How Workload Distribution Applies Workload Scores to Candidates
Workload distribution applies a workload score to candidates based on their current workload. The workload score is calculated as follows:
Workload score = Score times (1 minus (current workload divided
by maximum workload))
Note: The candidate's current workload excludes
the workload of the current object being assigned.
Candidates with a lighter workload receive a higher score than
candidates with a heavier workload. The workload score is then added
to the candidate's score to generate a total score. Candidates that
have workloads in excess of the maximum workload are eliminated from
the assignment rule. This criterion prevents employees from being
overloaded. Multiple workload distributions can be used for each assignment
rule.
Note: As with criteria, workload distribution has a Required
field, which functions in the same manner as it does for regular criteria.
The following figure shows a workload distribution rule for Critical Service Requests that:
Adds 100 points to candidates with a workload of 0 items (100 times (1 minus (0 divided by 2)))
Adds 50 points to candidates with a workload of 1 item (100 times (1 minus (1 divided by 2)))
Adds 0 points to candidates with a workload of 2 items (100 times (1 minus (2 divided by 2)))
Eliminates candidates with a workload of more than two items if the workload distribution rule is marked as Required
