar on the Function Space Diary page. The bar is composed of four smaller bars, representing setup time, configured space booking time, tear-down time, and a time block that is currently not used in the application. This user property is used to specify the drill-down link for each bar in the booking item. |
Item Drilldown Src Field Substitutes
This user property specifies the destination that Siebel Hospitality displays when a user clicks a booking item. Use this user property to navigate to the destination view when drilling down on the booking in the Function Space Diary.
Value |
Item Drilldown;Quote Id |
Usage |
This user property specifies the destination that Siebel Hospitality displays when a user clicks a booking item. If Quote Id is specified when a user drills down on the booking in the Function Space Diary, this user property navigates to the Quotes screen, Functions view. If Function Id is specified when a user drills down on the booking in the Function Space Diary, this user property navigates to the Functions screen. |
Item Fill Style Fields
Value |
Setup Time;Configured Space Booking;Tear Down Time;Tear Down Time |
TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary, TNT SHM Function Space Diary Total Availability Applet, TNT SHM Order Item Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Category Inventory Availability Gantt Chart Applet, TNT SHM Quote Item Inventory Availability Gantt Chart Applet |
Usage |
Each booking item is displayed as a time-duration bar on the Function Space Diary page. The bar is composed of four smaller bars, representing setup time, configured space booking time, tear-down time, and a time block that is currently not used in the application. |
Item Function Business Component
This user property is used to specify the business component to be used for the Function Booking Item.
Value |
TNT SHM FSI Booking |
Usage |
This user property is used to specify the business component to be used for the Function Booking Item. |
Item Icon Clip Text LIC
This user property is used to specify the icon clip text on the booking item.
Value |
Noise;Detail;Suite;Function Scheduling;Do Not Move;Recurring;Host;Affiliate;24 Hour Hold |
TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary, TNT SHM Function Space Diary Total Availability Applet, TNT SHM Function Space Diary - Business Type, TNT SHM Function Space Diary - Function Type, TNT SHM Function Space Diary - Meal Period, TNT SHM Function Space Diary - Quote Name TNT SHM Function Space Diary - Setup Style |
Usage |
When a function is created, flags such as Noise, Detail, Suite, and so on are displayed in the function. This user property is used to specify the icon clip text on the booking item. |
Item Icon Clip Text LOV Name
This user property is used to specify the list of values from which the clip text is retrieved.
Value |
TNT_SHM_GNTAX_ICON_CLIPTEXT |
TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary, TNT SHM Function Space Diary Total Availability Applet, TNT SHM Function Space Diary - Business Type, TNT SHM Function Space Diary - Function Type, TNT SHM Function Space Diary - Meal Period, TNT SHM Function Space Diary - Quote Name, TNT SHM Function Space Diary - Setup Style |
Usage |
This user property is used to specify the list of values from which the clip text is retrieved. |
Item Icon Fields
This user property is used to specify the field names to which item icons refer.
Value |
Noise Flag;Detail Flag;Suite Flag;Function Schedule Flag;Do Not Move Calc;Sub Recurrence Flag;Host Flag;Affiliate Flag;24 Hour Hold Flag |
Usage |
This user property is used to specify the field names to which item icons refer. |
Item Icon Ids
This user property is used to specify the Ids for item icons.
Value |
201;215;216;217;203;218;219;220;202 |
Usage |
This user property is used to specify the Ids for item icons. |
Item Id Field
This user property is used to specify the field to which each booking item refers.
Value |
Booking Id |
Usage |
This user property is used to specify the field to which each booking item refers. |
Item Join Field
This user property is used to specify the link between a booking and a function space.
Value |
Function Space Id |
Usage |
This user property is used to specify the link between a booking and a function space. |
Item Left Click Method
This user property is used to specify the method to be called when a user left-clicks a booking item.
Value |
InvokeDrillDown |
Usage |
This user property is used to specify the method to be called when a user left-clicks a booking item. |
Item Resize Method
This user property is used to specify the method to be called when a booking item is resized.
Value |
InvokeDragItem |
Usage |
This user property is used to specify the method to be called when a booking item is resized. |
Item Right Click Method
This user property is used to specify the method to be called when a user right-clicks a booking item.
Value |
InvokeAssignItem |
Usage |
This user property is used to specify the method to be called when a user right-clicks a booking item. |
Item Segment Left Click Methods
This user property is used to specify the method to be called when a user left-clicks an item segment.
Value |
InvokeDrillDown;InvokeDrillDown;InvokeDrillDown;InvokeDrillDown |
Usage |
This user property is used to specify the method to be called when a user left-clicks an item segment. |
Item Time Dependency Fields
This user property is used to specify the field from which dependency item information is retrieved.
Value |
Absolute Set Up Date Time;Start Date Time;Absolute End Date Time;Absolute Tear Down Date Time |
Usage |
This user property is used to specify the field from which dependency item information is retrieved. |
Item Time Dependency Tooltip Fields
This user property is used to specify the field from which dependency ToolTip information is retrieved.
Value |
Booking Dependency Tip;Booking Dependency Tip;Booking Dependency Tip;Booking Dependency Tip |
Usage |
This user property is used to specify the field from which dependency ToolTip information is retrieved. |
Item Time Display Toggle LOV Type
This user property is used to specify the list of values from which the name to be displayed on the booking item is retrieved.
Value |
TNT_SHM_GNTAX_FSD_DSP_TOGGLE |
Usage |
This user property is used to specify the list of values from which the name to be displayed on the booking item is retrieved. This user property is used by the Display field in the applet. |
Item Time Display Toggle Time Label 0
This user property is used to display the Function Name on the booking item.
Value |
Function Name Calculated |
Usage |
This user property is used to display the Function Name on the booking item. |
Item Time Display Toggle Time Label 1
This user property is used to display the Function Type on the booking item.
Value |
Function Type Calculated |
Usage |
This user property is used to display the Function Type on the booking item. |
Item Time Display Toggle Time Label 2
This user property is used to display the Meal Period on the booking item.
Value |
Meal Period Calculated |
Usage |
This user property is used to display the Meal Period on the booking item. |
Item Time Display Toggle Time Label 3
This user property is used to display the Business Type on the booking item.
Value |
Business Type Calculated |
Usage |
This user property is used to display the Business Type on the booking item. |
Item Time Display Toggle Time Label 4
This user property is used to display the Quote Name on the booking item.
Value |
Quote Name Calculated |
Usage |
This user property is used to display the Quote Name on the booking item. |
Item Time Display Toggle Time Label 5
This user property is used to display the Setup Style on the booking item.
Value |
Setup Style Calculated |
Usage |
This user property is used to display the Setup Style on the booking item. |
Item Time Display Toggle Time Label 6
This user property is used to display the Function Status on the booking item.
Value |
Function Status Calculated |
Usage |
This user property is used to display the Function Status on the booking item. |
Item Time Display Toggle Time Label 7
This user property is used to display the Event Manager Name on the booking item.
Value |
Event Manager Calculated |
Usage |
This user property is used to display the Event Manager Name on the booking item. |
Item Time Display Toggle Time Label 8
This user property is used to display the Sales Manager Name on the booking item.
Value |
Sales Manager Calculated |
Usage |
This user property is used to display the Sales Manager Name on the booking item. |
Item Time Display Toggle Time Label 10
This user property is used to display the Account Name on the booking item.
Value |
Account Name Calculated |
TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary |
Usage |
This user property is used to display the Account Name on the booking item. |
Item Time Display Toggle Time Label 12
This user property is used to display the Function Start Date on the booking item.
Value |
Function Start Date Calculated |
Usage |
This user property is used to display the Function Start Date on the booking item. |
Item Time Display Toggle Time Label 13
This user property is used to display the Function Day on the booking item.
Value |
Function Day Calculated |
Usage |
This user property is used to display the Function Day on the booking item. |
Item Time Display Toggle Time Label 17
This user property is used to display the Inventory Status on the booking item.
Value |
Inventory Status Calculated |
Usage |
This user property is used to display the Inventory Status on the booking item. |
Item Time Display Toggle Time Tooltip 0
This user property is used to specify the ToolTips to be displayed on the booking item.
Value |
Booking Set Up Tip;Booking Tip - Function Name;Booking Tear Down Tip;Booking Tear Down Tip |
Usage |
This user property is used to specify the ToolTips to be displayed on the booking item. |
Item Time Display Toggle Time Tooltip 1
This user property is used to specify the ToolTips to be displayed for the function space booking item.
Value |
Booking Set Up Tip;Booking Tip - Function Type;Booking Tear Down Tip;Booking Tear Down Tip |
Usage |
This user property is used to specify the ToolTips to be displayed for the function space booking item. |
Item Time Display Toggle Time Tooltip 2
Value |
Booking Set Up Tip;Booking Tip - Meal Period;Booking Tear Down Tip;Booking Tear Down Tip |
Usage |
Item Time Display Toggle Time Tooltip 3
Value |
Booking Set Up Tip;Booking Tip - Business Type;Booking Tear Down Tip;Booking Tear Down Tip |
Usage |
Item Time Display Toggle Time Tooltip 4
Value |
Booking Set Up Tip;Booking Tip - Quote Name;Booking Tear Down Tip;Booking Tear Down Tip |
Usage |
Item Time Display Toggle Time Tooltip 5
Value |
Booking Set Up Tip;Booking Tip - Setup Style;Booking Tear Down Tip;Booking Tear Down Tip |
Usage |
Item Time Display Toggle Time Tooltip 6
Value |
Booking Set Up Tip;Booking Tip - Function Status;Booking Tear Down Tip;Booking Tear Down Tip |
Usage |
Item Time Display Toggle Time Tooltip 7
Value |
Booking Set Up Tip;Booking Tip - Event Manager;Booking Tear Down Tip;Booking Tear Down Tip |
Usage |
Item Time Display Toggle Time Tooltip 8
Value |
Booking Set Up Tip;Booking Tip - Sales Manager;Booking Tear Down Tip;Booking Tear Down Tip |
Usage |
Item Time Display Toggle Time Tooltip 17
Value |
Usage |
Item Time Fields
This user property is used to specify the fields for booking item segments.
Value |
Usage |
This user property is used to specify the fields for booking item segments. |
Item Time Ineffective Tooltip Fields
This user property is used to specify the ToolTips to be displayed the function space is ineffective.
Value |
Ineffective Tip;Ineffective Tip;Ineffective Tip;Ineffective Tip |
Usage |
This user property is used to specify the ToolTips to be displayed the function space is ineffective. |
Item Tooltip Fields
This user property is used to specify the ToolTips to be displayed when the mouse hovers over each of the booking item segments.
Value |
Usage |
This user property is used to specify the ToolTips to be displayed when the mouse hovers over each of the booking item segments, such as setup time, function name, and teardown time. |
Item Type Field
This user property is used to specify the field from which the booking type is retrieved.
Value |
Booking Type |
Usage |
This user property is used to specify the field from which the booking type is retrieved. |
Number of Rows to Overlap
This user property is used to control how many function spaces from the previous set are displayed in the next set.
Value |
1 |
Usage |
When a user navigates to the next set of function spaces, the last function space in the previous set is displayed as the first item in the next set. This user property is used to control how many function spaces from the previous set are displayed in the next set. |
Parent BC Date Context Field
This user property is used to specify the Start Date search criteria to be shared among the Function Space Diary pages.
Value |
Search Sleeping Room Date |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary Total Availability Applet, TNT SHM Function Space Diary - Function Type, TNT SHM Function Space Diary - Business Type, TNT SHM Function Space Diary - Meal Period, TNT SHM Function Space Diary - Setup Style, TNT SHM Function Space Diary - Quote Name, TNT SHM SR Inventory Display Dync List Applet - Read Only, TNT SHM SR Inventory Display Dync List applet, TNT SHM SR Inventory Display Dync List Applet - Total Availability, TNT SHM SR Total Transient Avail Dync List Applet, TNT SHM SR Total Avail Room Specific Dync List Applet, TNT SHM Suite Total Avail Room Specific Dync List Applet, TNT SHM Sleeping Room Search Form Applet (No Product LOV), TNT SHM Function Space Inventory DyncPivot List Applet |
Usage |
This user property is used to specify the Start Date search criteria to be shared among the Function Space Diary pages. This field is in the parent business component (SHM Site), which allows child business components to share the Date context. |
Sell Notes - Special Dates Business Component
This user property is used to specify the business component from which sell notes and special dates information is retrieved.
Value |
TNT SHM Property Sell Note VBC |
Usage |
This user property is used to specify the business component from which sell notes and special dates information is retrieved. |
Sell Notes - Special Dates Popup Applet
This user property is used to specify the pop-up applet for sell notes and special dates.
Value |
TNT SHM Property Sell Notes Popup Applet |
Usage |
This user property is used to specify the pop-up applet for sell notes and special dates. |
Sell Notes - Special Dates Start Date Field Name
This user property specifies the field name from which the sell notes and special dates start date is retrieved.
Value |
Start Date |
Usage |
This user property specifies the field name from which the sell notes and special dates start date is retrieved. |
Slider Width(Height)
This user property is used to set the width of the slider.
Value |
5 |
Usage |
This user property is used to set the width of the slider. |
Start Date
This user property is used to retrieve the Start Date for the Function Space Diary.
Value |
Start Date |
Usage |
This user property is used to retrieve the Start Date for the Function Space Diary. |
Time BC Start Time Field
This user property is used to specify the Start Date and Start Time for the Function Space Diary.
Value |
Start Date Time |
Usage |
This user property is used to specify the Start Date and Start Time for the Function Space Diary. |
Time Business Component
This user property is used to specify the business component for the Gantt chart.
Value |
Usage |
This user property is used to specify the business component for the Gantt chart. |
TNT CMT Same Time Frame - Show Move Popup Applet
This user property is used to controls whether or not to show the Move pop-up window in this applet when a booking is selected and (without releasing the selection) moved to a time where another booking already exists.
Value |
Y |
Usage |
Controls whether or not to show the Move pop-up window in this applet when a booking is selected and (without releasing the selection) moved to a time where another booking already exists. If the value of this user property is Y, the Move pop-up window is displayed. Otherwise, the Move pop-up window is not displayed. |
X Axis Popup Height
This user property is used to set the height of the pop-up applet.
Value |
450 |
Usage |
This user property is used to set the height of the pop-up applet. |
X Axis Popup Width
This user property is used to set the width of the pop-up applet.
Value |
600 |
Usage |
This user property is used to set the width of the pop-up applet. |
X-Axis Background Color
This user property is used to set the background color of the x-axis (major and minor axis) of the Gantt chart.
Value |
15790320 |
Usage |
This user property is used to set the background color of the x-axis (major and minor axis) of the Gantt chart. |
X-Axis Height
This user property is used to specify the height of the x-axis.
Value |
40 |
Usage |
This user property is used to specify the height of the x-axis. |
X-Axis Line Color
This user property is used to specify the line color for the x-axis.
Value |
13421772 |
Usage |
This user property is used to specify the line color for the x-axis. |
X-Axis Line Style
This user property is used to specify the line style of the x-axis.
Value |
0 |
Usage |
This user property is used to specify the line style of the x-axis. |
Y Axis Join Field
This user property is used to specify the link between the booking item and the specific space.
Value |
Room Id |
Usage |
This user property is used to specify the link between the booking item and the specific space. |
Y-Axis Background Color
This user property is used to specify the background color for the y-axis of the Gantt chart.
Value |
16777215;16777215;16777215;16777215 |
Usage |
This user property is used to specify the background color for the y-axis of the Gantt chart. |
Y-Axis Business Component
This user property is used to specify the business component for the y-axis.
Value |
TNT SHM Compact Room Rel VBC |
Usage |
This user property is used to specify the business component for the y-axis. |
Y-Axis Draw Sides
This user property is used to draw the sides of the y-axis with the specified values as the widths of the upper line, start line, lower line, and end line respectively.
Value |
2;2;2;2 |
Usage |
This user property is used to draw the sides of the y-axis with the specified values as the widths of the upper line, start line, lower line, and end line respectively. |
Y-Axis Drilldown Index Field
This user property is used to specify the index field for the y-axis drill-down destination.
Value |
Drilldown Index Field |
Usage |
This user property is used to specify the index field for the y-axis drill-down destination. |
Y-Axis Drilldown Src Field Substitutes
This user property is used to specify the y-axis drill-down destination fields.
Value |
Category Space Drilldown;Room Property Id;Specific Space Drilldown;Room Property Id |
Usage |
This user property is used to specify the y-axis drill-down destination fields. |
Y-Axis Header Background Color
This user property is used to set the background color for the y-axis header.
Value |
15790320 |
Usage |
This user property is used to set the background color for the y-axis header. |
Y-Axis Header Label Text
This user property is used to specify the label text for the y-axis header.
Value |
Specific Space |
Parent Object Type |
Usage |
This user property is used to specify the label text for the y-axis header. |
Y-Axis Header Line Color
This user property is used to specify the color of the y-axis header line.
Value |
13421772 |
Usage |
This user property is used to specify the color of the y-axis header line. |
Y-Axis Header Line Style
This user property is used to specify the line style of the y-axis header.
Value |
0 |
Usage |
This user property is used to specify the line style of the y-axis header. |
Y-Axis Hierarchy
This user property is used to display the individual specific spaces in the function space category.
Value |
Y |
Usage |
Function space categories are displayed in tree format on the y-axis. To display the individual specific spaces in the category, set this user property value to Y. |
Y-Axis Hierarchy Drilldown Assignment
This user property is used to specify drill-down destinations for the y-axis hierarchy.
Value |
Specific Space Drilldown;Category Space Drilldown |
Usage |
This user property is used to specify drill-down destinations for the y-axis hierarchy. The first value is for specific space drill-down destinations and the second value is for category drill-down destinations. |
Y-Axis Item Dimensions
This user property is used to set the dimensions of the y-axis item.
Value |
0;20;40;520 |
Usage |
This user property is used to set the dimensions of the y-axis item. |
Y-Axis Item Fields
This user property is used to specify the fields for the icons on the y-axis.
Value |
Room Backup Required Id;Hierarchy Bitmap Id;Room Name Display;Room Name Display |
Usage |
Each y-axis item is divided into four parts, which are Backup Required icon, Hierarchy icon, Function Space label, and another label. This user property is used to specify the fields for the icons on the y-axis. |
Y-Axis Item Font Colors
This user property is used to set the font colors for y-axis items (function spaces).
Value |
13408614;13408614;13408614;13408614 |
Usage |
This user property is used to set the font colors for y-axis items (function spaces). |
Y-Axis Item Icons
This user property is used to specify the icon Ids for y-axis items.
Value |
207;206;210;204 |
Usage |
This user property is used to specify the icon Ids for y-axis items such as Backup Required and so on. |
Y-Axis Item Tooltip Fields
This user property is used to specify ToolTips to be displayed for y-axis items.
Value |
;;Room ToolTip;Room ToolTip |
Usage |
This user property is used to specify ToolTips to be displayed for y-axis items. |
Y-Axis Item Types
This user property is used to specify the icon types for y-axis items.
Value |
GIcon;GIcon;GLbl;GLbl |
Usage |
This user property is used to specify the icon types for y-axis items. |
Y-Axis Left Click Methods
This user property is used to specify the method to be called when a user left-clicks a y-axis item.
Value |
;InvokeToggleChildren;InvokeDrillDown; |
Usage |
This user property is used to specify the method to be called when a user left-clicks a y-axis item. |
Y-Axis Line Color
This user property is used to set the line color on the y-axis.
Value |
13421772;13421772;13421772;13421772 |
Usage |
This user property is used to set the line color on the y-axis. |
Y-Axis Line Style
This user property is used to set the line style on the y-axis.
Value |
0;0;0;0 |
Usage |
This user property is used to set the line style on the y-axis. |
Y-Axis Line Width
This user property is used to specify the line width on the y-axis.
