Reconfiguring Fields and Replacing Business Components
The following procedure shows you how to reconfigure fields and replace business components in the Siebel runtime repository.
To reconfigure fields and replace business components
  1. Choose View, Object Explorer, and then the Flat tab.
  2. Select Fields, and in the Fields list, query in the Picklist Column for PickList Pharma Samples Stocked Lots.
  3. Lock each project by choosing Tools, and then the Lock Project.
  4. In the Picklist column, replace each occurrence of PickList Pharma Samples Stocked Lots with Picklist Pharma All Unexpired Lots.
  5. Choose View, Object Explorer, and then the Types tab.
  6. Select Applet, and in the Applet list, query for any applet with the value Pharma Stocked Lot Pick Applet.
  7. For each occurrence, set the Business Component to Pharma Sample Lot for Picklist.
  8. Deploy the changes to the Siebel runtime repository.
