Setting Up Required Attributes
You can set up attributes to require users to select values for them.
If you do not enter values in the mandatory fields where attributes are required, then Siebel Product Configurator displays an error message.
If you click Finish It!, Siebel Product Configurator does not complete required attributes for the user, as it completes required cardinalities. Instead, it displays an error message saying that the configuration is incomplete.
To set up required attributes, follow these steps:
  • Set up the attribute values as usual. If it is an enumerated attribute, include in the list of possible values a value that would not be acceptable for this attribute. This value must match the type of the attribute, for example 999 in the type is numeric. Give this value a display name that will be displayed as an error message and that will be displayed in the control telling the user to select a value; for example, give it the display name Select a Color. For more information about setting up attribute values, see Creating Attribute Definitions.
  • Attach the attribute to a product class, and select the Required field. As the rejected and default value for the product class, enter 999, the value for the message. Because it is the default value, it is displayed in the drop-down control for the attribute. For more information about attaching an attribute to a product class, see Creating Product Classes in a Hierarchy.
    Note: As an alternative to designating an attribute as required in the product class definition, you can designate it as required in the product definition after the attribute has been attached to the product through the product class assignment. This gives the administrator the flexibility to have the same attributes on a product class required on some products and not required on other products.
  • Attach the product class to the product. The product inherits the rejected value from the product class. For more information about attaching a product to a product class, see Associating Attributes with a Product.