Value |
1;1;1;1 |
Usage |
This user property is used to specify the line width on the y-axis. |
Y-Axis Row Type Field
This user property is used to specify the type of the y-axis row.
Value |
Room Type |
Usage |
This user property is used to specify the type of the y-axis row. |
Y-Axis Width
This user property is used to specify the width of the Y-axis.
Value |
Function Space Column Size |
Usage |
This user property specifies the width of the Y-axis. The value of this user property is a column name in the User Preferences business component. This allows users to set their preferences for Y-axis width in the User Preferences screen. |
Business Component User Properties for Function Space Diary
This topic describes the following business component user properties:
Color Code Holiday Type
Use this user property to define the type of special day to which the Holiday color code type is mapped in the Function Space Diary.
Value |
Holiday |
TNT SHM Gantt AX Date Time Interval PopUp VBC business component |
Usage |
Each color code type has a different color, and each color must be mapped to a particular special day type to identify those days in the Function Space Diary. The default value is Holiday, which is the LOV display value for Holiday in the Property Pricing Admin screen, Sell Notes view. The special day configurations for a property are defined in the Sell Notes view. In the Function Space Diary, the color coding is applied to the day columns, if they belong to any of the special days that are defined in the Sell Notes view. |
Color Code Sell Note Type
Use this user property to define the type of special day to which the Sell Note color code type is mapped in the Function Space Diary.
Value |
Sell Notes |
Usage |
Each color code type has a different color, and each color must be mapped to a particular special day type to identify those days in the Function Space Diary. The default value is Sell Notes, which is the LOV display value for Sell Notes in the Property Pricing Admin screen, Sell Notes view. The special day configurations for a property are defined in the Sell Notes view. In the Function Space Diary, the color coding is applied to the day columns, if they belong to any of the special days that are defined in the Sell Notes view. |
Color Code Special Events Type
Use this user property to define the type of special day to which the Special Events color code type is mapped in the Function Space Diary.
Value |
Special Events |
Usage |
Each color code type has a different color, and each color must be mapped to a particular special day type to identify those days in the Function Space Diary. The default value is Special Events, which is the LOV display value for Special Events in the Property Pricing Admin screen, Sell Notes view. The special day configurations for a property are defined in the Sell Notes view. In the Function Space Diary, the color coding is applied to the day columns, if they belong to any of the special days that are defined in the Sell Notes view. |
Diary User Preferences Fields
Use this user property to retrieve the user preferences defined in the User Preferences screen, Function Space Diary view. When a user navigates to Function Space Diary, the view is displayed with these predefined attributes.
Value |
Time Scale Text;Display Toggle - Query;Toggle TurnTime - Query;Configured Space Pattern |
Usage |
Retrieves the user preferences defined in the User Preferences screen, Function Space Diary view. When a user navigates to the Function Space Diary, the view is displayed with these predefined attributes. The values correspond to the Time Scale, Display, Turn Time, and Config Space Pattern controls in the Function Space Diary view. For these controls, a user can enter values in the User Preferences view, which are set as the default values for the controls in the Function Space Diary view. These user preferences are captured through the Time Scale Text, Display Toggle - Query, Toggle TurnTime - Query, and Configured Space Pattern fields of the User Preferences business component. These fields are prefixed with Diary/, for example, Diary/Time Scale Text. |
Enable Single Button Toggle
Use this user property to enable or disable the toggle button click functionality.
Value |
Y |
TNT SHM SR Inventory Dync business component |
Usage |
Turns the toggle button click functionality on or off. If the value is Y, the dynamic applet of the toggle button can support toggle button functionality. |
Format Specifier Major
This user property is used to specify the date format on the major axis for each time scale. Use this user property to define the date formats for different time scales on the major axis of the Function Space Diary.
Value |
1;MMMM YYYY;2;DDDD DD;4;DDDD DD;8;DDDD DD;16;DDDD DD;32;MMMM YYYYY;64;DDD;128;DDD DD;256;DDD DD |
TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC |
Value |
1;MMMM YYYY;2;MMMM DD YYYY;4;DDDD MMMM DD YYYY;8;DDDD MMMM DD YYYY;16;DDDD MMMM DD YYYY;32;MMMM YYYYY |
TNT SHM Inventory Gantt AX Date Time Interval PopUp VBC |
Value |
Usage |
Multiple time scales are available for user selection. Each time scale is referenced by a code, as follows: |
Time Scale |
Code |
Week/Day |
1 |
Day/Day-Part |
2 |
Day/Hour |
4 |
Day/Half-Hour |
8 |
Day/Quarter-Hour |
16 |
Month/Day-of-Week |
32 |
Month/Day |
64 |
Week/Day/Day-Part |
128 |
Month/Day-of-Week/Day-Part |
256 |
This user property is used to specify the date format on the major axis for each time scale. This user property determines the date formats for the major axis of the Function Space Diary, for example, August 2008. The value is a set of name-value pairs. The first part of the delimiter represents the time scale, and the second part represents the format that applies to the time scale. |
Format Specifier Minor
This user property is used to specify the date format on the minor axis for each time scale. Use this user property to define the date formats for different time scales on the minor axis of the Function Space Diary.
Value |
1;DDD DD;2;DD h:m p;4;h p;8;h:m p;16;h:m p;32;DDDD DD;64;DD;128;DD h:m p;256;DD h:m p |
Value |
1;DDDD MMMM DD;2;DD h:m p;4;h p;8;h:m p;16;h:m p;32;DDDD DD |
Value |
Usage |
Multiple time scales are available for user selection. Each time scale is referenced by a code, as follows. |
Time Scale |
Code |
Week/Day |
1 |
Day/Day-Part |
2 |
Day/Hour |
4 |
Day/Half-Hour |
8 |
Day/Quarter-Hour |
16 |
Month/Day-of-Week |
32 |
Month/Day |
64 |
Week/Day/Day-Part |
128 |
256 |
This user property is used to specify the date format on the minor axis for each time scale. This user property determines the date formats for the minor axis of the Function Space Diary, for example, August 2008. The value is a set of name-value pairs. The first part of the delimiter represents the time scale, and the second part represents the format that applies to the time scale. |
Gantt Prefix
Use this user property to get an expression and set the expression as the named search specification for the TNT SHM Function Booking VBC business component.
Value |
GntAX Func Stat: |
TNT SHM Gantt AX Admin Function Status Color business component |
Usage |
The value of this user property is used as a prefix along with Status value of the function. The concatenated value is stored in the system preferences under the Name column. This user property is also used in C++ code in conjunction with the Status Color Scheme LIC user property to identify the color coding needed to display bookings, as defined by the function booking color scheme selection in the Function Space Diary screen. |
Include End Time in Label Major
This user property is used to specify whether or not a time interval is displayed on the major axis, for each time scale.
Value |
1;Y;2;N;4;N;8;N;16;N;32;Y;64;N |
Usage |
This user property is used to specify whether or not a time interval is displayed on the major axis, for each time scale. An example time interval is January 2012 to February 2012. If a value is set to N, only the start date is displayed on the major axis. |
Method Name 1
Use this user property to call a method when a user clicks the custom toggle button in the applet that is based on the TNT SHM SR Inventory Dync business component.
Value |
WithoutTentative |
Usage |
This user property is used when a custom toggle button exists on an applet. This user property calls different methods. The methods called are based on the caption of the button. The value for this user property is a method name, which is called by default when a user clicks the custom toggle button on the applet. The method name becomes the caption for the button. The method name must be defined as a LOV value for the TNT_SHM_TOTAL_AVAILABILITY type. |
Parent Field 1
Use this user property to retrieve the required field values from the parent business component when a user double-clicks in the Function Space Diary.
Value |
Id |
SHM Site business component |
Usage |
Defines the business component from which to retrieve the required field values when a user double-clicks in the Function Space Diary. The default value is SHM Site, which is the parent business component of the Function Space Diary. When a user double-clicks in the Function Space Diary, this user property and other details are sent to the service method, which is configured in the OnDoubleClick Invoke Service Method user property. |
Pivot 1 Type 0
In the applet that is based on the TNT SHM SR Inventory Dync business component, the exact quantity of blocked rooms is displayed under the Group Blocked heading.
Value |
Group Blocked;1;Exact Blocked;1 |
Usage |
Displays the aggregate value of the blocked sleeping rooms under the Group Blocked heading. |
Pivot 1 Type 2
In the applet that is based on the TNT SHM SR Inventory Dync business component, the exact quantity of projected rooms is displayed under the Group Projected heading.
Value |
Group Projected;1;Exact Projected;1 |
Usage |
Displays the aggregate value of the projected sleeping rooms under the Group Projected heading. |
Scale Unit Major
This user property is used to adjust the scaling factor on the major axis. Use this user property to define the scale unit of the major axis for different time scales in the Function Space Diary.
Value |
1;0.25;2;1;4;0.5;8;4;16;7;32;1;64;1 |
TNT SHM Gantt AX Date Time Interval PopUp VBC, TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC, TNT SHM Inventory Gantt AX Date Time Interval PopUp VBC |
Usage |
This user property is used to adjust the scaling factor on the major axis. This user property determines the scale unit of the major axis for different time scales in the Function Space Diary. The value is a set of name-value pairs. The first part of the delimiter represents the time scale, and the second part represents the unit scale of the major axis. |
Scale Unit Minor
This user property is used to adjust the scaling factor on the minor axis. Use this user property to define the scale unit of the minor axis for different time scales in the Function Space Diary.
Value |
1;1;2;1;4;.75;8;1;16;2;32;1;64;1;128;1;256;1 |
Value |
1;1.5;2;1;4;1;8;4;16;7;32;1 |
Value |
Usage |
This user property is used to adjust the scaling factor on the minor axis. This user property determines the scale unit of the minor axis for different time scales in the Function Space Diary. The value is a set of name-value pairs. The first part of the delimiter represents the time scale, and the second part represents the unit scale of the minor axis. |
Segments Per Page Major
This user property is used to specify the number of segments per page to be displayed on the major axis, for each time scale. Use this user property to define the segments per page of the major axis for different time scales in the Function Space Diary.
Value |
1;1;2;1;4;1;8;1;16;1;32;2;64;30;128;8;256;8 |
Value |
1;1;2;1;4;1;8;1;16;1;32;1 |
Value |
Usage |
This user property is used to specify the number of segments per page to be displayed on the major axis, for each time scale. This user property determines the segments per page of the major axis for different time scales in the Function Space Diary. The value is a set of name-value pairs. The first part of the delimiter represents the time scale, and the second part represents the segments per page for the major axis. |
Segments Per Page Minor
This user property is used to specify the number of segments per page to be displayed on the minor axis, for each time scale. Use this user property to define the segments per page of the minor axis for different time scales in the Function Space Diary.
Value |
1;8;2;1;4;24;8;24;16;48;32;8;64;30;128;8;256;8 |
Value |
1;7;2;1;4;24;8;48;16;96;32;4 |
Value |
Usage |
This user property is used to specify the number of segments per page to be displayed on the minor axis, for each time scale. This user property determines the segments per page of the minor axis for different time scales in the Function Space Diary. The value is a set of name-value pairs. The first part of the delimiter represents the time scale, and the second part represents the segments per page for the minor axis. |
Spl Date BC Description Field
Use this user property to retrieve the description for a special day and display the description in a tooltip in the Function Space Diary.
Value |
Description |
Usage |
Retrieves the description value for a special day and displays the description in a tooltip in the Function Space Diary. The default value is Description, which is the field name of the TNT SHM Property Special Dates Action business component, which in turn is defined for the Special Date BC Name user property. The value can also be mapped to any field other than Description that acts as a descriptive field for the TNT SHM Property Special Dates Action business component. |
Spl Date BC End Date Field
Use this user property to retrieve the end date or expiration date for special days.
Value |
End Date |
Usage |
Retrieves the end or expiration date value for defined special days. The Start Date and End Date of the special days are used in C++ code to determine whether or not the date column in the Function Space Diary lies within the date range of any special day. If it does, then the color code or icon of the special day is displayed on that date column in the Function Space Diary. The default value is End, which is the field name of the TNT SHM Property Special Dates Action business component, which in turn is defined for the Special Date BC Name user property. The value can also be mapped to any field other than End that acts as an expiration date for the TNT SHM Property Special Dates Action business component. |
Spl Date BC Start Date Field
Use this user property to retrieve the start date for special days.
Value |
Start Date |
Usage |
Retrieves the Start Date value for defined special days. The Start Date and End Date of the special days are used in C++ code to determine whether or not the date column in the Function Space Diary lies within any special day range. If it does, then the color code or icon of the special day is displayed on that date column in the Function Space Diary. The default value is Start, which is the field name of the TNT SHM Property Special Dates Action business component, which in turn is defined for the Special Date BC Name user property. The value can also be mapped to any field other than Start that acts as an expiration date for the TNT SHM Property Special Dates Action business component. |
Spl Date BC Type Field
Use this user property to retrieve the types of special days.
Value |
Type |
Usage |
This user property is used to retrieve the special day type. This type determines the color code mechanism. The default value is Type, which is the field name of the TNT SHM Property Special Dates Action business component, which in turn is defined for the Special Date BC Name user property. The value can also be mapped to any field other than Type that acts as the type for the TNT SHM Property Special Dates Action business component. |
Use this user property to indicate the LIC of the status for which toggle color codes are configured in the Function Space Administration screen.
Value |
FUNCTION_STATUS |
Usage |
This user property is used in C++ code in conjunction with the Gantt Prefix user property to identify the color coding needed to display the bookings as defined by the function booking color scheme selection in the Function Space Diary screen. This is the LIC of the status in TNT_FSD_COLOR_SCHEMA. |
Time Part BC Minor 3
Use this user property to retrieve the time part details for a property in the Function Space Diary.
Value |
256;TNT SHM Property Day Part Pricing |
Usage |
Usage of this user property is the same as Time Part BC Minor. |
Time Part BC Minor Property Field
Use this user property to retrieve the Property Id for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component.
Value |
Property Id |
Usage |
Retrieves the Property Id for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component. The default value is Property ID, which is a field in the TNT SHM Property Day Part Pricing business component. |
Tool Tip Delimiter
Use this user property to specify the delimiter for the tooltip in the Function Space Diary.
Value |
Usage |
Separates the attribute names and values in the tooltip in the Function Space Diary. The default value is a colon (:). |
Example |
If the attribute name is Function Type and value is Board Meeting, then the tooltip stores this information as Function Type:Board Meeting. |
Undo Method Name 1
Value |
WithTentative |
Usage |
This user property is used when a custom toggle button exists on an applet. The value of this user property represents the toggle method for the toggle button. When a user clicks the custom toggle button in the applet, the method that is configured for the Method Name 1 user property is called. Additionally, this method name WithTentative becomes the caption for the button. The method name must be defined as a LOV value for the TNT_SHM_TOTAL_AVAILABILITY type. When the user clicks the custom toggle button again, the method WithTentative is called. |
Units Per Segment Major
This user property is used to specify the number of units per segment on the major axis.
TNT SHM Gantt AX Date Time Interval PopUp VBC |
Value |
1;7;2;1;4;1;8;0.5;16;0.25;32; 28;64;1;128;1;256;7 |
Value |
1;7;2;1;4;1;8;1;16;1;32;28 |
Value |
Usage |
This user property is used to specify the number of units per segment on the major axis. |
Units Per Segment Minor
This user property is used to specify the number of units per segment on the minor axis.
Value |
1;1;2;1;4;0.0416666666666666;8;0.0 20833333333333334;16;0.010416666 666666666;32;7;64;1;128;1;256;7 |
Value |
1;1;2;1;4;0.0416666666666666;8;0.0 20833333333333333;16;0.010416666 666666666;32;7 |
Value |
Usage |
This user property is used to specify the number of units per segment on the minor axis. |
WithoutTentative:Field Name
Use this user property to set the Boolean value of the field of the dependent TNT SHM Quote Room Block Line Items Aggr business component, to which the toggle method call is delegated.
Value |
Tentative Flag |
Usage |
Sets the Boolean value of the field of the dependent TNT SHM Quote Room Block Line Items Aggr business component, to which the toggle method call will be delegated. The default value is Tentative Flag. When a user clicks the toggle button that displays a caption of Without Tentative, the Tentative Flag field of the TNT SHM Quote Room Block Line Items Aggr business component is set to True, and the aggregated records are prepared in the TNT SHM Quote Room Block Line Items Aggr business component. |
WithoutTentative:Status
Use this user property to remove the records associated with the referenced status (T1 and T2) when a user clicks the toggle button that displays a caption of Without Tentative.
Value |
T1;T2; |
Usage |
Removes the records associated with the referenced status (T1 and T2) when a user clicks the toggle button that displays a caption of Without Tentative. The aggregate records are processed in the TNT SHM Quote Room Block Line Items Aggr business component. |
WithoutTentative:Undo Method Name
Use this user property to implement toggle functionality in a toggle button.
Value |
WithTentative |
Usage |
Changes the caption of the toggle button when a user clicks the toggle button. The value is WithTentative. If a user clicks a toggle button with the caption WithoutTentative, the caption of the toggle button is replaced by WithoutTentative. |
WithTentative:Undo Method Name
Value |
WithoutTentative |
Usage |
Changes the caption of the toggle button when a user clicks the toggle button. The value is WithoutTentative. If a user clicks a toggle button with the caption WithTentative, the caption of the toggle button is replaced by WithoutTentative. |
TNT SHM Gantt AX Date Time Interval PopUp Business Component User Properties
This topic describes the following user properties for the TNT SHM Gantt AX Date Time Interval PopUp business component of the Function Space Diary:
Activation Field 1
This user property is used to specify the fields to be activated.
Value |
Go To |
Usage |
This user property is used to specify the fields to be activated. |
Value |
Day/Hour |
Usage |
This user property is used to specify the default time scale when the Function Space Diary is opened. |
Major Label Drilldown Name
This user property is used to specify the drill-down destination for the label of the major axis, for each time scale. Use this user property to specify whether drilldown is enabled or disabled in the major label for each of the time scales.
Value |
1;;2;Time Axis Item Drilldown;4;Time Axis Item Drilldown;8;Time Axis Item Drilldown;16;Time Axis Item Drilldown;32;64;;128;Time Axis Item Drilldown;256;Time Axis Item Drilldown |
Value |
1;;2;Time Axis Item Drilldown;4;Time Axis Item Drilldown;8;Time Axis Item Drilldown;16;Time Axis Item Drilldown;32; |
Value |
Usage |
This user property specifies whether drilldown is enabled or disabled in the major label for each of the time scales. This user property is also used to specify the drill-down destination for the label of the major axis, for each time scale. |
Minor Label Drilldown Name
Use this user property to specify whether drilldown is enabled or disabled in the minor label for each of the time scales. This user property is also used to specify the drill-down destination for the label of the minor axis, for each time scale.
Value |
1;Time Axis Item Drilldown;2;;4;;8;;16;;32;Time Axis Item Drilldown;64;Time Axis Item Drilldown;128;;256; |
Value |
1;Time Axis Item Drilldown;2;;4;;8;;16;;32;Time Axis Item Drilldown |
Value |
Usage |
This user property specifies whether drilldown is enabled or disabled in the minor label for each of the time scales. This user property is also used to specify the drill-down destination for the label of the minor axis, for each time scale. |
Minor Default Day Part Duration
This user property is used to set the default duration in minutes for day parts on the minor axis.
Value |
0;660;900;1080 |
Usage |
This user property is used to set the default duration in minutes for day parts on the minor axis. The day parts are Morning, Lunch, Afternoon, and Evening. |
Minor Default Day Part Labels
This user property is used to specify the default day part labels.
Value |
Morning;Lunch;Afternoon;Evening |
Usage |
This user property is used to specify the default day part labels. |
Time Part BC Minor
This user property is used to specify the time scale for which the day parts are displayed. Use this user property to retrieve the time part details for a property in the Function Space Diary.
