About Finish It!
“Finish It!” is a button that appears in configuration session selection pages. This button is active under the following conditions:
- The configuration session contains a relationship that has a minimum cardinality greater than zero.
- No default product has been defined for this relationship.
- The user has not selected the number of products from this relationship required by the minimum cardinality.
These relationships are called unsatisfied quantity relationships. In selection pages, an asterisk displays next to the relationship name and next to the item in the relationship, indicating that the user must make a selection.
When the user clicks Finish It!, the Siebel Product Configurator engine adds items to the solution from all unsatisfied quantity relationships so that minimum cardinalities are met or exceeded. the Siebel Product Configurator engine makes arbitrary selections from these relationships. You cannot specify which products will be selected by setting the sequence of the product in the relationship.
For example, you have defined a relationship called Keyboard. This relationship has a minimum cardinality of 1 and no default product. This causes the Finish It! button to become active in configuration sessions. When the user clicks Finish It!, the Siebel Product Configurator engine adds a keyboard to the solution.
If you do not want the Finish It! button to be active during configuration sessions, specify default products for all relationships with a minimum cardinality greater than zero.
