Changing System Preferences and Enabling Lot Number Tracking
The following procedure shows you how to change system preferences and enable lot number tracking.
To change the system preferences and enable Lot# tracking
  1. Log in to the Pharma web client as an administrator.
  2. Navigate to the Administration - Application screen, then the System Preferences view.
  3. Query for the following System Preference Name records:
    • Lots For Disperse Only
    • Samples Lots Enabled
  4. Set the System Preference Value for each of these records to TRUE.
  5. Navigate to the Administration - Product screen, then the Products view, and check the Lot# Tracking flag for each product that requires inventory reconciliation of samples without lot numbers.
  6. Log out of the Pharma web client.