Value |
2;TNT SHM Property Day Part Pricing |
Value |
2;TNT SHM Day Part Display |
Value |
Usage |
This user property is used to specify the time scale for which the day parts are displayed. This user property retrieves the time part details for a property and indicates whether or not to display the time part details on the appropriate time scale in the Function Space Diary. For instance, the default value of TNT SHM Gantt AX Date Time Interval PopUp VBC is represented as follows: 2 is the LIC for the time scale in the Function Space Diary, and TNT SHM Property Day Part Pricing is the business component from which to get the time part details for a property. |
Time Part BC Minor 2
Value |
64;TNT SHM Day Part Display |
Usage |
This user property is used to specify the time scale for which the day parts are displayed. Usage of this user property is the same as Time Part BC Minor. |
TNT CMT CI Property Field Name
This user property is used to specify the field that displays whether the property is a SFA (Sales Force Automation) property or a CI (Consolidated Inventory) property.
Value |
TNT CMT SFA CI Condition |
TNT SHM Gantt AX Date Time Interval PopUp VBC, Quote, SHM Site |
Usage |
This user property is used to specify the field that displays whether the property is a SFA (Sales Force Automation) property or a CI (Consolidated Inventory) property. |
User Properties for Sleeping Room Mapping
This topic describes the user properties supported for the Sleeping Room Mapping functionality of Siebel Hospitality. This topic covers the following subject:
Business Component User Properties for Sleeping Room Mapping
Activation BC
This user property is used in C++ code to activate some of the fields of the SHM Site business component during the administration of sleeping room mapping.
Value |
TNT Product - ISS Admin |
Usage |
The value of this user property is a business component name. This user property is used in C++ code to activate some of the fields in the SHM Site business component during the administration of sleeping room mapping. |
Activation Field 1
This user property is used in C++ code to activate a defined field of the SHM Site business component, which is configured in the Activation BC user property during the administration of sleeping room mapping.
Value |
TNT Capacity |
Usage |
Activation Field 2
Value |
Description |
Usage |
Activation Field 3
Value |
TNT CRS Code |
Usage |
Child BC
This user property is accessed in C++ code to specify the virtual child business component to be run at a specific view aspect that is set at the applet using the business component.
Value |
TNT Mapped Specific Room |
Usage |
TNT SHM Arrival Date Field
Use this user property to set the correct value of the Calculated Arrival Date field on a change of duration (that is, a change to the value of the Num Nights Duration field) or a change to the closed date (that is, a change to the value of the Hospitality Close Date field).
Value |
Calculated Arrival Date |
Opportunity Home Add Virtual business component |
Usage |
The value of this user property is a business component field. When the Num Nights Duration field or the Hospitality Close Date field is updated, a new value for the Calculated Arrival Date field is calculated and set by way of C++ code. |
TNT SHM Departure Date Field
Use this user property to set the correct value of the Calculated Arrival Date field on a change of duration (that is, a change to the value of the Num Nights Duration field) or a change to the arrival date (that is, a change to the value of the Calculated Arrival Date field).
Value |
Hospitality Close Date |
Usage |
The value of this user property is a business component field. When the Num Nights Duration field or the Calculated Arrival Date field is updated, a new value for the Hospitality Close Date field is calculated and set by way of C++ code. |
TNT SHM Number of Nights Field
Use this user property to set the correct value of the Num Nights Duration field on a change of arrival date (that is, a change to the value of the Calculated Arrival Date field) or a change to the closed date (that is, a change to the value of the Hospitality Close Date field).
Value |
Num Nights Duration |
Usage |
The value of this user property is a business component field. When the Calculated Arrival Date field or the Hospitality Close Date field is updated, a new value for the Num Nights Duration field is calculated and set by way of C++ code. |
View Name
This user property is accessed in C++ code to enable the specialized behavior of the business component that is defined in the Child BC user property.
Value |
TNT Generic Room Type Mapping View |
TNT Mapped Specific Room business component |
Usage |
This user property is accessed in C++ code to enable the specialized behavior of the business component that is defined in the Child BC user property. |
Integration Object User Properties for Sleeping Room Mapping
This topic describes the following integration object user property:
Date XMLTag Name
Use this user property to decide whether or not to create a quote from an opportunity for a property when the opportunity for a property does not have user-defined dates.
Value |
ListOfTNT SHM Property Dates |
TNT SHM Multiple Dates integration object |
Usage |
Varies depending on whether the user property is active or inactive, as follows:
User Properties for Menus and Packages
This topic describes the user properties supported for the Menus and Packages functionality of Siebel Hospitality. This topic covers the following subjects:
Applet User Properties for Menus and Packages
This topic describes the following applet user properties:
BC Field Search LHS
Use this user property with the Parent BC Constraint Field user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet. The search specification is formed according to the sequence of the BC Field Search LHS xx and Parent BC Constraint Field xx user properties, where xx indicates 0,1,2,3,…
Value |
Vendor Id = |
TNT Property Substitute Product Assoc Applet applet |
Usage |
Use this user property to format the search specification for the TNT PropÂerty Substitute Product Assoc Applet applet. This user property works with the Parent BC Constraint Field user property. This user property value acts as the LHS part of the search specification, and the value of the Parent BC Constraint Field user property acts as the RHS part of the search specificaÂtion. |
BC Field Search LHS 1
Use this user property with the Parent BC Constraint Field 1 user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet. The search specification is formed according to the sequence of the BC Field Search LHS xx and Parent BC Constraint Field xx user properties, where xx indicates 0,1,2,3,…
Value |
Type = |
Usage |
Use this user property to format the search specification for the TNT PropÂerty Substitute Product Assoc Applet applet. This user property works with the Parent BC Constraint Field 1 user property. This user property value acts as the LHS part of the search specification, and the value of the Parent BC Constraint Field 1 user property acts as the RHS part of the search specifiÂcation. |
BC Field Search LHS 2
Use this user property with the Parent BC Constraint Field 2 user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet. The search specification is formed according to the sequence of the BC Field Search LHS xx and Parent BC Constraint Field xx user properties, where xx indicates 0,1,2,3,…
Value |
Id <> |
Usage |
Use this user property to format the search specification for the TNT PropÂerty Substitute Product Assoc Applet applet. This user property works with the Parent BC Constraint Field 2 user property. This user property value acts as the LHS part of the search specification, and the value of the Parent BC Constraint Field 2 user property acts as the RHS part of the search specifiÂcation. |
CanInvokeMethod: CopyRecord
Use this user property to disable the Copy Record functionality in Menu Administration, Event Order Item Administration, and Package & Specific Space Administration.
The user property for the TNT SHM FSI Sleeping Room List Applet applet, which is enabled in the Oracle’s Siebel CRM base application (the functionality that is common to Oracle’s Siebel Business Applications that are not industry-specific), is disabled in Siebel Hospitality to resolve a visibility issue.
Value |
N |
TNT Property Product Admin List Applet, TNT Package Administration List Applet, TNT Menu Administration List Applet, and TNT SHM FSI Sleeping Room List Applet applets |
Usage |
Due to some technical constraints in Administration - Product, you must disable the Copy Record functionality in Menus and Packages-related adÂministration views in order to release a copied product. |
Double Click Applet Method
Use this user property to specify the method to call on a double-click event.
Value |
AddProducts |
TNT Menu Product Pick Applet applet, TNT Package Product Pick Applet apÂplet |
Usage |
When a user double-clicks one of the parent objects, the selected record is added to its originating or parent applet. The value of this user property is AddProducts, which is a custom method. If you do not use the double-click event, this user property can be deactivated. |
Effective Dates Constraint BC
Use this user property to constrain records in parent object applets by getting effective date details from the active business component.
This user property exists in the Siebel CRM base application. In Siebel Hospitality, the value Internal Product - ISS Admin is replaced with TNT Product - ISS Admin for Menus and Packages to resolve a visibility issue.
Value |
TNT SHM FSI Function Space Assoc List Applet and TNT SHM FSI Indivisible Space Assoc List Applet applets |
Usage |
Constrains records in parent object applets by getting effective date details from the active business component. |
Enter Key Method
Use this user property to specify the Quick Add functionality that operates when a user clicks the Enter button.
Value |
Search |
TNT Attribute Search Applet applet |
Usage |
Specifies the Quick Add functionality that operates when a user clicks the Enter button. |
Mode
Use this user property to display the pop-up applet in edit mode.
Value |
Edit |
TNT Check Spelling control in TNT Menu Administration List Applet, TNT Package Administration List Applet and TNT Property Product Admin List Applet applets |
Usage |
Specifies that when a user clicks the Check Spelling button, the pop-up ApÂplet is displayed in edit mode. |
Mode
Use this user property to display the pop-up applet in edit list mode.
Value |
Edit List |
AddItem control in TNT Menu Item List Applet, TNT Package Item List ApÂplet applet |
Usage |
Specifies that when a user clicks the Add Items button, the pop-up applet is displayed in edit list mode. |
Named Method: CreateMenuPackages
Use this user property to call the Show Popup method when a user chooses the Create Custom Menu/Package applet menu item.
Value |
'INVOKE', 'ShowPopup', '"TNT Custom Menu/Package Popup Applet"', 'Edit' |
TNT SHM Function Line Items List Applet - Function, TNT SHM Function Line Items List Applet, TNT SHM Order Line Item List Applet applets |
Usage |
Calls the Show Popup method when a user chooses the Create Custom Menu/Package applet menu item. |
Named Method: QuickAddItem
Use this user property to call the business service method when a user clicks the Quick Add button to add an entered item to the function line items.
Value |
"INVOKESVC", "TNT Utility Service", "QuickAdd" |
TNT Quote Catalog Quick Add Form Applet applet |
Usage |
Calls the business service method when a user clicks the Quick Add button to add an entered item to the function line items. |
Use this user property with the BC Field Search LHS user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet.
Value |
Vendor Id |
Usage |
See the usage of the BC Field Search LHS user property. |
Use this user property with the BC Field Search LHS 1 user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet.
Value |
Type |
Usage |
See the usage of the BC Field Search LHS 1 user property. |
Use this user property with the BC Field Search LHS 2 user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet.
Value |
Id |
Usage |
See the usage of the BC Field Search LHS 2 user property. |
Popup
Use this user property to specify the pop-up Applet to be displayed when a user clicks the Check Spelling button.
Value |
Spell Checker Popup Applet |
Usage |
Specifies the pop-up Applet to be displayed when a user clicks the Check Spelling button. |
Popup
Use this user property to specify the popup applet that is displayed when a user clicks the Add Items button.
Value |
TNT Menu Product Pick Applet |
AddRecord control in TNT Menu Item List Applet applet |
Usage |
Specifies the popup applet that is displayed when a user clicks the Add Items button. |
Popup
Value |
TNT Package Product Pick Applet |
AddRecord control in TNT Package Item List Applet applet |
Usage |
Popup Dimension
Use this user property to specify the dimensions of the pop-up applet that is displayed when a user clicks the Check Spelling button.
Value |
400 X 550 |
Usage |
Specifies the dimensions of the pop-up applet that is displayed when a user clicks the Check Spelling button. |
Popup Dimension
Use this user property to specify the dimensions of the pop-up applet that is displayed when a user clicks the Add Items button.
Value |
500 X 600 |
AddRecord control in TNT Menu Item List Applet, TNT Package Item List ApÂplet applets |
Usage |
Specifies the dimensions of the pop-up applet that is displayed when a user clicks the Add Items button. |
Product Search Fields
Use this user property to specify the Product fields in which a user can search using the Quick Add view.
Value |
Name, Product Type, TNT Display Name, TNT Unit of Measure, Part #, SHM Sub Category, Grouping Code, SHM Category, TNT Report Header, SHM Parent Category |
Usage |
Specifies the Product fields on which a search can be done in the Quick Add view. |
Search Spec Condition BC
Use this user property to constrain records in parent object applets by applying a formed search specification to the active business component.
This user property exists in the Siebel CRM base application. In Siebel Hospitality, the value Internal Product - ISS Admin is replaced by TNT Product - ISS Admin for Menus And Packages to resolve a visibility issue.
Value |
TNT SHM FSI Function Space Assoc List Applet applet |
Usage |
Constrains records in parent object applets by applying a formed search specification to the active business component. |
Business Component User Properties for Menus and Packages
AddToCart Proxy Buscomp2
Use this user property to get the business component instance in C++ code to evaluate defined search criteria and search for items.
Value |
Internal Product Popup |
Quick Add business component |
Usage |
The value of this user property is business component. This user property gets the business component instance in C++ code to evaluate defined search criteria, search items, and add the selected items to the function line items. |
Aspect Default Value: Menu
Use this user property to set the default Menu Per Person value for the Type field, if the TNT Product - ISS Admin business component is driven by the TNT Menu Administration List Applet applet.
Value |
LookupValue ("PRODUCT_TYPE", "Menu Per Person") |
Type Field in TNT Product - ISS Admin business component |
Usage |
The TNT Menu Administration List Applet applet has the Default Aspect user property and a value of Menu. If the TNT Product - ISS Admin business component is driven by the TNT Property Product Admin List Applet applet, the lookup value of Menu Per Person is set to the Type field as the default value. |
Use this user property to set the default value of Person to the Unit of Measure field, if the TNT Product - ISS Admin business component is driven by the TNT Menu Administration List Applet applet.
Value |
LookupValue ("UNIT_OF_MEASURE", "Person") |
Unit of Measure Field in TNT Product - ISS Admin business component |
Usage |
The applet TNT Menu Administration List Applet has the Default Aspect user property and a value of Menu. If the TNT Product - ISS Admin business component is driven by the TNT Menu Administration List Applet applet, the lookup value of the Unit of Measure field is set to Person as the default valÂue. |
Aspect Default Value: MenuEventItem
Use this user property to set the default current date C value for the Start Date field, if the TNT Product - ISS Admin business component is driven by the TNT Property Product Admin List Applet applet.
Value |
Today() |
Start Date Field in TNT Product - ISS Admin business component |
Usage |
The TNT Property Product Admin List Applet applet has the Default Aspect user property and a value of MenuEventItem. If the TNT Product - ISS AdÂmin business component is driven by the TNT Property Product Admin List Applet applet, the current date is set to Type as the default value. |
Aspect Default Value: Package
Use this user property to set the default value of the Start Date field to the current date, if the TNT Product - ISS Admin business component is driven by the TNT Package Administration List Applet applet.
Value |
Today() |
Usage |
The TNT Package Administration List Applet applet has the Default Aspect user property and a value of Package. If the TNT Product - ISS Admin busiÂness component is driven by the TNT Property Product Admin List Applet applet, the default value of Type is set to the current date. |
Use this user property to set the default value of the Unit of Measure field to Person, if the TNT Product - ISS Admin business component is driven by the TNT Package Administration List Applet applet.
Value |
Usage |
The TNT Package Administration List Applet applet has the user property Default Aspect and a value of Package. If the TNT Product - ISS Admin busiÂness component is driven by the TNT Menu Administration List Applet apÂplet, the default value of the Unit of Measure field is set to Person. |
CanInvokeCustomMethod 1
Use this user property to enable or disable the Validate Allocation method.
Value |
"ValidateAlloc", "IsIdNotNull" |
TNT SHM Quote Item, TNT SHM Invoice Order Item, TNT SHM Order Item business components |
Usage |
Enables or disables the Validate Allocation method. The first part of the value indicates the method name, and the second part of the value indicates a condition for enabling or disabling. By default, the condition indicates that a record must exist. This user property is applicable only for those business components that are based on the CSSBCSHMQuoteItem class. |
CanInvokeCustomMethod 2
Use this user property to enable or disable the UseSysAlloc method.
Value |
"UseSysAlloc", "TNT Use Sys Alloc Call Flag" |
Usage |
Enables or disables the UseSysAlloc method. The first part of the value indicates the method name, and the second part of the value indicates a condition for enabling or disabling. The value of the TNT Use Sys Alloc Call Flag field determines if the UseSysAlloc method is enabled or disabled for users. This user property is applicable only for those business components that are based on the CSSBCSHMQuoteItem class; and the condition part must return either Y, y, N, or n. |
Deep Copy
Use this user property to copy the child items in the menu or package when the parent menu or package is copied.
Value |
TNT SHM Order Item |
TNT SHM Order Item business component |
Usage |
Copies the child items in the menu or package when the parent menu or package is copied. |
Deep Copy
Value |
TNT SHM Quote Item |
TNT SHM Quote Item business component |
Usage |
Deep Copy
Value |
TNT SHM Invoice Order Item |
TNT SHM Invoice Order Item business component |
Usage |
Field Name: IsExtendedQuantity
Use this user property to pass the field name to the C++ code.
Value |
IsExtendedQuantity |
Usage |
Passes the field name to the C++ code. |
Field Name: IsMenuPackageType
Value |
TNT Extended Revenue Estimate Line Total - Display |
Usage |
Field Name: TNT TaxRequired Flag
Value |
TNT TaxRequired Flag |
TNT SHM Quote Item, TNT SHM Invoice Order Item, TNT SHM Order Item, TNT SHM Order Item Copy business components |
Usage |
Field Name: TNT TopLevelParentFlag
Value |
TNT TopLevelParentFlag |
Usage |
Field Name: TNT TopLevelParentPIP
Value |
TNT TopLevelParentPIP |
Usage |
Field Read Only Field: Product
Use this user property to evaluate some conditions to make the Product field read only.
Value |
TNT Product Read Only Flag |
Usage |
For a description of the usage of this user property, see the chapter on user properties in Siebel Developer's Reference. This user property is in the Oracle’s Siebel CRM base application and is modified with more conditions for the Menus and Packages feature. |
IsParentMPTypeField
Use this user property to specify the field name to determine if the parent line item is a Menu or Package Type.
Value |
IsParentOrderItemMPType |
TNT SHM Order Item, TNT SHM Invoice Order Item business components |
Usage |
A field name of the business component is passed as the value of this user property. This user property is used in C++ code to verify whether or not the function line item is a child item of a parent menu or package. |
Line Items BC Name: Quote
Use this user property to get the appropriate business component instance in C++ code to create custom menus or packages in quote line items.
Value |
TNT Custom Menu, Package VBC business component |
Usage |
Creating custom menus and packages is handled through C++ code, and it requires the appropriate business component to be retrieved. This user property is created with the business object. If the active business object is TNT SHM Quote, then the TNT SHM Quote Item business component instance is created in C++ code to create custom menus and packages. |
Line Items BC Name: TNT Function Line Item Quick Entry View
Use this user property to retrieve the business component instance in C++ code while adding items to the function line items, using the Quick Add applet.
Value |
Internal Product Popup, Quick Add business components |
Usage |
Retrieves the business component instance in C++ code while adding items to the function line items, using the Quick Add applet. The second part of the user property name designates the view context. If the active view is the TNT Function Line Item Quick Entry View view, then the TNT SHM Quote Item business component instance adds the items to the function line items. |
Line Items BC Name: TNT SHM Function
Use this user property to get the appropriate business component instance in C++ code to create custom menus or packages in function line items.
Value |
TNT SHM Function Item |
TNT Custom Menu/Package VBC business component |
Usage |
Creating custom menus and packages is handled through C++ code, and it requires the appropriate business component to be retrieved. This user property is created with the business object. If the active business object is TNT SHM Function, then the TNT SHM Function Item business component instance is created in C++ code to create custom menus and packages. |
Line Items BC Name: TNT SHM Order Entry
Use this user property to get the appropriate business component instance in VBC code.
Value |
Usage |
Creating custom menus and packages is handled through C++ code, and it requires the appropriate business component to be retrieved. This user property is created with the business object. If the active business object is TNT SHM Order Entry, then the TNT SHM Order Entry Item business component instance is created in C++ code to create custom menus and packages. |
Line Items BC Name: TNT SHM Order Function Line Items View
Value |
Usage |
Retrieves the business component instance in C++ code while adding items to the function line items, using the Quick Add applet. The second part of the user property name designates the view context. If the active view is the TNT SHM Order Function Line Items view, then the TNT SHM Order Item business component instance adds the items to the function line items. |
Line Items BC Name: TNT SHM Quote Function Line Items View
Value |
Usage |
Retrieves the business component instance in C++ code while adding items to the function line items, using the Quick Add applet. The second part of the user property name designates the view context. If the active view is the TNT SHM Quote Function Line Items view, then the TNT SHM Quote Item business component instance adds the items to the function line items. |
Line Items BO Name: Quote
Use this user property to define a business object name to make technical decisions in C++ code.
