Add Controls to the Repository
You can add a new control in the repository to show the localized field name for a new field.
To add a new control to the repository
  1. In Oracle's Web Tools, locate the applet Cfg Cx Runtime Instance Frame (JS HI).
  2. Add a new control.
    For example, you can add Name = lblTest, Caption = TestLabel.
  3. Use this control in the template.
