System Fields of a Business Component
A system field is a business component field that represents the data that Siebel CRM gets from a system column. All business components in Siebel CRM include system fields. You are not required to do any special configuration to display or manipulate a system field. You do not need to define it as a business component field. For example, you can reference a system field in the Field property of a control, list column, or in another object.
You must not modify a system field. For example, by renaming it. Siebel CRM does not support modifying a system field.
For more information, see System Columns of a Siebel Table and Displaying a System Field in an Applet.
