Searching for Properties for an Opportunity
The Property Locator can be used to find properties in a particular region or area. The Property Locator is available from the Property screen. When you search for a property in the Property Locator, you must enter address details in the search fields. You can also enter other details about the property, such as market segment, brand, or facilities information. However, the Property Locator is primarily a tool for locating properties in a particular area or region. When you have used the Property Locator to find a list of possible properties, you can choose the appropriate property using the Properties list.
This task is a step in Selecting Properties for an Event Opportunity.
To search for properties for an opportunity
Navigate to the Property screen, then the Property Locator view.
Enter details in the search fields, making sure that you enter information in either the City and State fields, or in the Zip Code field, and click Search.
The following table describes some of the fields.
Field Comments Name
The name of the property for which you are searching.
Property Type
Select the required properties type if it is known.
CRS Code
Select the Central Reservation System code of the property, if it is known.
Market Tier
Select the market segment in which the required properties are classified.
Brand
Select the brand of the required properties.
Service Level
The level of service offered by the properties.
Weekend-Weekday
Indicates whether or not weekend-weekday pricing is to be used at the required properties.
Pool
Indicates if there is a pool at the required properties.
Golf
Indicates if there are golfing facilities available at the required properties.
Beach Nearby
Indicates if there is a beach near the required properties.
City
Indicates the city in which the required properties are located.
State
Indicates the state in which the required properties are located.
Country
Indicates the country in which the required properties are located.
Province
Indicates the province in which the required properties are located.
Zip Code
Indicates the zip code for the required properties.
Distance In
Indicates whether the search range is measured in miles or kilometers.
Search Range
Indicates the maximum distance from the ZIP code or city the required properties can be located.
Business Center
Indicates if there is a business center at the required properties.
Restaurant
Indicates if there is a restaurant at the required properties.
Nearest Airport
Indicates the airport nearest to the required properties.
If there are properties matching the criteria specified, these properties are displayed in the Properties list. If there are no properties matching the criteria specified, an error message is displayed informing you to refine your search.
