Displaying a System Field in an Applet
This topic describes how to display a system field in the list column of a list applet. You can display a system field in the control of a form applet. It is not necessary to define a system field as a child Field object of the underlying business component. For more information, see System Fields of a Business Component.
To display a system field in an applet
In Siebel Tools, click Applet in the Object Explorer.
In the Applets list, locate the applet you must modify.
In the Object Explorer, expand the Applet tree, expand the List tree, and then click List Column.
In the List Columns list, add a new record.
In the Field property of the list column, choose a system field.
In the Display Name property, enter a value that describes the data that the system field stores, such as Last Updated.
