Guidelines for Using a Business Component User Property With the Admin Mode Property
Do not use a business component user property with an applet that resides in a view if the Admin Mode Flag property of this view contains a check mark. If this Admin Mode Flag contains a check mark, then Siebel CRM does the following:
  • Turns off all insert and update restrictions for the business components that the view uses, including the restrictions that the business component user property defines.
  • Ignores the Sales Rep and Personal visibility modes of the business component.
  • Makes records that do not include a primary team member visible.
  • Does not override pop-up visibility.
You can include a check mark in the Admin Mode Flag property only if the view is part of a screen that contains only administration views. You can create a list view where the Admin Mode Flag property contains a check mark if this list view drills down to a detail view that Siebel CRM does not mark as an administration view. This configuration allows you to share a detail view with a list view that is not an administration view.
Caution: All views and drilldowns in a screen that is granted Admin Mode will behave according to the Admin Mode due to their subordinate relationship to the screen. If a view is a child of a screen that is in Admin Mode, and if the Admin Mode Flag property of the view does not contain a check mark, then Siebel CRM still displays the view in Admin Mode.