Value |
Quote |
Usage |
Defines the business object name to make technical decisions in C++ code. This user property is active only if the business component is associated with the defined business object. |
Line Items BO Name: SHM Invoice
Use this user property to define the business object name to make technical decisions in C++ code.
Value |
SHM Invoice |
Usage |
Line Items BO Name: TNT SHM Function
Value |
TNT SHM Function |
Usage |
Line Items BO Name: TNT SHM Order Entry
Value |
TNT SHM Order Entry |
Usage |
Line Items BO Name: TNT SHM Templates
Value |
TNT SHM Templates |
Usage |
Menu Item Field Map 1
Use this user property to carry over the value from Menu Item administration to the function line item when a menu is added to the function line items.
Value |
"TNT Split Qty Flag", "Split Price Flag" |
Usage |
Carries over the value from Menu Item administration to the function line item when a menu is added to the function line items. In this case, TNT Split Qty Flag is a field in the parent object and Split Price Flag is a field in the TNT Menu Item business component. When a menu is added to the function line items, the child menu items are added along with the parent menu. The value of the Split Price Flag field of the TNT Menu Item business component is copied into the TNT Split Qty Flag field of the parent business component.
Note: For examples, refer to the Menu Item Field Map x (where
x is equal to 1,2,3…) user properties in the same parent object.
Named Method
Use this user property to call a business service method when a user clicks the Add button to add line items through the Search Add applet.
Value |
"AddToList", "INVOKESVC", "Internal Product Popup", "TNT Utility Service", "ListAdd" |
Internal Product Popup business component |
Usage |
Calls a business service method when a user clicks the Add button to add line items through the Search Add applet. |
Named Method 1
Use this user property to set the Per Person Allocation field to an empty string when the UpdateItemsPPA custom method is called.
Value |
"UpdateItemsPPA", "SET", "Per Person Allocation", """" |
TNT Package Item business component |
Usage |
For a package item, the Per Person Allocation field must be empty if the parent package is of the Package Item Price type. If the parent package type is modified to Package Item Price, the UpdateItemsPPA custom methÂod is called by the UpdatePPA method from the TNT Product - ISS Admin parent business component. |
Named Method 4
Use this user property to set an empty value to the Per Person Allocation parent business component in package items.
Value |
"UpdatePPA", "INVOKEALL", "TNT Package Item", "UpdateItemsPPA" |
Usage |
For a package item, Per Person Allocation must be empty if the parent Package is of the Package Item Price type. This user property works with the On Field Update Invoke user property. If the Package type is modified to Package Item Price, the UpdatePPA custom method is called, and the call delegates to the UpdateItemsPPA method of the TNT Package Item busiÂness component. |
Named Method 7
Use this user property to refresh the business component when the SetParentSplitFlag method is called.
Value |
"SetParentSplitFlag", "INVOKE", "TNT SHM Invoice Order Item", "RefreshBusComp" |
Usage |
Refreshes the business component when the TNT Split Qty Flag field is updated for a child menu item, so as to set the appropriate value of Split Menu Flag for the parent menu. This user property works with the On Field Update Invoke user property. |
Named Method 8
Use this user property to call an internal service method to set the split flag value for the parent menu when the TNT Split Qty Flag field is updated for a child menu item.
Value |
"SetParentSplitFlag", "INVOKEALL", "TNT SHM Invoice Order Item", "SetSplitValue" |
Usage |
Calls an internal service method to set the appropriate value to the Split Menu Flag field for the parent menu when the TNT Split Qty Flag field is updated for a child menu item. This user property works with the On Field Update Invoke user property. |
Named Method 8
Use this user property with the On Field Update Invoke 10, On Field Update Invoke 11, and On Field Update Invoke 12 user properties to update the value of the Quantity Requested field in the child business components.
Value |
"UQItemQty", "INVOKEALL", "TNT SHM Quote Item", "UpdateFields" |
TNT SHM Function business component |
Usage |
Updates the value of the Quantity Requested field in the child business components. This user property works with the On Field Update Invoke 10, On Field Update Invoke 11, and On Field Update Invoke 12 user properties. |
Named Method 9
Use this user property to set the split flag value for a parent menu when the TNT Split Qty Flag field is updated for a child menu item.
Value |
"SetSplitValue", "INVOKESVC", "TNT SHM Invoice Order Item", "TNT Utility Service", "SetSplitPriceFlag" |
Usage |
Sets the value of the TNT Split Qty Flag field for the parent menu. This user property works with the Named Method 8 user property. |
Named Method 10
Use this user property with the On Field Update Invoke 13, On Field Update Invoke 14, and On Field Update Invoke 15 user properties to update the value of the Quantity Requested field in the child business components.
Value |
"UOItemQty", "INVOKEALL", "TNT SHM Order Item", "UpdateField" |
Usage |
Updates the value of the Quantity Requested field in the child business components. This user property works with the On Field Update Invoke 13, On Field Update Invoke 14, and On Field Update Invoke 15 user properties. |
Named Method 11
Use this user property to call the service method to validate the package price with the cumulative allocation of the child line items of the package.
Value |
"ValidateAlloc", "INVOKESVC", "TNT SHM Quote Item", "TNT Utility Service", "Validate Allocation Price" |
Usage |
Calls the service method to validate the package price with the cumulative allocation of the child line items of the package.
Named Method 13
Use this user property to call the service method to set the system allocation to the child line items of the appropriate package.
Value |
"UseSysAlloc", "INVOKESVC", "TNT SHM Quote Item", "TNT Utility Service", "Set System Allocation" |
Usage |
Calls the service method to set the system allocation to the child line items of the appropriate package. |
Named Method 14
Use this user property to call a service method to set the system allocation for the child line items of the appropriate package.
Value |
"UseSysAlloc", "INVOKESVC", "TNT SHM Invoice Order Item", "TNT Utility Service", "Set System Allocation" |
Usage |
Calls a service method to set the system allocation for the child line items of the appropriate package. This user property works with the On Field Update Invoke 1 user property and the Applet menu method item. |
Named Method 15
Use this user property to update the Quantity if Guaranteed/Projected/Expected Num changes in the Parent BC TNT SHM Function.
Value |
"UpdateFields", "SET", "Quantity Requested", [QuantityCalc] |
Usage |
Updates the Quantity of TNT SHM Quote Item if Guaranteed/Projected/Expected Num changes in the parent business component TNT SHM Function. |
Named Method 15
Value |
"ValidateAlloc", "INVOKESVC", "TNT SHM Invoice Order Item", "TNT Utility Service", "Validate Allocation Price" |
Usage |
Named Method 16
Value |
"SetParentSplitFlag", "INVOKE", "TNT SHM Quote Item", "RefreshBusComp" |
Usage |
Calls an internal service method to set the appropriate value for the Split Menu Flag of the parent menu, when the TNT Split Qty Flag field of an associated child menu item is updated. This user property works with the On Field Update Invoke user property. |
Named Method 17
Value |
"UpdateField", "SET", "Quantity Requested", [QuantityCalc] |
Parent Object Type |
Usage |
Updates the Quantity of TNT SHM Order Item if Guaranteed/Projected/Expected Num changes in the parent business component TNT SHM Function. |
Named Method 17
Use this user property to call an internal service method to set the Split flag value for parent menu when TNT Split Qty Flag field of an associated child Menu Item is updated.
Value |
"SetParentSplitFlag", "INVOKEALL", "TNT SHM Quote Item", "SetSplitValue" |
Usage |
Named Method 18
Value |
"ValidateAlloc", "INVOKESVC", "TNT SHM Order Item", "TNT Utility Service", "Validate Allocation Price" |
Usage |
Named Method 19
Value |
"UseSysAlloc", "INVOKESVC", "TNT SHM Order Item", "TNT Utility Service", "Set System Allocation" |
Usage |
Named Method 21
Value |
"SetParentSplitFlag", "INVOKE", "TNT SHM Order Item", "RefreshBusComp" |
Usage |
Named Method 22
Use this user property to call an internal service method to set the Split flag value for the parent menu when TNT Split Qty Flag field of an associated child Menu Item is updated.
Value |
"SetParentSplitFlag", "INVOKEALL", "TNT SHM Order Item", "SetSplitValue" |
Usage |
Use this user property to call the named methods to mark or unmark the split price for a parent menu when the split flag value of the child menu items changes.
Value |
"TNT Split Qty Flag", "TNT SHM Invoice Order Item", "SetParentSplitFlag", "IIf([Type Calc]=""Menu Item"", ""Y"", ""N"")" |
Usage |
Sets the value of the TNT Split Qty Flag field for the parent menu in function line items when the split flag value of the child menu items changes; that is, when the value of the TNT Split Qty Flag field changes. This user property works with the Named Method 8 user property. |
Use this user property to call the named methods to select or clear the Split Price field for a parent menu when the value of the TNT Split Qty Flag of an associated child menu item changes.
Value |
"TNT Split Qty Flag", "TNT SHM Quote Item", "SetParentSplitFlag", "IIf([Type Calc]=""Menu Item"", ""Y"", ""N"")" |
Usage |
Sets the TNT Split Qty Flag for the parent menu in a function line item when the TNT Split Qty Flag value of an associated child menu item changes. This user property works with the Named Method 8 user property. |
Value |
"TNT Split Qty Flag", "TNT SHM Order Item", "SetParentSplitFlag", "IIf([Type Calc]=""Menu Item"", ""Y"", ""N"")" |
Usage |
Use this user property to clear the System Allocation Flag of the parent package when a split menu or a package of the Package Item Price type is added to the package items.
Value |
"Type", "TNT Product - ISS Admin", "UpdateSysFlag", "IIf([Type Calc] = ""Package Item Price"" OR ([Type Calc] = ""Menu Per Person"" AND [Split Menu Item Flag] =""Y""), ""Y"", ""N"")" |
Usage |
For a package, the System Allocation Flag must be set to False if the packÂage items include either a split menu or a package of the Package Item Price type. When a split menu or a package of the Package Item Price type is associated with a parent package, the UpdateSysFlag custom method of the TNT Product - ISS Admin parent business component is called to clear the System Allocation Flag, if it is selected. |
Use this user property to delegate the call to the TNT Package Items child business component to set the value of Per Person Allocation to empty, if the package type is Package Item Price.
Value |
"Type", "TNT Product - ISS Admin", "UpdatePPA", "IIf([TNT Type LIC] = ""Package Item Price"", ""Y"", ""N"")" |
Usage |
Delegates the call to the TNT Package Items child business component to set the value of Per Person Allocation to empty, if the package type is PackÂage Item Price. |
Value |
"TNT Use System Alloc Flag", "TNT SHM Invoice Order Item", "UseSysAlloc", "IIf([TNT Use System Alloc Flag], ""Y"", ""N"")" |
Usage |
Calls the System Allocation service method, if the value of the TNT Use System Alloc Flag field changes. |
Use this user property to call the service method to set the system allocation to the child line items of the appropriate package, if the TNT Use System Allocation field of the parent or root package is set to True.
Value |
"TNT Use System Alloc Flag", "TNT SHM Order Item", "UseSysAlloc", "IIf([TNT Use System Alloc Flag], ""Y"", ""N"")" |
Usage |
Calls the service method to set the system allocation to the child line items of the appropriate package, if the TNT Use System Allocation field of the parent or root package is set to True. |
Value |
Usage |
Use this user property to update the value of the Quantity Requested field in the child business component, if the value of the Guaranteed Num field changes.
Value |
"Guaranteed Num", "TNT SHM Function", "UQItemQty", "IIf([TNT Is Quote Item BC] = ""Y"", ""Y"", ""N"")" |
Usage |
Updates the value of the Quantity Requested field in the child business component, if the value of the Guaranteed Num field changes. |
Use this user property to update the value of the Quantity Requested field in the child business component, if the value of the Projected Num field changes.
Value |
"Projected Num", "TNT SHM Function", "UQItemQty", "IIf(([Guaranteed Num] IS NULL AND [TNT Is Quote Item BC] = ""Y""), ""Y"", ""N"")" |
Usage |
Updates the value of the Quantity Requested field in the child business component, if the value of the Projected Num field changes. |
Use this user property to update the value of the Quantity field in the child business component, if the value of the Expected Num field changes.
Value |
"Expected Num", "TNT SHM Function", "UQItemQty", "IIf(([Guaranteed Num] IS NULL AND [Projected Num] IS NULL AND [TNT Is Quote Item BC] = ""Y""), ""Y"", ""N"")" |
Usage |
Updates the value of the Quantity field in the child business component, if the value of the Expected Num field changes. |
Value |
"TNT Use System Allocation", "TNT SHM Quote Item", "UseSysAlloc", "IIf([TNT Use System Allocation], ""Y"", ""N"")" |
Usage |
Use this user property to update the value of the Quantity field in the child business component, if the value of the Guaranteed Num field changes.
Value |
"Guaranteed Num", "TNT SHM Function", "UOItemQty", "IIf([TNT Is Order Item BC] = ""Y"", ""Y"", ""N"")" |
Usage |
Updates the value of the Quantity field in the child business component, if the value of the Guaranteed Num field changes. |
Value |
"Projected Num", "TNT SHM Function", "UOItemQty", "IIf(([Guaranteed Num] IS NULL AND [TNT Is Order Item BC] = ""Y""), ""Y"", ""N"")" |
Usage |
Value |
"Expected Num", "TNT SHM Function", "UOItemQty", "IIf(([Guaranteed Num] IS NULL AND [Projected Num] IS NULL AND [TNT Is Order Item BC] = ""Y""), ""Y"", ""N"")" |
Usage |
On Field Update Set 10
Use this user property to reinitialize the Grouping Code field value, if the product type is modified.
Value |
"Type", "Grouping Code", "", "[TNT EMMenuPkg View Flag] =Y" |
Usage |
The Grouping Code can be different for each product. This user property reinitializes the Grouping Code, if any, when a product type is modified. |
On Field Update Set 11
Use this user property to set the default value of the Unit Of Measure field. The product type determines the default value.
Value |
"Type", "Unit of Measure", "IIF ([Calculated Type] = ""Package Each"" or [Calculated Type] = ""Package Item Price"", LookupValÂue(""UNIT_OF_MEASURE"",""Each""), IIF([Calculated Type] = ""Package Per Person"", LookupValue(""UNIT_OF_MEASURE"",""Person""), [Unit of Measure]))" |
Usage |
Sets the default value of the Unit Of Measure field. |
On Field Update Set 47
Use this user property to check that at any time either the Discount Amount field or the Discount Percentage field has a value, but not both fields.
Value |
"Discount Amount", "Discount Percent", "IIf ([Discount Amount] IS NOT NULL, """", [Discount Percent])" |
Usage |
Checks that at any time either the Discount Amount field or the Discount Percentage field has a value, but not both fields. |
On Field Update Set 48
Value |
"Discount Percent", "Discount Amount", "IIf ([Discount Percent] IS NOT NULL, """", [Discount Amount])" |
Usage |
Package Item Field Map 3
Use this user property to carry over the value from Package Item administration to the function line item when a package is added to the function line items.
Value |
"Quantity Requested", "Quantity" |
Usage |
Carries over the value from Package Item administration to the function line item when a package is added to the function line items. In this case, Quantity Requested is a field in the parent object, and Quantity is a field in the TNT Package Item business component. When a package is added to the function line items, the child package items are added along with the parent package. The value of the Split Price Flag field of the TNT Package Item business component is copied into the TNT Split Qty Flag field of the parent business component.
Note: For examples, refer to the Package Item Field Map x (where
Parent Item Product Type
Use this user property to get the Parent Item Product type. This user property is used in C++ code.
Value |
Parent Order Item Product Type |
Usage |
Gets the Parent Item Product type. Used in C++ code. |
Value |
Parent Product Type |
Usage |
Parent Pick Field
The value of this user property is a business component field. Use this user property to get the picklist for the defined value and add the item to the function line items, using the Quick Add applet. This user property is used in C++ code.
Value |
Product |
Usage |
The Quick Add applet is the child of the Function Line Items applet. The value of this user property is the parent business components field. This user property is used in C++ code to get the picklist for the defined value and add the item to the function line items through the picklist. |
Parent Product Type
Value |
Usage |
Parent Product Type
Value |
Parent Quote Item Product Type |
TNT SHM Quote Item business components |
Usage |
Pick List SearchSpec:MenuEventItem
Use this user property to set the search specification for the static picklist in the Type field, if the TNT Product - ISS Admin business component is driven by the TNT Property Product Admin List Applet applet.
Value |
[Order By] = 201 OR [Order By] = 202 |
Usage |
The TNT Property Product Admin List Applet applet has the Default Aspect user property and a value of MenuEventItem. If the TNT Product - ISS AdÂmin business component is driven by the TNT Property Product Admin List Applet applet, the search specification for the static picklist in the Type field is formed by the MenuEventItem value. |
Pick List SearchSpec:Package
Use this user property to set the search specification for the static picklist of the Type field, if the TNT Product - ISS Admin business component is driven by the TNT Package Administration List Applet applet.
Value |
[Order By] = 204 OR [Order By] = 205 OR [Order By] = 206 |
Usage |
The TNT Package Administration List Applet applet has the Default Aspect user property and a value of Package. If the TNT Product - ISS Admin busiÂness component is driven by the TNT Package Administration List Applet applet, the search specification of the static picklist of the Type field is formed by the Package value. |
Prefix For Custom Product
Use this user property to define the prefix for the custom-created menus and packages in function line items.
Value |
Product Prefix |
Usage |
A menu or package does not have to be predefined in the product list. A menu or package can also be created at run time. The products listed in the table in this topic are provided with Siebel Hospitality as seed data. If a user renames items in the seed data, for example, WRITE-IN Menus Per Person instead of Write-in Menu Per Person, then the value of the Product Prefix calculated field must be modified accordingly.
Note: Optionally, you can define a Display Name for each product with any value. The Product Name and Product Type
must be the same for all the seed products as defined in the following table.
Table Seed Data Products
| Product Name | Product Type |
Write-in Menu Per Person |
Menu Per Person |
Write-in Menu Item |
Menu Item |
Write-in Package Per Person |
Write-in Package Each |
Package Each |
Write-in Package Item Price |
Write-in Event Order Item |
Event Order Item |
Product BC Name: TNT Function Line Item Quick Entry View
Use this user property to pass the Product business component name to the C++ code.
Value |
Usage |
Retrieves the business component instance in C++ code while adding items to the function line items through the Search Add applet. The second part of the user property name designates the view context. If the active view is the TNT Function Line Item Quick Entry view, then the Internal Product Popup business component instance evaluates defined search criteria and gets the items. |
Product BC Name: TNT SHM Order Function Line Items View
Use this user property to retrieve the business component instance in C++ code to evaluate search criteria and get the items while adding items to the function line items through the Search or Quick Add applet.
Value |
Usage |
Retrieves the business component instance in C++ code while adding items to the function line items through the Search Add applet. The second part of the user property name designates the view context. If the active view is the TNT SHM Order Function Line Items view, then the Internal Product Popup business component instance evaluates defined search criteria and gets the items. |
Product BC Name: TNT SHM Quote Function Line Items View
Value |
Usage |
Retrieves the business component instance in C++ code while adding items to the function line items through the Search Add applet. The second part of the user property name designates the view context. If the active view is the TNT SHM Quote Function Line Items view, then the Internal Product Popup business component instance evaluates defined search criteria and gets the items. |
Recursive Link
Use this user property to permanently delete the child items of a menu or package that is deleted from the function line items.
