Add Fields to the Cfg ISS Prod Def Buscomp
This procedure adds the fields you want to display to the Object Broker and recompiles the application. This makes the fields available for display.
To add fields to the Cfg ISS Prod Def Buscomp
  1. In Oracle's Web Tools, open a workspace and then navigate to Object Explorer.
    For more information on using workspace dashboards, see Using Siebel Tools.
  2. Locate the Cfg ISS Prod Def Buscomp in Oracle's Web Tools.
  3. Add the desired fields from S_PROD_INT to the buscomp.
  4. For each field you add, define a user property called Cfg UI Field.
  5. Set the user property value to TRUE.
  6. Deliver the workspace.
