Business Component Events for Siebel VB
The following table describes a summary of the business component events you can use with Siebel VB.
Event Description Format
BusComp_Associate Event
Called if the user adds a business component record to create an association.
BusComp_Associate
BusComp_ChangeRecord Event
Called if a business component record becomes the current record.
BusComp_CopyRecord Event
Called if the user copies a business component record, and if the user makes this record the active record.
BusComp_CopyRecord
BusComp_DeleteRecord Event
Called if the user deletes a business component record.
BusComp_InvokeMethod Event
Called if Siebel CRM calls the InvokeMethod method on a business component.
BusComp_InvokeMethod(methodName as String)
BusComp_NewRecord Event
Called if the user creates a business component record, and if the user makes this record the active record. You can use this event to set up default values for a field.
BusComp_NewRecord
BusComp_PreAssociate Event
Called if Siebel CRM detects that the user is about to add a business component record to create an association.
BusComp_PreCopyRecord Event
Called if Siebel CRM detects that the user is about to copy a business component record. You can use this event to perform precopy validation.
BusComp_PreDeleteRecord Event
Called if Siebel CRM detects that the user is about to delete a business component record. You can use this event to prevent the deletion or to perform any actions before Siebel CRM deletes the record.
BusComp_PreGetFieldValue Event
Called if a user accesses a business component field.
BusComp_PreGetFieldValue(FieldName as String, FieldValue as String)
Bus Comp_PreInvokeMethod Event
Called if Siebel CRM calls a specialized method on a business component. Siebel CRM calls it before it calls this specialized method.
BusComp_PreInvokeMethod(methodName as String)
BusComp_PreNewRecord Event
Called if Siebel CRM detects that the user is about to create a new business component record. You can use this event to perform preinsert validation.
BusComp_PreQuery Event
Siebel CRM calls the BusComp_PreQuery event before it runs a query. You can use this event to modify the search criteria or to restrict Siebel CRM from running certain queries.
BusComp_PreQuery
BusComp_PreSetFieldValue Event
Siebel CRM calls this event after the user modifies a field value or after a call to the SetFieldValue method occurs. This event allows you to use custom validation before Siebel CRM applies predefined validation.
BusComp_PreSetFieldValue(FieldName as String, FieldValue as String)
BusComp_PreWriteRecord Event
Called before Siebel CRM writes a record to the Siebel database.
BusComp_Query Event
Called after Siebel CRM completes a query but before it displays the query results.
BusComp_Query
BusComp_SetFieldValue Event
Called if Siebel CRM sends a value to a business component from the Siebel client or through a call to the SetFieldValue method.
BusComp_SetFieldValue(fieldName as String)
BusComp_WriteRecord Event
Called after Siebel CRM saves the record to the Siebel database.
BusComp_WriteRecord