Value |
TNT SHM Invoice Order Item, TNT SHM Invoice Order Item - Deep |
Usage |
Permanently deletes the child items of a menu or package that is deleted from the function line items. |
Revenue Adjusted Price Field
Use this user property to pass the field name for revenue calculations.
Value |
TNT Extended Revenue Estimate Line Total Adjusted - Display |
Usage |
Passes the field name for revenue calculations. |
Template Copy Fields
Use this user property to specify the fields to be copied when a template is created using the Apply Template method.
Value |
Product Id, Quantity Requested, Service Start, Description, Note, Outline Number |
Usage |
Specifies the fields to be copied when a template is created using the Apply Template method. |
TNT Allocation Validation Diff
Use this user property to define the value of the difference that forms the basis for the validation between the unit net price of a parent package and the accumulated per person allocations of the child package items.
Value |
0.01 |
Usage |
Specifies the value of the difference that forms the basis for the validation between the unit net price of a parent package and the accumulated per person allocations of the child package items. |
TNT Extended Net Price Flag
Value |
TNT MP Extended Net Price Flag |
Usage |
TNT Item Price Field
Use this user property to get the price value of the line item, which is referenced during the distribution of a per person allocation in C++ code.
Value |
Item Price - Display |
Usage |
Gets the price value of the line item, which will be referenced during the distribution of a per person allocation in C++ code. |
TNT Manual Allocation Field
Use this user property to set the allocation for the defined field in the case of a per person allocation.
Value |
TNT Per Person Allocation |
Usage |
The value of this user property is a field, and the per person or system allocation value is set to this field. This user property is used in C++ code to set the appropriate allocation value for the child items of a package. |
TNT MPType Flag
Value |
IsMPType |
Usage |
TNT No Display Flag
Value |
TNT Guest No Price Flag |
Usage |
TNT SHM Line Item Total Field
Use this user property to pass the Line item Total field value to the C++ code for revenue estimate calculations.
Value |
Usage |
Passes the Line item Total field value to the C++ code for revenue estimate calculations. |
Value |
Usage |
User Properties for Histories and Futures
This topic describes the user properties supported for the Histories and Futures functionality of Siebel Hospitality. This topic covers the following subjects:
Applet User Properties for Histories and Futures Functionality
Apply Custom Visibility
Use this user property to apply customized visibility rules.
Value |
Y |
TNT History Opportunity List Applet applet |
Usage |
If this user property is set, then the visibility rules of the framework do not apply, but the customized visibility rules do apply. |
Default Aspect
Use this user property to define the Default Aspect property for an applet.
Value |
History |
Usage |
When the aspect is defined, the business component user properties function that is based on the aspect is defined. The Default Aspect is defined as History. |
Default Aspect
Value |
History |
TNT Opportunity History Assoc List Applet applet |
Usage |
Default Aspect
Value |
History |
TNT History Quote List Applet applet |
Usage |
Get Service Method
Use this user property to specify the service method to be called.
Value |
BuildVisibilitySearchSpec |
Usage |
If this user property is set, then the specified service method will be called to apply visibility in Histories and Futures. |
Get Service Name
Use this user property to specify the service to be called.
Value |
TNT Utility Service |
Usage |
If this user property is set, then the specified service will be called to apply visibility in Histories and Futures. |
Business Component User Properties for Historiesand Futures
This topic describes the following business component user properties:
Activation BC 1
Use this user property to activate the fields of the business component specified in the user property value.
Value |
TNT History Quote |
TNT History Opportunity business component |
Usage |
If this user property is available, then the fields of this business component are activated when the current view is not active. |
Activation BC 2
Value |
TNT History Functions |
Usage |
Activation BC 3
Value |
TNT History Room Blocks |
Usage |
Activation Fields
Use this user property to specify the fields to activate.
Values |
Name, Original Opportunity Name, Event Template Name, Account, Intermediary Account, Arrival Date, Departure Date, Opportunity Segment, Type, Locked Flag |
Usage |
If this user property is available, then the specified fields of the business component are activated when the current view is not active. |
Activation Fields
Use this user property to specify the fields to be activated.
Values |
Property Name, Property Type, Quote Number, Quote Name, Status, Arrival Date, Departure Date, Currency Code, Comments |
TNT History Quote business component |
Usage |
If this user property is available, then the specified fields of the business component will be activated when the current view is not active. |
Activation Fields
Values |
Start Date, Start Day, Function Name, # Actual, # Contracted, # Expected, # Guaranteed, Food Revenue, Beverage Revenue, Room Rental Revenue |
TNT History Functions business component |
Usage |
Activation Fields
Values |
Start Date, Start Day, Contracted, Blocked, 90 Day Pickup, 60 Day Pickup, 30 Day Pickup, Actual, Picked Up, Projected, Complimentary |
History Room Blocks business component |
Usage |
All Historical Opportunities
Use this user property to pass the name of the Historical Opportunity view that has All visibility.
Value |
TNT All Historical Opportunities View |
Usage |
If this user property is available, then apply All visibility. |
All Properties
Use this user property to pass the name of the Properties view that has All visibility.
Value |
TNT SHM All Property View |
Usage |
If this user property is available and the view is accessible, then apply All visibility. |
Apply Visibility Field
Use this user property to specify the field on which visibility is applied.
Value |
Property Id |
Usage |
If this user property is available, then this field determines the visibility application. |
Aspect BC ReadOnly: History
Use this user property to set the business component to read-only mode, if the value of the field specified in the user property is Y.
Value |
Calc Locked Flag |
Usage |
When Aspect is defined and the current aspect is Aspect, then the current record becomes read-only when the value of the specified field is Y. |
Value |
Calc Locked Flag |
Usage |
When Aspect is defined, and the current aspect is Aspect, then the current record becomes read-only when the value of Field Name is Y. |
Aspect Child BC ReadOnly: History
Value |
Calc Locked Flag |
Usage |
When Aspect is defined and the current aspect is Aspect, then the child business components of the current record become read-only when the value of the specified field is Y. |
Value |
Calc Locked Flag |
Usage |
When Aspect is defined, and the current aspect is Aspect, then the child business components of the current record become read-only when the value of Field Name is Y. |
Cluster BC
Use this user property to specify the business component name used in the Clusters view.
Value |
TNT SHM Cluster |
Usage |
If this user property is available, then while applying visibility, the cluster-related data configured for a specific logged-in user is retrieved from this business component. |
Cluster BO
Use this user property to specify the business object name used in the Clusters view.
Value |
TNT SHM Cluster |
Usage |
If this user property is available, then while applying visibility, the cluster-related data configured for a specific logged-in user is retrieved from the business component available in this business object. |
Clusters
Use this user property to pass the name of the Properties view that has Cluster visibility.
Value |
TNT SHM All Property by Cluster View |
Usage |
If this user property is available and the view is accessible, then apply Cluster visibility. |
Clusters Historical Opportunities
Use this user property to pass the name of the Historical Opportunity view that has Cluster visibility.
Value |
TNT My Cluster Historical Opportunities View |
Usage |
If this user property is available, then apply Cluster visibility. |
Deep Copy 1
Use this user property to copy the specified child business component when a user selects the Copy option.
Value |
Usage |
When this property is set when a user chooses Copy Record in the parent business component, the specified child business component is also copied. |
Deep Copy 2
Value |
Usage |
Deep Delete 1
Use this user property to delete the specified child business component when a user selects the Delete option.
Value |
Usage |
When this property is set when a user chooses Delete Record in the parent business component, the specified child business component is also deleted. |
Deep Delete 2
Value |
Usage |
Employee BC
Use this user property to specify the business component name used in the Administration - User screen, Employees and Users views.
Value |
Employee |
Usage |
If this user property is available, then while applying visibility, the employee-related data and user-related data of the logged-in user are retrieved from this business component. |
Employee BO
Use this user property to specify the business object name used in the Administration - User screen, Employees and Users views.
Value |
Employee |
Usage |
If this user property is available, then while applying visibility, the employee-related data and user-related data of the logged-in user are retrieved from the business component available in this business object. |
Event Template Id
Use this user property to set the Row Id of a template when working with templates.
Value |
Event Template Id |
Usage |
If this user property is available when an event template is applied to an opportunity, set the Template Id of Event Template to the business component field name. |
Field Read Only Field: Locked Flag
Use this user property to set only the specified field to read-only mode. The value of the user property determines if the specified field is set to read-only mode.
Value |
Calc Locked Flag Read Only |
Usage |
If this user property is set, then the field name after the colon (:) in the user property name is read only. The value of the user property determines if this field is read only. |
My Historical Opportunities
Use this user property to pass the name of the Historical Opportunity view that has My visibility.
Value |
TNT My Historical Opportunities View |
Usage |
If this user property is available, then apply My visibility. |
My Properties
Use this user property to pass the name of the Properties view that has My visibility.
Value |
TNT SHM My Property View |
Usage |
If this user property is available and the view is accessible, then apply My visibility. |
Use this user property to call the specified business component method when a field is updated.
Values |
History Opportunity Id, TNT Opportunity History Assoc, UpdateLinks |
TNT Opportunity History Assoc business component |
Usage |
When the History Opportunity Id field is updated, then the Update Links method of the business component is called. |
Parent Pick Field
Use this user property to set the Template Id to an opportunity field when applying an event template to an opportunity.
Value |
Name |
TNT SHM Opportunity Property business component |
Usage |
If this user property is available when an event template is applied to an opportunity, set the property from Event Template to the business component field name. |
Parent Pick Field
Use this user property to specify the name of the field that has an associated picklist.
Value |
Name |
Usage |
When creating or applying an event template, copies the name of the field with the associated picklist that includes all the details of the selected record, rather than copying all the fields. |
Property BC
Use this user property to specify the business component name used in the Property view.
Value |
SHM Site |
Usage |
If this user property is available, then while applying visibility, the property-related data configured for a specific logged-in user is retrieved from this business component. |
Skip Setup Style Initialization
Use this user property to skip the setup style initialization, which is the initialization that occurs when a control is loaded into your Siebel application, for the Function Space Diary.
Value |
Y |
TNT SHM FSI Room Relationships business component |
Usage |
Setup style initialization is necessary only the first time the Function Space Diary screen is loaded. Activating this user property avoids subsequent initializations. This user property is used in C++ code to improve performance when the Function Space Diary control is loaded into Siebel Hospitality. The default value is Y, which prevents the Function Space Diary control from being initialized when it is loaded into Siebel Hospitality. If the value is N, then the Function Space Diary control is initialized each time it is loaded into Siebel Hospitality. |
Use this user property to copy field values from a template when working with templates.
Value |
Property Id |
Usage |
If this user property is available when an event template is applied to an opportunity, set the Property Id from Event Template to the business component field name. |
Example |
TNT SHM Brand, TNT SHM City |
Use this user property to copy the specified field values from a template.
Value |
History Opportunity Id |
Usage |
If this user property is available, then the History Opportunity Id field is copied from the event template to the record to which the event template is applied. |
User Properties for Event Checks
This topic describes the user properties supported for the event checks functionality of Siebel Hospitality. This topic covers the following subjects:
Applet User Properties for Event Checks
Can Invoke Method: ConfirmVoidEventCheck
Use this user property to enable the Void Event Check button for only event checks with a specified Status field.
Value |
[Status] = LookupValue('PS_SUBCONTRACTOR_STATUS', 'Posted') |
SHM Invoice Form Applet and SHM Invoice List Applet applets |
Usage |
Enables the Void Event Check button for only event checks with a Status field of Posted. |
Can Invoke Method: CopyRecord
Use this user property to disable the Copy Record functionality for records in the line items applet.
Value |
[TNT Disable New Delete Flag] AND [Id] IS NOT NULL |
TNT SHM Function Line Items List Applet, TNT SHM Order Line Item List Applet, TNT SHM Event Check Line Item List Applet, and TNT SHM Event Check Order Line Item Form Applet applets |
Usage |
Disables the Copy Record functionality when no records appear in the line items applet. |
Can Invoke Method: DeleteRecord
Use this user property to disable the Delete Record functionality for records in the line items applet.
Value |
Usage |
Disables the Delete Record functionality when no records appear in the line items applet. |
Can Invoke Method: PostCheck
Use this user property to disable the Post Check button for only event checks with the specified Status fields.
Value |
[Status] <> LookupValue('PS_SUBCONTRACTOR_STATUS', 'Voided') AND [Status] <> LookupValue('PS_SUBCONTRACTOR_STATUS', 'Posted') |
Usage |
Disables the Post Check button for only event checks with a Status field of Posted or Voided. Such event checks are read only. |
Can Invoke Method: RecalculateInvoiceItemsAndTaxes
Use this user property to disable the Recalculate button for only event checks with the specified Status fields.
Value |
SHM Invoice Form Applet applet |
Usage |
Disables the Recalculate button for only event checks with a Status field of Posted or Voided. Such event checks are read only. |
Can Invoke Method: ShowPopup
Use this user property to disable the Post Day button for only event checks with the specified Status fields.
Value |
Usage |
Disables the Post Day button for only event checks with a Status field of Posted or Voided. Such event checks are read only. |
Can Invoke Method: VoidEventCheck
Use this user property to call the VoidEventCheck method for only event checks with a specified Status field.
Value |
Usage |
Calls the VoidEventCheck method for only event checks with a Status field of Posted. |
Disable Buscomp Hierarchy
Use this user property to disable the function hierarchy in the Functions List Applet of the Event Checks screen.
Value |
True |
TNT SHM Invoice Function List Applet applet |
Usage |
Disables the function hierarchy in the Functions List Applet of the Event Checks screen. |
OverridePopupVisibility
Use this user property to restrict the properties that appear in the dialog box that appears when users click the Open Day button and the Post Day button.
Value |
TNT Property Name, 5 |
SHM Check Date VBC Form Applet applet |
Usage |
Restricts the properties that appear in the dialog box that appears when users click the Open Day button and the Post Day button. |
View Aspect: SHM Invoice Detail View
Use this user property to set the event checks with the specified Status fields as read-only records.
Value |
TNT_EVENT_CHECK_STATUS |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the SHM Invoice Detail View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: SHM Invoice Detail View (Accounting)
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the SHM Invoice Detail View (Accounting) becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: SHM Invoice More Info View (Detail)
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the SHM Invoice More Info View (Detail) becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM All Across Organizations Invoice List View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM All Across Organizations Invoice List View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM All Invoices by Cluster View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM All Invoices by Cluster View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM All Invoices by Quote Property View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM All Invoices by Quote Property View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM Event Check Line Item Attribute View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM Event Check Line Item Attribute View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM Event Check Line Items More Info View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM Event Check Line Items More Info View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM Event Check Notes View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM Event Check Notes View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
Business Component User Properties for Event Checks
Aspect BC ReadOnly: TNT_EVENT_CHECK_STATUS
Use this user property to set the event checks with the specified Status fields as read-only records when those records are associated with the FS Invoice business component.
Value |
TNT Invoice Status Read Only View Flag |
FS Invoice business component |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records when those records are associated with the FS Invoice business component. |
Aspect Child BC ReadOnly: TNT_EVENT_CHECK_STATUS
Use this user property to set the event checks with the specified Status fields as read-only records when those records are associated with the FS Invoice child business component.
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records when those records are associated with the FS Invoice child business component. |
State Model
Use this user property to deactivate the state model.
Value |
Y |
Usage |
Deactivates the state model. |
Business Service User Properties for Event Checks
This topic describes the following business service user properties:
Async Workflow Call for Source Recalculate Invoice
Use this user property to asynchronously call the workflow that recalculates taxes and service charges when users divide event checks or move items between event checks.
Value |
Y |
SHM Invoice Process business service |
Usage |
Asynchronously calls the workflow that recalculates taxes and service charges when users divide event checks or move items between event checks. |
Recalculate Workflow Name
Use this user property to get the SHM Recalculate Invoice Items workflow instead of using hard code to get this workflow.
Value |
SHM Recalculate Invoice Items Workflow |
Usage |
Gets the SHM Recalculate Invoice Items workflow instead of using hard code to get this workflow. |
Order Item BC Name
Use this user property to get the TNT SHM Invoice Order Item business component instead of using hard code to get this business component.
Value |
Usage |
Gets the TNT SHM Invoice Order Item business component instead of using hard code to get this business component. |
User Properties for Banquet Event Order Report
This topic describes the user properties supported for the banquet event order report functionality of Oracle’s Siebel Hospitality. This topic covers the following subjects:
Applet User Properties for Banquet Event Order Reports
This topic describes the following applet user properties:
IsSearchSpecFldMVG
Use this user property to designate if the search specification field in the SearchSpecField user property is a MVG (Multi-Value Group) field.
Value |
N |
TNT SHM Report Section MVG Applet applet |
Usage |
Designates if the search specification field in the SearchSpecField user property is a MVG (Multi-Value Group) field. |
Named Method 1: DeleteRecord
Use this user property to recalculate the Split Qty Flag for the parent line item when a user deletes a child line item.
Value |
'INVOKE', 'DeleteRecord' |
Usage |
Recalculates the Split Qty Flag for the parent line item when a user deletes a child line item. This user property works with the Named Method 2: DeleteRecord user property. |
Value |
'INVOKE', 'SetParentSplitFlag' |
Usage |
Recalculates the Split Qty Flag for the parent line item when a user deletes a child line item. This user property works with the Named Method 1: DeleteRecord user property. |
SearchSpecField
Use this user property to prepare the search specification.
Value |
PS Property Id |
Usage |
Prepares the search specification. This user property is used in C++ code, and works with the IsSearchSpecFldMVG user property. |
Business Component User Properties for Banquet Event Order Reports
Copy Function Calculate Price: Quote
Use this user property to designate that the price must be calculated for line items when users copy a function.
Value |
Y |
Usage |
This user property is used in C++ code and created with the business object. If the active business object is Quote, then the price must be calculated for line items when users copy a function. |
Disable Hierarchy: SHM Invoice
This user property is used in C++ code to disable or enable the function hierarchy in the active business object when the Day number (#) field and Date field for the function change.
Value |
Y |
Usage |
This user property is used in C++ code to disable or enable the function hierarchy in the active business object when the Day number (#) field and Date field for the function change. |
Disable Hierarchy: TNT SHM Order Entry
Value |
Y |
Usage |
Field Read Only Field: Date
Use this user property to set the Date field for subfunctions to a read-only mode.
Value |
Is Sub Function Flag |
Usage |
Sets the Date field for subfunctions to a read-only mode. |
Field Read Only Field: Day#
Use this user property to set the Day number (#) field for subfunctions to a read-only mode.
Value |
Usage |
Sets the Day number (#) field for subfunctions to a read-only mode. |
Value |
DateReadOnlyFlag |
TNT SHM Agenda Functions business component |
Usage |
Field Read Only Field: Start Date
Use this user property to set the Start Date field for subfunctions to a read-only mode.
Value |
DateReadOnlyFlag |
Usage |
Sets the Start Date field for subfunctions to a read-only mode. |
IsSearchSpecFldMVG
Value |
N |
TNT SHM Property Report Section business component |
Usage |
Menu Item Field Map 7
Use this user property to copy the report header value for child items in product and property administration to quote line items.
Value |
"TNT Product Report Header Id", "Report Header Id" |
Usage |
Copies the report header value for child items in product and property administration to quote line items. |
Use this user property to copy the report header value for child items in product and property administration to order line items.
Value |
"TNT Report Section Id", "Report Header Id" |
Usage |
Copies the report header value for child items in product and property administration to order line items. |
Named Method 1
Use this user property to update the projected revenue for revenue estimates when the Projected, Expected, and Guaranteed fields for a function change.
