Identifying a Property for an Opportunity
When you have narrowed the list of properties to properties in a specific area, you can use the Property screen to decide on the appropriate property or properties to use for the opportunity.
This task is a step in Selecting Properties for an Event Opportunity.
To identify a property for an opportunity
Do one of the following:
Use the Property Locator to find a list of properties in a specific area, as described in Searching for Properties for an Opportunity.
Navigate to the Properties screen, then the Properties view, and query for properties.
For each property potential in the list, click the link in the Property Name field.
Using the view tabs, determine whether or not the property is appropriate for the opportunity in terms of facilities, sleeping room availability, neighborhood, and so on.
If you decide that the property is appropriate for the opportunity, you can add it to the opportunity.
