Business Component Methods for Siebel VB
The following table describes a summary of the business component methods you can use with Siebel VB. It does not include object interface methods that are not called directly from a business component. For information about methods that you can call with the InvokeMethod method on the business component, see Business Component Invoke Methods.
Method Description Format
ActivateField Method for a Business Component
Activates a field.
Dim oBusComp as BusComp
oBusComp.ActivateField fieldName as String
ActivateMultipleFields Method for a Business Component
Activates multiple fields.
oBusComp.ActivateMultipleFields
oPropSet as PropertySet
Associate Method for a Business Component
Creates a new many-to-many relationship for the parent object through an association business component.
oBusComp.Associate whereIndicator as Integer
BusObject Method for a Business Component
Returns the name of the business object that the business component references.
Dim oBusObject as BusObject
Set oBusObject = oBusComp.BusObject
ClearToQuery Method for a Business Component
Clears the current query but does not clear sort specifications on the business component.
oBusComp.ClearToQuery
DeactivateFields Method for a Business Component
Deactivates the fields that are currently active from the SQL query statement of a business component.
oBusComp.DeactivateFields
DeleteRecord Method for a Business Component
Removes the current record from a business component.
oBusComp.DeleteRecord
ExecuteQuery Method for a Business Component
Returns a set of business component records.
oBusComp.ExecuteQuery cursorMode as Integer
ExecuteQuery2 Method for a Business Component
Returns a set of business component records. Allows you to control the number of records Siebel CRM returns.
oBusComp.ExecuteQuery2 cursorMode as Integer, ignoreMaxCursorSize as Integer
FirstRecord Method for a Business Component
Moves the record pointer to the first record in a business component, making that record the current record.
Dim iIsRecord as Integer
iIsRecord = oBusComp.FirstRecord
FirstSelected Method for a Business Component
Makes the first record of the multiple selection in a business component active.
Dim iIsMultipleSection as Integer
iIsMultipleSelection = oBusComp.FirstSelected
GetAssocBusComp Method for a Business Component
Returns the name of the association business component.
Dim AssocBusComp as BusComp
Set AssocBusComp = oBusComp.GetAssocBusComp
GetFieldValue Method for a Business Component
Returns the value of a field from the current record of a business component.
Dim sValue as String
sValue = oBusComp.GetFieldValue(FieldName as String)
GetFormattedFieldValue Method for a Business Component
A field value that is in the same format that the Siebel client uses.
sValue = oBusComp.GetFormattedFieldValue(FieldName as String)
GetMultipleFieldValues Method for a Business Component
Returns values for the fields specified in a property set.
oBusComp.GetMultipleFieldValues oFields as PropertySet, oValues as PropertySet
GetMVGBusComp Method for a Business Component
Returns the multivalue group business component associated a business component field.
Dim MvgBusComp as BusComp
set MvgBusComp = oBusComp.GetMVGBusComp(FieldName as String)
GetNamedSearch Method for a Business Component
Returns the name of a search specification.
sValue = oBusComp.GetNamedSearch(SearchName as String)
GetPicklistBusComp Method for a Business Component
Returns the name of the pick business component that is associated with a field in the current business component.
Dim pickBusComp as BusComp
Set pickBusComp = oBusComp.GetPicklistBusComp(FieldName as String)
GetSearchExpr Method for a Business Component
Returns the current search expression that is defined for a business component.
Dim sExpr as String
sExpr = oBusComp.GetSearchExpr
GetSearchSpec Method for a Business Component
Returns the search specification for a field.
Dim sSpec as String
sSpec = oBusComp.GetSearchSpec(FieldName as String)
GetSortSpec Method for a Business Component
Returns the sort specification for a business component.
Dim sSortSpec as String
sSortSpec = GetSortSpec
GetUserProperty Method for a Business Component
Returns the value of a user property.
sValue = oBusComp.GetUserProperty(propertyName as String)
GetViewMode Method for a Business Component
Returns the current visibility mode for a business component.
Dim iMode as Integer
iMode = oBusComp.GetViewMode
InvokeMethod Method for a Business Component
Calls a method.
oBusComp.InvokeMethod(methodName as String, methArg1, methArg2, methArgN as String or StringArray)
LastRecord Method for a Business Component
Moves the record pointer to the last record in a business component.
Dim iReturn as Integer
iReturn = oBusComp.LastRecord
Name Method for a Business Component
Returns the name of a business component.
Dim sName as String
sName = oBusComp.Name
NewRecord Method for a Business Component
Adds a new record to a business component.
oBusComp.NewRecord whereIndicator as Integer
NextRecord Method for a Business Component
Moves the record pointer to the next record in a business component, making that record the current record.
iReturn = oBusComp.NextRecord
NextSelected Method for a Business Component
Makes the next record of the current multiple selection the active record.
iReturn = oBusComp.NextSelected
ParentBusComp Method for a Business Component
Returns the name of the parent business component.
Dim parentBusComp as BusComp
Set parentBusComp = oBusComp.ParentBusComp
Pick Method for a Business Component
Places the currently chosen record in a pick business component into the appropriate fields of the parent business component.
oBusComp.Pick
PreviousRecord Method for a Business Component
Moves the record pointer to the previous record in a business component.
iReturn = oBusComp.PreviousRecord
RefineQuery Method for a Business Component
Refines a query.
oBusComp.RefineQuery
SetFieldValue Method for a Business Component
Sets a new value for a field in the current record of a business component.
oBusComp.SetFieldValue FieldName as String, FieldValue as String
SetFormattedFieldValue Method for a Business Component
Sets the new value to a field for the current record of a business component.
oBusComp.SetFormattedFieldValue FieldName as String, FieldValue as String
SetMultipleFieldValues Method for a Business Component
Sets new values in the fields of the current record of a business component.
oBusComp.SetMultipleFieldValues oPropSet as PropertySet
SetNamedSearch Method for a Business Component
Sets the named search specification on a business component.
oBusComp.SetNamedSearch searchName as String, searchSpec as String
SetSearchExpr Method for a Business Component
Sets a search expression for a business component rather than for each field.
oBusComp.SetSearchExpr searchSpec as String
SetSearchSpec Method for a Business Component
Sets the search specification for a field.
Dim oBusComp as BusCompoBusComp.SetSearchSpec fieldName as String, searchSpec as String
SetSortSpec Method for a Business Component
Sets the sort specification for a business component.
oBusComp.SetSortSpec sortSpec as String
SetUserProperty Method for a Business Component
Sets the value of a user property in a business component.
oBusComp.SetUserProperty propertyName as String, newValue as String
SetViewMode Method for a Business Component
Sets the visibility type for a business component.
oBusComp.SetViewMode viewMode as Integer
UndoRecord Method for a Business Component
Reverses any unsaved modifications that Siebel CRM has made on a record.
oBusComp.UndoRecord
WriteRecord Method for a Business Component
Saves to the Siebel database any modifications made to the current record.
oBusComp.WriteRecord