Value |
"Update Revenue", "INVOKE", "TNT SHM Quote Function Revenue Estimates", "ExpandAll" |
TNT SHM Quote Function Revenue Estimates business component |
Usage |
Updates the projected revenue for revenue estimates when the Projected, Expected, and Guaranteed fields for a function change. This user property works with the Named Method 2 and Named Method 3 user properties. |
Named Method 2
Value |
"Update Revenue", "INVOKEALL", "TNT SHM Quote Function Revenue Estimates", "Set Revenue" |
Usage |
Updates the projected revenue for revenue estimates when the Projected, Expected, and Guaranteed fields for a function change. This user property works with the Named Method 1 and Named Method 3 user properties. |
Named Method 3
Value |
"Set Revenue", "SET", "Projected Revenue - Function", "[Projected Revenue Per Person] * [Parent Attendees Calc]" |
Usage |
Updates the projected revenue for revenue estimates when the Projected, Expected, and Guaranteed fields for a function change. This user property works with the Named Method 1 and Named Method 2 user properties. |
Named Method 3
Use this user property to update the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change.
Value |
"Update Sub Function", "INVOKESVC", "TNT SHM Agenda Functions", "TNT SHM Day Number", "UpdateSubFunction" |
Usage |
Updates the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change. This user property works with the On Field Update Invoke 1 user property. |
Named Method 11
Value |
"Update Sub Function", "INVOKESVC", "TNT SHM Function", "TNT SHM Day Number", "UpdateSubFunction" |
Usage |
Updates the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change. This user property works with the On Field Update Invoke 19 user property. |
Value |
"Day #", "TNT SHM Agenda Functions", "Update Sub Function", "[Child Function Id] IS NOT NULL" |
Usage |
Updates the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change. This user property works with the Named Method 3 user property. |
On Field Update Invoke 16
Use this user property to update the projected revenue for revenue estimates when the Projected field for a function changes.
Value |
"Projected Num", "TNT SHM Quote Function Revenue Estimates", "Update Revenue", "[Guaranteed Num] IS NULL" |
Usage |
Updates the projected revenue for revenue estimates when the Projected field for a function changes. |
On Field Update Invoke 17
Use this user property to update the projected revenue for revenue estimates when the Guaranteed field for a function changes.
Value |
"Guaranteed Num", "TNT SHM Quote Function Revenue Estimates", "Update Revenue" |
Usage |
Updates the projected revenue for revenue estimates when the Guaranteed field for a function changes. |
On Field Update Invoke 18
Use this user property to update the projected revenue for revenue estimates when the Expected field for a function changes.
Value |
"Expected Num", "TNT SHM Quote Function Revenue Estimates", "Update Revenue", "[Guaranteed Num] IS NULL AND [Projected Num] IS NULL" |
Usage |
Updates the projected revenue for revenue estimates when the Expected field for a function changes. |
Value |
"Day#", "TNT SHM Function", "Update Sub Function", "[Child Function Id] IS NOT NULL" |
Usage |
Updates the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change. This user property works with the Named Method 11 user property. |
On Field Update Set
Use this user property to capture in the Revision Time field the date and time that the track changes flag changes.
Value |
"Track Changes Flag", "Revision Time", "IIf ([Track Changes Flag]= 'Y', Timestamp(), '')" |
Order Entry - Orders business component |
Usage |
Captures in the Revision Time field the date and time that the track changes flag changes. |
Use this user property to set the default value for the report header label to the report header name.
Value |
"Report Section", "Display Name", "[Report Section]" |
Usage |
Sets the default value for the report header label to the report header name. |
Package Item Field Map 6
Value |
Usage |
Value |
Usage |
SearchSpecField
Value |
Parent Property Id |
Usage |
Sequence Field
Use this user property to get a sequence number when users create a new record.
Value |
Sequence Num |
TNT Function Report Comments and TNT SHM BEO Section Description business components |
Usage |
Gets a sequence number when users create a new record. |
Use this user property to specify the copied fields when users create a template for a function.
Value |
Day#, Function Type, Function Name, Start, Duration, End, Setup Style, Expected Num, Function Space, Post As, Comments, Projected Num, Room Area, Room Area Square Meters, Meal Period, Flow Flag, Spacious Set Flag, Noise Flag, Best Fit Suite Only, TNT SubFunction Location |
Usage |
Specifies the copied fields when users create a template for a function. |
Use this user property to specify the copied fields when users create a template for an agenda function.
Value |
Day #, Function Type, Name, Start Time, Duration, End Time, Setup Style, Expected #, Projected, Room Area, Room Area Square Meters, Meal Period, Flow Flag, Spacious Set Flag, Noise Flag, Bypass Flag, Best Fit Suite Only Flag, Location |
Usage |
Specifies the copied fields when users create a template for an agenda function. |
User Properties for Space Hold
This topic describes the user properties supported for the Space Hold functionality of Siebel Hospitality. This topic describes the following user properties:
CanInvoke Method: ReleaseInventory
Use this user property to enable or disable the ReleaseInventory method.
Value |
[TNT Disable Release Flag] AND [Id] IS NOT NULL |
TNT SHM Functions List Applet, TNT SHM Order Function List Applet applet |
Usage |
This user property is used to enable or disable the ReleaseInventory method. If the function record has an inventory status other than Unreserved, then only the ReleaseInventory method can be invoked. |
Enable Sub Function Dependency At Detail Function
Value |
N |
TNT SHM Function Booking VBC business component |
Usage |
This user property is used in C++ code. If the value is Y, then dependencies for the subfunction will be created and displayed at the detail function booking level. If the value is N, then dependencies for the subfunction will not be created and displayed at the detail function booking level. |
Item BC Search Space
Use this user property to get an expression and set it as a named search specification for the TNT SHM Function Booking VBC business component.
Value |
Update BC Search Spec Field |
TNT SHM Function Space Diary, TNT SHM Function Space Diary Total Availability Applet applet |
Usage |
The TNT SHM Function Booking VBC business component search specification is truncated to enable the display of subfunctions in the Function Space Diary. If a user does not want to display the subfunctions, this user property is used in C++ code to restore the search specification to its original, untruncated form. |
Load Business Component Name
Value |
TNT SHM Gantt AX Admin Specialized Controls |
Usage |
This user property is used in C++ code to return Function Space Diary administration values. The Function Space Diary administration value will be returned from the respective defined business component. |
Named Method 3
Use this user property to call the ReleaseInventory() method of the TNT SHM Function Booking business component when the ReleaseInventory() method is called.
Value |
ReleaseInventory, INVOKE, TNT SHM Function Booking, Release |
TNT SHM Function Booking business component |
Usage |
This user property is used in conjunction with the Named Method 11 user property of the TNT SHM Function business component. This user property is used to call the Release method to release the inventory. |
Named Method 11
Value |
ReleaseInventory, INVOKEALL, TNT SHM Function Booking, ReleaseInventory |
Usage |
This user property is used to invoke a named method when the Release applet menu item is selected to release the inventory. |
Named Method 12
Use this user property to call the RefreshBusComp() method of the TNT SHM Function business component when the ReleaseInventory() method is called.
Value |
ReleaseInventory, INVOKE, TNT SHM Function, RefreshBusComp |
Usage |
This user property is used in conjunction with the Named Method 11 user property to refresh the TNT SHM Function business component. |
Sort Specification Field
Use this user property to sort the functions in the Create Agenda Sub Function pop-up applet.
Value |
Start Time |
Usage |
This user property is used to sort the functions in the Opportunities screen, Function Agenda view. This user property is used only if the ViewMode Sort:3 user property is not available. To sort the Function Agenda list on a different field, modify the value of this user property with that field name. |
Use this user property to sort the subfunctions in Create Agenda Sub Function pop-up applet.
Value |
Start |
Usage |
This user property is used to sort the functions in the Opportunities screen, Function Agenda view. This user property is used only if the ViewMode Sort:3 user property is not available. To sort the functions on a different field, modify the value of this user property with that field name. |
TNT SHM Field Names
This user property is used in conjunction with the TNT SHM Parent Function Field Names user property of the TNT SHM Agenda Functions business component. Use this user property to define the field names to be used to display the existing subfunction details in the Sub Function pop-up applet. Also, if there is any change in the subfunction details, use this user property to map all these field values back to the parent business component.
In C++, the field values are copied from the TNT SHM Create Agenda Sub Function VBC business component to the TNT SHM Agenda Functions business component in the defined field order. Therefore, you must maintain the order of the fields to determine from which field in the TNT SHM Create Agenda Sub Function VBC business component to which field in the TNT SHM Agenda Functions business component each value is copied.
Value |
TNT SHM Day#, TNT SHM Function Type, TNT SHM Post As/Signage, TNT SHM Date, TNT SHM End Time, TNT SHM Flow, TNT SHM Location, TNT SHM Projected, TNT SHM Start Time, TNT SHM Expected Attendees |
TNT SHM Create Agenda Sub Function VBC business component |
Usage |
This user property is used in C++ code in conjunction with the TNT SHM Agenda Functions business component. For more information about the usage of this user property, see TNT SHM Parent Function Field Names. |
TNT SHM Field Names
This user property is used in conjunction with the TNT SHM Parent Function Field Names user property of the TNT SHM Functions business component. Use this user property to define the field names to be used to display the existing subfunction details in the Sub Function pop-up applet. Also, if there is any change in the subfunction details, use this user property to map all these field values back to the parent business component.
In C++, the field values are copied from the TNT SHM Create Sub Function VBC business component to the TNT SHM Functions business component in the defined field order. Therefore, you must maintain the order of the fields to determine from which field in the TNT SHM Create Sub Function VBC business component to which field in the TNT SHM Functions business component each value is copied.
Value |
TNT SHM Day#, TNT SHM Function Type, TNT SHM Post As/Signage, TNT SHM Date, TNT SHM End Time, TNT SHM Flow, TNT SHM Location, TNT SHM Projected, TNT SHM Start Time, TNT SHM Expected Attendees, TNT SHM Function Space Id, TNT SHM Function Space |
TNT SHM Create Sub Function VBC business component |
Usage |
This user property is used in C++ code in conjunction with the TNT SHM Function business component. For more information about the usage of this user property, see TNT SHM Parent Function Field Names. |
TNT SHM Has Function Space Field
Use this user property to define whether or not the function space option is available for the function agenda.
Value |
N |
Usage |
This user property is used in C++ code to manage function space functionality. By default, the value is N, indicating that function space is not available in the Opportunities screen, Function Agenda view. Modify the value to Y if function space is available for the function agenda. |
Value |
Y |
Usage |
This user property is used in C++ code to manage function space functionality. By default, the value is Y, indicating that function space is available in the Functions views of the Quotes, Orders, and Event Checks screens. Modify the value to N if function space is not available for the function. |
This user property is used in conjunction with the TNT SHM Field Names user property of the TNT SHM Create Agenda Sub Function VBC business component. Use this user property to define the field names to be copied in the subfunction. Also, when the Sub Function pop-up applet is opened, use this user property to display these field values as subfunction records.
Value |
Day #, Function Type, Name, Start Date, End Time, Flow Flag, Location, Projected, Start Time, Expected # |
Usage |
This user property is used in C++ code in conjunction with the TNT SHM Create Agenda Sub Function VBC business component. When a user clicks the Sub Function button, the subfunctions of the selected function are displayed in the Create Agenda Sub Function pop-up applet. Similarly, if the existing subfunction details are modified or if new subfunctions are added, these changes are displayed in Opportunity screen, Function Agenda view. This user property is used to map the VBC fields with the fields of the TNT SHM Agenda Functions parent business component. If you add, delete, or modify fields, then to display these changes, you must modify the value of this user property, and also the value of the TNT SHM Field Names user property in the TNT SHM Create Agenda Sub Function VBC business component. |
This user property is used in conjunction with the TNT SHM Field Names user property of the TNT SHM Create Sub Function VBC business component. Use this user property to define the field names to be copied in the subfunction when the Sub Function pop-up applet is opened.
Value |
Day#, Function Type, Function Name, Date, End, Flow Flag, TNT SubFunction Location, Projected Num, Start, Expected Num, Joined Function Space ID, Joined Function Space Name |
Usage |
This user property is used in C++ code in conjunction with the TNT SHM Create Sub Function VBC business component. When a user clicks the Sub Function button, the subfunctions of the selected function are displayed in Create Agenda Sub Function pop-up applet. Similarly, if the existing subfunction details are modified or if new subfunctions are added, these changes are displayed in the Functions views of the Quotes and Orders screens. This user property is used to map the VBC fields with the fields of the TNT SHM Function parent business component. If you add, delete, or modify fields, then to display these changes, you must modify this user property value, and also the value of the TNT SHM Field Names user property of the TNT SHM Create Sub Function VBC business component. |
TNT SHM Parent Function Write Field Names
This user property is used in conjunction with the TNT SHM Write Field Names user property. Use this user property to define the names of the fields that receive changes in subfunction details from the TNT SHM Create Sub Function VBC business component. Also use this user property to define the field names to be copied in the subfunction so that when the Sub Function pop-up applet is opened, all these field values are displayed as the existing subfunction records.
In C++, the field values are copied from the TNT SHM Create Sub Function VBC business component to the TNT SHM Function business component in the defined field order. Therefore, you must maintain the order of the fields to determine from which field in the TNT SHM Create Sub Function VBC business component to which field in the TNT SHM Functions business component each value is copied.
Value |
TNT SHM Function business component |
Usage |
This user property is used in conjunction with the TNT SHM Parent Function Write Field Names user property of the TNT SHM Function business component. Use this user property to define the field names to map back to the parent business component to save changes in the subfunction details.
Value |
Usage |
This user property is used in C++ code in conjunction with the TNT SHM Function business component. For more information about the usage of this user property, see TNT SHM Parent Function Write Field Names. |
ViewMode Sort:3
Value |
Start Time |
Usage |
This user property is used to sort the functions in the Opportunities screen, Function Agenda view. To sort the Function Agenda list on a different field, modify the value of this user property with that field name. |
ViewMode Sort:3
Use this user property to sort the functions in Create Agenda Sub Function pop-up applet.
Value |
Start |
Usage |
This user property is used to sort the functions in the Opportunities screen Function Agenda view. If you sort the functions on a different field, then modify the value of this user property with that field name. |
User Properties for Run of House
This topic describes the user properties supported for the Run of House functionality of Siebel Hospitality. This topic describes the following user properties:
AddSellNoteRowOnTop
Use this user property to decide the position for displaying sell notes.
Value |
Y |
TNT SHM SR Inventory Dync, TNT SHM SR Total Avail Dync, TNT SHM SR Total Transient Avail Dync, TNT SHM SR Type Dync - Group By Type business components |
Usage |
This user property is used to decide the position for displaying sell notes. If the value is Y, then the sell notes are displayed at the start of the Total Group Availability applet. If the value is not Y, then the sell notes are displayed at the end of Total Group Availability applet. In the later case, before the sell notes, counts are displayed for Total Group Available, Group Optimal, Group Blocked, Group Projected, and Group Authorized for the different room types. |
Pivot 0 BC Sort Spec
Use this user property to define the sort specification while displaying the available data.
Value |
Start Date, Room Type (DESCENDING), Room Name |
TNT SHM SR Inventory Dync business component |
Usage |
This user property is used to define the sort specification while displaying the available data. The sort specification can be changed by modifying the value with appropriate fields. |
ROH Main Search Spec Field Name
Use this user property to check the availability functionality for Run of House rooms.
Value |
ROH Main Search Spec |
Parent Object Type |
TNT SHM Quote Room Block Summary DyncPivot, TNT SHM Revised Room Block Booking, TNT SHM Quote Room Block Line Items, TNT SHM FSI Booking business components |
Usage |
This user property is used in conjunction with the ROH Sub Search Spec Field Name user property. This user property is used to check the availability of Run of House rooms. |
Value |
ROH Sub Search Spec |
Usage |
This user property is used in conjunction with the ROH Main Search Spec Field Name user property. This user property is used to check the availability of Run of House rooms. |
User Properties for Sleeping Room Taxes and Service Charges
This topic describes the user properties supported for the Sleeping Room Taxes and Service Charges functionality of Oracle’s Siebel Hospitality. This topic describes the following business component user properties:
Calculate Tax & Service Charges for Room
Use this user property to determine whether or not to calculate taxes and service charges for sleeping rooms.
Value |
Y |
TNT SHM Room block Rates, TNT SHM Room block Rates Pending business components |
Usage |
This user property is used to decide whether or not to calculate taxes and service charges for sleeping rooms. This user property has a value of Y to calculate taxes and service charges, and a value of N to not to calculate taxes and service charges. |
Consider Complimentary
Use this user property to determine whether or not the complimentary quantity must be considered when negotiated sleeping rooms records are generated.
Value |
Function Status;Quote Status |
Usage |
This user property is used to decide whether or not the complimentary quantity must be considered when negotiated sleeping rooms records are generated. This user property has a value of Y to consider the complimentary quantity, and a value of N to not consider the complimentary quantity. |
TNT SHM Calc Revenue For Which Field
Use this user property to indicate which amount taxes and service charges must be calculated for.
Value |
ForAdjusted |
Usage |
This user property is used to indicate which amount taxes and service charges must be calculated for. The default ForAdjusted value calculates the sum of taxes and service charges for the guest invoice. The ForOriginal value calculates the sum of taxes and service charges for the accounting invoice. |
TNT SHM Total Service Charge Amount Field
Use this user property to indicate the name of the field in which the weekday service charge amount is stored.
Value |
Service Charge Amount |
Usage |
This user property is used to indicate the name of the field in which the weekday service charge amount is stored. |
TNT SHM Total Tax Amount Field
Use this user property to indicate the name of the field in which the weekday tax amount is stored.
Value |
Tax Amount |
Usage |
This user property is used to indicate the name of the field in which the weekday tax amount is stored. |
TNT SHM Weekend Total Service Charge Amount Field
Use this user property to indicate the name of the field in which the weekend service charge amount is stored.
Value |
Weekend Service Charge Amount |
Usage |
This user property is used to indicate the name of the field in which the weekend service charge amount is stored. |
TNT SHM Weekend Total Tax Amount Field
Use this user property to indicate the name of the field in which the weekend tax amount is stored.
Value |
Weekend Tax Amount |
Usage |
This user property is used to indicate the name of the field in which the weekend tax amount is stored. |
User Properties for Pivot Applets
This topic describes the user properties supported for the pivot applets functionality in Siebel Hospitality. This topic covers the following subjects:
Applet User Properties for Pivot Applets
BC Date Context Field
This user property is used to specify the pivot BC Date field name. This user property is activated when a user clicks the Go To Diary button.
Value |
Date |
TNT SHM SR Inventory Display Dync List Applet - Read Only, TNT SHM SR Inventory Display Dync List Applet - Total Availability, TNT SHM SR Inventory Display Dync List applet, TNT SHM SR Total Avail Room Specific Dync List Applet, TNT SHM SR Total Transient Avail Dync List Applet |
Usage |
This user property contains the date field name in the pivot business component. This field keeps the date context with the parent business component. For example, if a user clicks the Next Set Column button in the pivot applet, the date column display advances to the next seven days. The same date context is maintained in the parent business component. |
Button Drilldown
This user property is used to specify the name of the drill-down object. This user property is activated when a user clicks the Go To Diary button.
Value |
Diary Drilldown |
Usage |
This user property is used to specify the name of the drill-down object that has been configured in the applet. |
CanModifyLayout
This user property is used to control the display of the Columns Displayed applet menu option.
Value |
N |
TNT SHM Property Projected / Blocked List Applet |
Usage |
If this user property is set to N, the Columns Displayed menu option is disabled. If this user property is set to Y, the Columns Displayed menu option is enabled. |
Parent BC Date Context Field
This user property is used to specify the parent business component date field name. This user property is activated when a user clicks the Go To Diary button.
Value |
Search Sleeping Room Date |
Usage |
This user property contains the parent business component date field name. This field keeps the date context with the pivot business component. For example, if a user clicks the Next Set Column button in the pivot applet, the date column display advances to the next seven days. The same date context is maintained in the parent business component. This field value is set with the same date in the pivot business component. |
Parent Src Field Default
This user property is used to specify the source field name in the source business component. This user property is activated when a user clicks the Go To Diary button.
