7Using Siebel Enterprise Integration Manager with Siebel Territory Management
This chapter covers information about using Siebel Enterprise Integration Manager (EIM) to load Siebel Territory Management data into your Siebel database. It includes the following topics:
About Using Siebel Enterprise Integration Manager for Siebel Territory Management
The tasks described in the preceding chapters of this book describe how to set up territories, territory hierarchies, and rules directly in the Siebel user interface. This approach works well on the small scale: for example, when you are working in a test environment. However, in a production environment and even for large-scale tests, Siebel Enterprise Integration Manager is a preferred way to enter data.
Siebel Territory Management Records Suitable for Bulk Loading
The following information lists the types records that you are most likely to want to bulk load into Siebel Territory Management using Siebel Enterprise Integration Manager.
| Record Type | Location on the Siebel Territory Management Screen |
Territories |
Territories List view |
Territory nodes |
Hierarchies List, Territory Nodes view |
Rules |
Alignments List, Rules view, Accounts, Contacts, Assets, Postal Codes, and Geo Zones subviews |
Conditions |
Alignments List, Conditions view |
Loading Siebel Territory Management Data into the Siebel Database
Use Siebel Enterprise Integration Manager to load Siebel Territory Management data into the Siebel database. For general information about using Siebel Enterprise Integration Manager, see Siebel Enterprise Integration Manager Administration Guide.
Use the following Siebel Enterprise Integration Manager tables to load data from your external source into the Siebel Territory Management application (base) tables:
EIM_TERR_HIER
EIM_TERRITORY
EIM_TERRALGN
EIM_TERRALGN_D
EIM_ALGNPOSCON
EIM_ALGNPOSAST
EIM_ALGNPOSACC
