Starting and Ending a Shift
Complete the following procedure to start and end a shift.
To start and end a shift
Tap Side Menu and then tap Shifts to display the following:
The Shift list in the main pane.
The Calendar showing the activity planning information in the side pane.
Tap a shift record in the main pane.
Tap Start when you start the shift to record your start time and date.
Tap Complete when you end the shift to record your end time.