Value |
Id |
Usage |
This user property contains the source field name in the parent business component. This field is used to query the child business component in the Destination view. |
Popup Applet Name
This user property specifies the name of the applet that is used to display records.
Value |
TNT SHM Property Special Dates / Sell Notes Popup Applet |
TNT SHM Function Space Inventory DyncPivot List Applet, TNT SHM Property Pricing - FS Full Day Discount Pivot Applet, TNT SHM Property Pricing - Function Space Pivot Applet, TNT SHM Property Pricing - Sleeping Room Government Pivot Applet, TNT SHM Property Pricing - Sleeping Room Pivot Applet |
Usage |
This user property is used to specify the pop-up applet name. This user property displays the records from the business component defined by the Popup BC Name user property. |
Popup BC Name
This user property specifies the name of the business component that displays the records in the applet specified by the Popup Applet Name user property.
Value |
TNT SHM Property Special Dates Action |
Usage |
This user property specifies the name of the business component that displays the records in the applet specified by the Popup Applet Name user property. |
Popup End Date Field
This user property is used to specify the end date field name.
Value |
End Date |
Usage |
This user property is used to specify the end date field name. This field is used to prepare the date range search specification on the business component specified by the Popup BC Name user property. |
Popup Start Date Field
This user property is used to specify the start date field name.
Value |
Start Date |
Usage |
This user property is used to specify the start date field name. This field is used to prepare the date range search specification on the business component specified by the Popup BC Name user property. |
Refresh Applet
This user property is used to refresh the applet.
Value |
Y |
TNT SHM SR Inventory Display Dync List applet |
Usage |
If this user property is set to Y, the applet is refreshed after records have been written to the applet. If this user property is set to N, the applet is not refreshed after records have been written to the applet. |
Business Component User Properties for Pivot Applets
BC Name Field
This user property is used to store the name of a field defined in the business component.
Value |
BC Name |
TNT SHM SR Inventory Dync |
Usage |
This user property is used to store the name of a field defined in the business component. For example, if a business component contains multiple data business components, BC Name is stored as multiple values that are derived from the respective data business components. For example, if this VBC contains multiple data business components, the respective data BC Names are stored in the BC Name field. |
BO Name Field
Value |
BO Name |
Usage |
This user property is used to store the name of a field defined in the business component. For example, if this VBC contains multiple data business objects, the respective data BO Names are stored in the BO Name field. |
Column Name Field
Value |
Column Name |
TNT SHM SR Inventory Dync, TNT SHM FSI Category Valid Authorization VBC |
Usage |
This user property is used to store the name of a field defined in the business component. In the specified business components, multiple columns are displayed in dynamic rows. For example, the corresponding Group Forecast, Group Authorized, and Capacity LOV values are displayed in the user interface. Consequently, this user property is used in code to temporarily read those values. |
Dyn Field Name Field
This user property is used to store the name of the dynamic field in the specified data business component.
Value |
Dyn Field Name |
Usage |
This user property is used to store the name of the dynamic field in the specified data business component. For example, in this business component, the dynamic field name is Start Date for all the data business components. |
Enable Single Button Toggle
This user property is used to enable or disable the functionality to switch the With Tentative/Without Tentative button between the two labels.
Value |
Y |
Usage |
When set to Y, this user property enables the functionality to switch the With Tentative/Without Tentative button between the two labels. When set to N, this user property disables the functionality to switch the With Tentative/Without Tentative button between the two labels. |
Method Name 1
This user property determines the value of the With Tentative/Without Tentative button label. This user property is a continuation of the Enable Single Button Toggle user property.
Value |
WithoutTentative |
Usage |
The With Tentative/Without Tentative button label is determined by the value of this user property. By default, the button label is the WithoutTentative LOV value, which displays the Without Tentative label on the button. You can configure more such buttons in the user interface and add more user properties such as Method Name 2 and so on. |
Undo Method Name 1
This user property changes the label of the With Tentative/Without Tentative button from Without Tentative to With Tentative. This user property is a continuation of the Method Name 1 user property.
Value |
WithTentative |
Usage |
When a user clicks the Without Tentative button, this user property calls the WithTentative method, which changes the button label to With Tentative. |
WithTentative:Undo Method Name
This user property changes the label of the With Tentative/Without Tentative button from With Tentative to Without Tentative. This user property is a continuation of the Undo Method Name 1 user property.
Value |
WithoutTentative |
Usage |
When a user clicks the With Tentative button, this user property calls the WithoutTentative method, which changes the button label to Without Tentative. |
WithoutTentative:Field Name
This user property runs the data business component specified by the value of the Tentative Flag field in the TNT SHM Quote Room Block Line Items Aggr business component.
Value |
Tentative Flag |
Usage |
The Tentative Flag field in the TNT SHM Quote Room Block Line Items Aggr business component has a value of Y for With Tentative and a value of N for Without Tentative. According to the Tentative Flag field value, this user property runs the appropriate data business component. |
WithoutTentative:Status
When the With Tentative/Without Tentative button is in Without Tentative display mode, this user property excludes records with a Status values of T1 and T2.
Value |
T1;T2; |
Usage |
When the With Tentative/Without Tentative button is in Without Tentative display mode, this user property excludes records with a Status values of T1 and T2 (that is, tentative records) from the display. |
WithoutTentative:Undo Method Name
When a user clicks the Without Tentative button, this user property changes the button label to With Tentative. This user property is a continuation of the WithTentative:Undo Method Name user property.
Value |
WithTentative; |
Usage |
When a user clicks the Without Tentative button, this user property changes the button label to With Tentative. The WithTentative method is called when a user clicks the button. |
Pivot 0 Aggregate Type
This user property is used to aggregate the Total values horizontally.
Value |
0 |
TNT SHM SR Inventory Dync, TNT SHM SR Total Avail Dync, TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Total Group Avail Dync, TNT SHM SR Total Transient Avail Dync, TNT SHM SR Type Dync - Group By Type, TNT SHM FSI Category Valid Authorization VBC |
Usage |
This user property is used to aggregate the Total values horizontally. If the value of this user property is 1, it creates a row with the label Total and displays the total of all the attribute values in two separate rows. |
Pivot 0 BC Name
This user property contains the name of the business component in which the displayed data is stored.
Value |
TNT SHM FSI Auth Lvl |
Usage |
This user property contains the name of the business component in which the displayed data is stored. |
Pivot 0 BC Search Spec
This user property contains the search specification to apply to the business component in which the displayed data is stored.
Value |
([Room Type] = LookupValue(PRODUCT_TYPE, 'Sleeping Room') OR [Room Type] = LookupValue(PRODUCT_TYPE, 'ROH Sleeping Room')) |
TNT SHM SR Inventory Dync The same user property is also available with different values in the following business components: TNT SHM SR Total Avail Dync, TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Total Group Avail Dync, TNT SHM SR Total Transient Avail Dync, TNT SHM SR Type Dync - Group By Type, TNT SHM FSI Category Valid Authorization VBC |
Usage |
This user property contains the search specification to apply to the business component in which the displayed data is stored. |
This user property contains the sort specification to apply to the business component in which the displayed data is stored.
Value |
Usage |
This user property contains the sort specification to apply to the business component in which the displayed data is stored. |
Pivot 0 BO Name
This user property contains the name of the business object that contains the business component in which the displayed data is stored.
Value |
SHM Site |
TNT SHM SR Inventory Dync, TNT SHM SR Total Avail Dync, TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Total Group Avail Dync,TNT SHM SR Total Transient Avail Dync, TNT SHM SR Type Dync - Group By Type, TNT SHM FSI Category Valid Authorization VBC |
Usage |
This user property contains the name of the business object that contains the business component in which the displayed data is stored. |
Pivot 0 Can Update
This user property sets the various column values in dynamic rows.
Value |
Y |
Usage |
This user property sets the various column values in dynamic rows. |
Pivot 0 Dynamic Field
This user property specifies a field, the value of which is displayed as dynamic columns.
Value |
StartDate |
Usage |
This user property specifies a field, the value of which is displayed as dynamic columns. This field is present in the data business component. |
Pivot 0 Group Field
This user property specifies the data business component field, the value of which is used to group the data in the applet.
Value |
Room Name |
Usage |
This user property specifies the data business component field, the value of which is used to group the data in the applet. |
Pivot 0 Parent Filter Field 0
This user property is used to apply the parent search specification to the data business component.
Value |
Date;Search Sleeping Room Date |
TNT SHM SR Inventory Dync, TNT SHM SR Total Avail Dync, TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Total Group Avail Dync, TNT SHM SR Total Transient Avail Dync, TNT SHM SR Type Dync - Group By Type |
Usage |
This user property is used to apply the parent search specification to the data business component. The value of the Search Sleeping Room Date field in the SHM Site business component is used to apply the search specification. |
Pivot 0 Parent Filter Field 1
Value |
Day Of Week;Search Day Of Week |
TNT SHM SR Inventory Dync The same user property is also available with different values in the following business components: TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Type Dync - Group By Type |
Usage |
This user property is used to apply the parent search specification to the data business component. For example, the value of the Search Day Of Week field in the SHM Site business component is used to apply the search specification. |
Pivot 0 Type 0
This user property specifies the attributes that are displayed in the applet.
Value |
Total Group Available;1;Total Group Available;1 |
Usage |
This user property specifies the attributes that are displayed in the applet. The first argument indicates the LOV value to be displayed in the user interface as an attribute. The second argument identifies the data business component field name. |
Pivot 0 Type 1
Value |
Group Optimal;1;Optimal Level;1 |
Usage |
Pivot 0 Type 2
Value |
Capacity;0;Room Capacity;0 |
TNT SHM SR Inventory Dync The same user property is also available with different values in the following business components: TNT SHM SR Total Avail Dync, TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Total Group Avail Dync, TNT SHM SR Total Transient Avail Dync, TNT SHM SR Type Dync - Group By Type |
Usage |
Pivot 0 Type 3
Value |
Transient Booked;0;Transient Booked;0 |
Usage |
Pivot 0 Type 4
Value |
Usage |
Pivot 1 Aggregate Type
This user property is used to aggregate the Total horizontally.
Value |
0 |
TNT SHM SR Inventory Dync, TNT SHM SR Total Avail Dync, TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Total Group Avail Dync, TNT SHM SR Total Transient Avail Dync |
Usage |
Pivot 1 BC Name
Value |
TNT SHM Quote Room Block Line Items Aggr |
TNT SHM SR Inventory Dync, TNT SHM SR Total Avail Dync, TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Total Group Avail Dync, TNT SHM SR Total Transient Avail DyncUsage |
Usage |
Pivot 1 BC Search Spec
Value |
TNT SHM SR Inventory Dync The same user property is also available with different values in the following business components: TNT SHM SR Total Avail Dync, TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Total Group Avail Dync, TNT SHM SR Total Transient Avail Dync |
Usage |
Pivot 1 BO Name
Value |
Quote |
Usage |
Pivot 1 Dynamic Field
Value |
Start Date |
Usage |
Pivot 1 Group Field
This user property is used to specify a data business component field, the value of which is used to group the data in the applet.
Value |
Status |
TNT SHM SR Inventory Dync, TNT SHM SR Total Avail Dync, TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Total Transient Avail Dync |
Usage |
This user property is used to specify a data business component field, the value of which is used to group the data in the applet. |
Pivot 1 Parent Filter Field 0
Value |
Usage |
This user property is used to apply the parent search specification to the data business component. The value of the Search Sleeping Room Date field in the SHM Site business component is used to apply the search specification to the data business component. |
Pivot 1 Parent Filter Field 1
Value |
TNT SHM SR Inventory Dync The same user property is also available with different values in the TNT SHM SR Total Avail Room Specific Dync business component. |
Usage |
This user property is used to apply the parent search specification to the data business component. For example, the value of the Search Day Of Week field in the SHM Site business component is used to apply search specification to the data business component. |
Pivot 1 Type 0
Value |
Group Blocked;1;Exact Blocked;1 |
Usage |
Pivot 1 Type 0 Sub Group 0
This user property is used to create subgroups.
Value |
Definite/Hold;[Status]=LookupValue("TNT_FUNC_STATUS","Definite") OR [Status]=LookupValue("TNT_FUNC_STATUS","Hold") |
Usage |
This user property is used for sub-grouping. This user property is used in conjunction with the Pivot 1 Type 0 user property to create subgroups of the dynamic records. |
Pivot 1 Type 1
Value |
Group Picked Up;0;Picked Up;0 |
Usage |
Pivot 1 Type 2
Value |
Group Projected;1;Exact Projected;1 |
TNT SHM SR Inventory Dync The same user property is also available with different values in the following business components: TNT SHM SR Total Avail Dync, TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Total Group Avail Dync |
Usage |
Pivot 1 Type 2 Sub Group 0
Value |
Usage |
This user property is used for sub-grouping. This user property is used in conjunction with the Pivot 1 Type 2 user property to create subgroups of the dynamic records. |
Pivot 2 Aggregate Type
Value |
0 |
Usage |
Pivot 2 BC Name
Value |
Usage |
Pivot 2 BC Search Spec
Value |
Usage |
Pivot 2 BO Name
Value |
SHM Site |
Usage |
Pivot 2 Dynamic Field
Value |
Start Date |
Usage |
Pivot 2 Group Field
Value |
Room Name |
Usage |
Pivot 2 Parent Filter Field 0
Value |
Usage |
Pivot 2 Parent Filter Field 1
Value |
Usage |
This user property is used to apply the parent search specification to the data business component. For example, the value of the Search Day Of Week field in the SHM Site business component is used to apply the search specification to the data business component. |
Pivot 2 Type 0
Value |
Group Authorized;1;Authorization Level;1 |
Usage |
Pivot 2 Type 1
Value |
Usage |
Pivot 2 Type 2
Value |
Usage |
Pivot 2 Type 3
Value |
Usage |
Pivot Calc Type 0
This user property is used to create records for specialized calculated row types from an already-aggregated value.
Value |
Total Group Available |
Usage |
This user property is used to create records for specialized calculated row types from an already-aggregated value. The calculated expression can be given as a value, or as the calculated business component field name from the data business component. |
Pivot Date Range
This user property is used to specify the date range.
Value |
7 |
Usage |
This user property is used to specify the date range. The value 7 means that the pivot applet displays the dynamic date columns for the next seven dates. In other words, the display shows the current date plus the next seven dates. |
Pivot Dynamic Field Format
This user property specifies the display format of the dynamic field.
Value |
%a %d %b, %y |
TNT SHM SR Inventory Dync, TNT SHM SR Type Dync - Group By Type |
Usage |
This user property specifies the display format of the dynamic field. The dynamic field is Start Date, which is displayed in the format {Sun 21 Nov, 10}. If the value of this user property is [%a %m/%d/%y], the Start Date field value is displayed in the format {Sun 11/21/10}. |
Pivot LOV Type
This user property specifies the LOV Type used for various attributes that are displayed in the pivot applet.
Value |
TNT_SHM_SR_AVAIL_PIVOT |
TNT SHM SR Inventory Dync The same user property is also available with different values in the following business components: TNT SHM FSI Category Valid Authorization VBC, TNT SHM SR Inventory Dync, TNT SHM SR Total Avail Dync, TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Total Group Avail Dync, TNT SHM SR Total Transient Avail Dync, TNT SHM SR Type Dync - Group By Type |
Usage |
This user property specifies the LOV Type used for various attributes that are displayed in the pivot applet. |
Pivot Static Field 0
This user property specifies the fields in the pivot business component that are mapped with applet list columns.
Value |
Type |
Usage |
This user property specifies the fields in the pivot business component that are mapped with applet list columns. |
Pivot Static Field 1
Value |
Property ID |
Usage |
Pivot Static Field 2
Value |
Date |
Usage |
Room Name Field
Value |
Room Name |
Usage |
This user property is used to store the name of a field defined in the business component. While displaying records in the pivot applet, this variable is used to store room block names. |
Total Availability Applet Name
This user property specifies the name of the applet that displays the pivot records.
Value |
TNT SHM SR Inventory Display Dync List Applet - Total Availability |
Usage |
This user property specifies the name of the applet that displays the pivot records. |
Pivot Calc Type 1
Value |
Total Booked |
TNT SHM SR Total Avail Dync |
Usage |
Pivot Calc Type 2
Value |
Total Available |
Usage |
Pivot Calc Type 3
Value |
Occupied Percent |
Usage |
Pivot Calc Type 4
Value |
Actual Available |
Usage |
Pivot 0 Group by Group Field
If the value of this user property is Y, then the field specified by the Pivot 0 Group Field is used for grouping.
Value |
Y |
Usage |
If the value of this user property is Y, then the field specified by the Pivot 0 Group Field is used for grouping, rather than the Pivot 0 Type 0 values. |
Pivot 0 Type 5
Value |
Group Projected;1;Projected;1 |
Usage |
Pivot 0 Type 6
Value |
Definite/T1 Projected;1;Projected D/T1;1 |
Usage |
Pivot 0 Type 7
Value |
Group Picked Up;1;Picked Up;1 |
Usage |
Pivot 0 Type 8
Value |
Usage |
Pivot Static Field 3
Value |
Group field |
Usage |
DCPivot Attribute LOV Name
Value |
TNT_SHM_DYNC_PIVOT_ATTRIB |
TNT SHM Function Space Inventory Dynamic Pivot The same user property is also available with different values in the following business components: TNT SHM Property Pricing - FS Full Day Discount Pivot VBC, TNT SHM Property Pricing - Function Space Pivot VBC, TNT SHM Property Pricing - Sleeping Room Government Pivot VBC, TNT SHM Property Pricing - Sleeping Room Pivot VBC, TNT SHM Property Projected / Blocked |
Usage |
DCPivot Attribute List 0
This user property is used to specify the first attribute to be displayed in the pivot applet for all the dynamic columns.
Value |
Authorization Level |
Usage |
This user property is used to specify the first attribute to be displayed in the pivot applet for all the dynamic columns. The display value from the TNT_SHM_DYNC_PIVOT_ATTRIB LOV Type for this value is used as the attribute. |
DCPivot Attribute List 1
This user property is used to specify the second attribute to be displayed in the pivot applet for all the dynamic columns.
Value |
Max Overbook Level |
Usage |
This user property is used to specify the second attribute to be displayed in the pivot applet for all the dynamic columns. The display value from the TNT_SHM_DYNC_PIVOT_ATTRIB LOV Type for this value is used as the attribute. |
DCPivot Attribute List 2
This user property is used to specify the third attribute to be displayed in the pivot applet for all the dynamic columns.
Value |
Max Option Level |
TNT SHM Function Space Inventory Dynamic Pivot The same user property is also available with different values in the following business components: TNT SHM Property Pricing - Sleeping Room Pivot VBC |
Usage |
This user property is used to specify the third attribute to be displayed in the pivot applet for all the dynamic columns. The display value from the TNT_SHM_DYNC_PIVOT_ATTRIB LOV Type for this value is used as the attribute. |
DCPivot DC Field Format
This user property is used to specify the display format of the dynamic field.
Value |
%a %d %b, %y |
TNT SHM Function Space Inventory Dynamic Pivot, TNT SHM Property Pricing - FS Full Day Discount Pivot VBC, TNT SHM Property Pricing - Function Space Pivot VBC, TNT SHM Property Pricing - Sleeping Room Government Pivot VBC, TNT SHM Property Pricing - Sleeping Room Pivot VBC, TNT SHM Property Projected / Blocked |
Usage |
This user property is used to specify the display format of the dynamic field. The dynamic field is Start Date, which is displayed in the format {Sun 21 Nov, 10}. If the value of this user property is [%a %m/%d/%y], the Start Date field value is displayed in the format {Sun 11/21/10}. |
DCPivot DC Set Size
This user property is used to control the number of date columns that are displayed.
Value |
8 |
Usage |
This user property is used to control the number of date columns that are displayed. This user property displays columns from the current date plus this value. When the value of this user property is 8, the view displays nine columns, one for the current date and one for each of the eight subsequent dates. |
DCPivot DC Totals Field
This user property is used in conjunction with the DCPivot DC Vertical Totals user property.
Value |
Rooms |
Usage |
This user property is used with conjunction of the DCPivot DC Vertical Totals user property. If this user property and the DCPivot DC Vertical Totals user property are both set to Y, a vertical row is created for Total with the label Total in one of the cells. |
DCPivot DC Unit Size
This user property is used to calculate the date range.
Value |
1 |
Usage |
This user property is used to calculate the date range. The value of this user property indicates what the next dynamic column will be. If the value of this user property is 1, the difference between the date columns is one day. |
DCPivot Data Bus Comp
Value |
TNT SHM Function Space Inventory Dynamic Pivot The same user property is also available with different values in the following business components: TNT SHM Property Pricing - FS Full Day Discount Pivot VBC, TNT SHM Property Pricing - Function Space Pivot VBC', TNT SHM Property Pricing - Sleeping Room Government Pivot VBC, TNT SHM Property Pricing - Sleeping Room Pivot VBC, TNT SHM Property Projected / Blocked |
Usage |
DCPivot Data Search Spec
Value |
[Room Type] <> LookupValue('PRODUCT_TYPE', 'Sleeping Room') |
TNT SHM Function Space Inventory Dynamic Pivot The same user property is also available in the following business components that have the following value: ([Inventory Status] = LookupValue("TNT_SHM_INV_STATUS", "Actualized") OR [Inventory Status] = LookupValue("TNT_SHM_INV_STATUS", "Reserved")) TNT SHM Property Pricing - FS Full Day Discount Pivot VBC, TNT SHM Property Pricing - Function Space Pivot VBC', TNT SHM Property Pricing - Sleeping Room Government Pivot VBC, TNT SHM Property Pricing - Sleeping Room Pivot VBC, TNT SHM Property Projected / Blocked |
Usage |
DCPivot Default DC DataType
This user property specifies the default data type for dynamic columns.
Value |
10 |
Usage |
This user property specifies the default data type for dynamic columns. |
DCPivot Default DC FieldName
This user property specifies the default dynamic field name for dynamic columns.
Value |
Start Date |
Usage |
This user property specifies the default dynamic field name for dynamic columns. |
DCPivot Group Key List 0
Value |
Room Name |
Usage |
DCPivot Update Primary BC
If this user property is set to Y, it goes through each column of the current virtual record, reads the value of each cell, and updates the value that corresponds to the data business component.
Value |
Y |
TNT SHM Function Space Inventory Dynamic Pivot The same user property is also available with different values in the following business components: TNT SHM Property Pricing - FS Full Day Discount Pivot VBC, TNT SHM Property Pricing - Function Space Pivot VBC', TNT SHM Property Pricing - Sleeping Room Government Pivot VBC, TNT SHM Property Pricing - Sleeping Room Pivot VBC |
Usage |
If this user property is set to Y, it goes through each column of the current virtual record, reads the value of each cell, and updates the value that corresponds to the data business component. |
TNT AvoidBookmark
This user property is related to printing functionality.
Value |
Y |
TNT SHM Function Space Inventory Dynamic Pivot, TNT SHM Property Projected / Blocked |
Usage |
This user property is related to printing functionality. In the case of dynamic data, this user property is used to avoid the re-execution of the business component and to maintain the context of the dynamic data. |
Virtual Business Component User Properties for Pivot Applets
This topic describes the following virtual business component user properties:
DCPivot Aggregation
Value |
N |
TNT SHM Property Pricing - FS Full Day Discount Pivot VBC The same user property is also available with different values in the following business components: TNT SHM Property Pricing - Function Space Pivot VBC, TNT SHM Property Pricing - Sleeping Room Government Pivot VBC, TNT SHM Property Pricing - Sleeping Room Pivot VBC, TNT SHM Property Projected / Blocked |
Usage |
This user property is used to aggregate the Total values horizontally. This user property creates a row with the label Total and displays the total of all the attribute values in two separate rows. |
DCPivot Attribute List 3
This user property is used to specify one of the attributes to be displayed in the pivot applet for all the dynamic columns.
Value |
Maximum |
Usage |
This user property is used to specify one of the attributes to be displayed in the pivot applet for all the dynamic columns. |
DCPivot Attribute List 4
Value |
Cost |
Usage |
DCPivot Attribute Read-Only List 0
This user property is used to specify a field in the pivot applet that is read only.
Value |
Rental |
Usage |
This user property is used to specify a field in the pivot applet that is read only. |
DCPivot Attribute Read-Only List 1
Value |
Threshold |
Usage |
DCPivot Data BusComp Link
This user property specifies the name of the link.
Value |
SHM Site/TNT SHM Property Pricing - FS Full Day Discount |
Usage |
This user property specifies the name of the link. |
DCPivot DC Horizontal Totals
If the value of this user property is Y, a column named Total is created and displays the total of values for that record.
Value |
N |
Usage |
If the value of this user property is Y, a column named Total is created and displays the total of values for that record. |
If the value of this user property is Y, a row labeled Total is created and displays the total of values for the attributes.
Value |
N |
Usage |
If the value of this user property is Y, a row labeled Total is created and displays the total of values for the attributes. |
DCPivot Group Key List 1
This user property is used to specify the grouping field.
Value |
Day Part Name |
TNT SHM Property Pricing - FS Full Day Discount Pivot VBC The same user property is also available with different values in the following business components: TNT SHM Property Pricing - Function Space Pivot VBC, TNT SHM Property Projected / Blocked |
Usage |
This user property is used to specify the grouping field. |
DCPivot Group Key List 2
Value |
Rooms |
Usage |
DCPivot Parent Search Field
This user property specifies the name of the parent business component field used for the search specification.
Value |
Usage |
This user property specifies the name of the parent business component field used for the search specification. |
Field Read Only Field: Authorization Level
This user property sets a specific field in a business component to be read only.
Value |
Read Only - Authorization Level |
Usage |
This user property sets a specific field in a business component to be read only. For more information about this user property, see the chapter on user properties in Siebel Developer's Reference. |
Sum BC Name
This user property specifies the name of the business component that is used to add up the field values specified by user properties such as Sum Field 1, Sum Field 2, and so on.
Value |
Usage |
This user property specifies the name of the business component that is used to add up the field values specified by user properties such as Sum Field 1, Sum Field 2, and so on. |
Sum Field 1
This user property specifies the name of the field for which to calculate a sum.
Value |
Blocked;Blocked |
Usage |
This user property specifies the name of the field for which to calculate a sum. The first attribute is the field name in the business component specified by the Sum BC Name user property. The second attribute is the field name in the present business component. |
Sum Field 2
Value |
D/T1 Blocked;Blocked D/T1 |
Usage |
Sum Field 3
Value |
Picked Up;Picked Up |
Usage |
Sum Field 4
Value |
Projected;Projected |
Usage |
Sum Field 5
Value |
D/T1 Projected;Projected D/T1 |
Usage |
Sum Key Field 1
This user property is used to uniquely identify the records in the business component specified by the Sum BC Name user property.
Value |
Start Date |
Usage |
This user property is used to uniquely identify the records in the business component specified by the Sum BC Name user property. |
Sum Key Field 2
Value |
Room Id |
Usage |
User Properties for Meeting Packages
This topic describes the user properties supported for the meeting packages functionality of Siebel Hospitality. This topic describes the following user properties:
Applet User Properties for the Function Space Diary
This topic describes the user properties that support meeting packages functionality in the Function Space Diary applets:
Diary User Preferences for End Time
This user property is used to specify the field name that is used in the Diary user preferences for end time control.
Value |
End Time |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet |
Usage |
This user property specifies the field name that is used in the Diary user preferences for end time control. |
Diary User Preferences for Start Time
This user property is used to specify the field name that is used in the Diary user preferences for start time control.
Value |
Start Time |
Usage |
This user property specifies the field name that is used in the Diary user preferences for start time control. |
Item Color Fields
This user property is used to specify the field name that is present in the Y-axis business component in the Diary.
Value |
Compound Inventory Status |
Usage |
This user property specifies the field name that is present in the Y-axis business component in the Diary. The booking color is displayed in the Diary according to the value of this user property. |
Item Mouse Over Ids
This user property is used to control the cursor shape in the Diary when the mouse pointer is hovering.
Value |
213;213;213;213 |
Usage |
This user property specifies the parameter for the cursor shape in the Diary when the mouse pointer is hovering. |
Item Time TurnTime Toggle BC Method
This user property is used to specify the name of the business component method that displays the turn time conflicts, if any, within the booking.
Value |
ShowToggleTurnTime |
Usage |
This user property displays the name of the business component method that displays the turn time conflicts, if any, within the booking. |
Restrict Diary BC Date
This user property is used to set the effective dates search specification in the booking business component and display the appropriate active specific spaces.
Value |
Y |
Usage |
If this user property is set to Y, then it sets the effective dates search specification in the booking business component and displays the appropriate active specific spaces. |
Retain Unreserve Popup Default
If the timing for a primary booking is changed, then this user property is used to move the booking to the new time.
Value |
Unreserve |
Usage |
If the timing for a primary booking is changed, then the primary booking is moved to the new time. If a backup space is booked, then this popup provides the option either to retain the backup booking or Unreserve it. |
Retain Unreserve Popup Name
This user property is used to specify the pop-up applet name for Retain Unreserve Popup Default.
Value |
TNT SHM Retain/Unreserve Popup Applet |
Usage |
This user property specifies the pop-up applet name for Retain Unreserve Popup Default. |
Transient Suite Field
This user property is used to disable the right-click context menu if the Type value of a space is Suite.
Value |
Is Transient Suite |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary |
Usage |
This user property is used to disable the right-click context menu if the Type value of a space is Suite. |
Views Having No Space for Icons in Major Axis
This user property is used to list views that have no space for icons.
Value |
128;256 |
Usage |
This user property contains a semicolon (;) separated list of views that have no space to display icons. |
Weekend BC Activation Field 1
This user property is used to specify the name of a field in the Weekend Admin business component that is activated in the code.
Value |
Day of Week |
Usage |
This user property specifies the name of a field in the Weekend Admin business component that is activated in the code. |
Weekend BC Activation Field 2
Value |
Weekend Weekday Flag |
Usage |
Weekend BC Activation Field 3
Value |
Property Id |
Usage |
Y-Axis Drill Down Enable
This user property is used to enable or disable drill-down on Y-axis specific spaces.
Value |
N |
Usage |
If the value of this user property is N, then drill-down on Y-axis specific spaces is disabled. |
Y-Axis Mouse Over Cursor Ids
This user property is used to control the cursor shape on the Y-axis when the mouse pointer is hovering.
Value |
213;213;213;213 |
Usage |
This user property specifies the parameter for the cursor shape on the Y-axis when the mouse pointer is hovering. |
Business Component User Properties for the Function Space Diary
This topic describes the user properties that support meeting packages functionality in the Function Space Diary business components:
Activation Field 2
This user property is used to specify the fields to be activated in the business component when the Diary is initialized.
Value |
Function Space Type - Query |
TNT SHM Gantt AX Date Time Interval PopUp VBC business component |
Usage |
This user property is used to specify the fields to be activated in the TNT SHM Gantt AX Date Time Interval PopUp business component, in the Function Space Diary screen, when the Diary applet is initialized. |
Color Code Weekend Type
Use this user property to define the type of day to which the Weekend color code type is mapped in the Function Space Diary.
Value |
Weekend |
Usage |
Each color code type has a different color, and each color must be mapped to a particular day type to identify those days in the Function Space Diary. The default value is Weekend. |
Default Function Space Type
This user property is used to provide the default value for the Function Space Type field.
Value |
Specific Space |
Usage |
This user property is used to provide the default value for the Function Space Type field. |
Default Start Date Time
This user property is used to provide the default value for the Start Date field.
Value |
Null |
TNT SHM Gantt AX Date Time Interval PopUp VBC business component TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC business component TNT SHM Inventory Gantt AX Date Time Interval PopUp VBC business component |
Usage |
This user property is used to provide the default value for the Start Date field. If this value is empty, then the default value of this field is the Date Threaded field value, if any. Otherwise, the default value of the Start Date field is the current date. |
Editable for TimeScale
This user property is used to specify whether or not the bookings are editable in each time scale.
Value |
1;N;2;N;4;Y;8;Y;16;Y;32;N;64;N;128;N;256;N |
Usage |
This user property is used to specify whether or not the bookings are editable in each time scale. |
GRC View:TNT SHM Site Function Space Diary Total Availability View
This user property is used to specify whether or not to refresh the other applets in the Function Space Diary views. This user property is used in conjunction with the Item BC Search Space applet user property.
Value |
Y |
Usage |
This user property is used to specify whether or not to refresh the other applets in the Function Space Diary views. This user property is used in conjunction with the Item BC Search Space applet user property. |
Parent StartDate Field
This user property is used to specify the Start Date field name in the parent business component.
Value |
Start Date |
Usage |
This user property specifies the Start Date field name in the parent business component. |
Time Part BC Major
This user property is used to specify the list of values in which day parts are displayed. Use this user property to retrieve the time part details for a property in the Function Space Diary.
Value |
Null |
Usage |
This user property is used to specify the list of values in which day parts are displayed. This user property retrieves the time part details for a property, and indicates whether or not to display the time part details on the appropriate time scale in the Function Space Diary. |
Time Part BC Minor End Date Field
Use this user property to retrieve the End Date for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component.
Value |
End Date |
Usage |
This user property retrieves the End Date for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component. The default value is End Date, which is a field in the TNT SHM Property Day Part Pricing business component. |
Time Part BC Minor End Time Field
Use this user property to retrieve the End Time for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component.
Value |
End Time |
Usage |
This user property retrieves the End Time for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component. The default value is End Time, which is a field in the TNT SHM Property Day Part Pricing business component. |
Time Part BC Minor Name Field
Use this user property to retrieve the Name for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component.
Value |
Name |
Usage |
This user property retrieves the Name for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component. The default value is Name, which is a field in the TNT SHM Property Day Part Pricing business component. |
Time Part BC Minor Start Date Field
Use this user property to retrieve the Start Date for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component.
Value |
Start Date |
Usage |
This user property retrieves the Start Date for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component. The default value is Start Date, which is a field in the TNT SHM Property Day Part Pricing business component. |
Time Part BC Minor Start Time Field
Use this user property to retrieve the Start Time for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component.
Value |
Start Time |
Usage |
This user property retrieves the Start Time for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component. The default value is Start Time, which is a field in the TNT SHM Property Day Part Pricing business component. |
Time Scale:Day/Day-Part
This user property is used to specify the number of days to be added to determine the date range columns for the Total Availability view.
Value |
1 |
Usage |
This user property specifies the number of days to be added to determine the date range columns for the Total Availability view. |
Time Scale:Day/Half-Hour
Value |
1 |
Usage |
Time Scale:Day/Hour
Value |
1 |
Usage |
Time Scale:Day/Quarter-Hour
Value |
1 |
Usage |
Time Scale:Month/Day
Value |
1 |
Usage |
Time Scale:Month/Day-of-Week
Value |
7 |
Usage |
Time Scale:Month/Day-of-Week/Day Part
Value |
7 |
Usage |
Time Scale:Week/Day
Value |
1 |
Usage |
Time Scale:Week/Day/Day Part
Value |
1 |
Usage |
TNT SHM Site Function Space Diary Total Availability View:BC 1
If a user navigates to the TNT SHM Site Function Space Diary Total Availability View, then this user property refreshes the TNT SHM SR Inventory Dync business component.
Value |
Usage |
If a user navigates to the TNT SHM Site Function Space Diary Total Availability View, then this user property refreshes the TNT SHM SR Inventory Dync business component. |
This user property is used to provide the Total Availability applet name.
Value |
Usage |
This user property provides the Total Availability applet name. |
Use Working Hours
This user property is used to specify whether or not to use working hours in each time scale.
Value |
Usage |
This user property specifies whether or not to use working hours in each time scale. If working hours are used, the horizontal scroll position is set depending on the start time of the working day and the pixels per unit. If working hours are not used, the horizontal scroll position is set to zero. |
X-Axis Drill Down Enable
This user property is used to specify whether or not to set the field value of Drilldown Name.
Value |
Y |
Usage |
This user property specifies whether or not to set the field value of Drilldown Name. |
Business Component User Property for Opportunities
This topic describes the property that supports meeting packages functionality in the Opportunity business component:
Template Copy History
This user property is used to provide the field name that evaluates to Y or N, depending on which properties and histories are copied when a generic event template is created.
Value |
Copy Properties Flag |
Opportunity business component |
Usage |
This user property is used to provide the field name that evaluates to Y or N, depending on which properties and histories are copied when a generic event template is created. |
Applet User Properties for Quotes
This topic describes the user properties that support meeting packages functionality in the Quotes applets:
Quote Item BC Name
This user property is used in C++ code to read the nonfunction line items (TNT Quote Item) business component name for time shift functionality.
Value |
TNT Quote Item |
TNT SHM Time Shift Parameter Event Popup Applet |
Usage |
This user property is used in C++ code to read the nonfunction line items (TNT Quote Item) business component name for time shift functionality. |
Quote Meeting Pkgs BC
This user property is used in C++ code to read the quote meeting packages (TNT Quote Meeting Packages) business component name for time shift functionality.
Value |
TNT Quote Meeting Packages |
Usage |
This user property is used in C++ code to read the quote meeting packages (TNT Quote Meeting Packages) business component name for time shift functionality. |
Business Component User Properties for Quotes
Exclude Function For Time Shift
This user property is used in C++ code to read the Quote Meeting Package Id field name to determine whether to exclude functions from a selective time shift.
Value |
Quote Meeting Package Id |
TNT SHM Function Business Component |
Usage |
This user property is used in C++ code to read the Quote Meeting Package Id field name to determine whether to exclude functions from a selective time shift. |
Exclude RmBlk For Time Shift
This user property is used in C++ code to read the Quote Meeting Package Id field name to determine whether to exclude room block items from a selective time shift.
Value |
TNT SHM Quote Room Block Business Component |
Usage |
This user property is used in C++ code to read the Quote Meeting Package Id field name to determine whether to exclude room block items from a selective time shift. |
Field Core Flg
This user property is used in C++ code to read the Core Flag field name for time shift functionality.
Value |
Core Flag |
TNT Quote Item, TNT SHM Function, TNT SHM Quote Item, TNT SHM Quote Room Block, TNT SHM Quote Room Block Line Items Business Components |
Usage |
This user property is used in C++ code to read the Core Flag field name for time shift functionality. |
Field Name: Shifted Start Date
This user property is used in C++ code to read the Shifted Start Date field name for time shift functionality.
Value |
Shifted Start Date |
TNT Quote Meeting Packages Business Component |
Usage |
This user property is used in C++ code to read the Shifted Start Date field name for time shift functionality. |
Field Name: TNT Meeting Package Picklist Search Spec
This user property is used in C++ Code to get the name of the field that stores the search specification for displaying Meeting Packages in the TNT Quote Meeting Package pick applet.
Value |
TNT Meeting Package Picklist Search Spec |
TNT SHM Quote Room Block business component |
Usage |
This user property is used in C++ Code to get the name of the field that stores the search specification for displaying Meeting Packages in the TNT Quote Meeting Package pick applet. |
Quote Revised Item BC
This user property is used in C++ code to read the revised nonfunction line item (TNT Revised Quote Item) business component name for time shift functionality.
Value |
TNT Revised Quote Item |
Quote Business Component |
Usage |
This user property is used in C++ code to read the revised nonfunction line item (TNT Revised Quote Item) business component name for time shift functionality. |
Time Shift: Meeting Pkg BC Name
Value |
Usage |
