Binding an Attribute Value to a Line Item Integration Component Field
You can create an attribute and bind the value to a quote, an order, or an asset item field. When you start the configuration session, the value from the business component field is loaded into the product instance's attribute value. When you exit the configuration session, the attribute value is copied to the target business component field value. This attribute is accessible in the Siebel Product Configurator user interface, constraints, scripts, and properties. If there is any data inconsistency between the field data and the product instance, then a warning window displays at the start and end of the configuration session. Note that the business component field that is mapped to the attribute value must exist in the corresponding line item integration components for quotes, orders or asset. This streamlines the order capture process by enabling users to provide line item characteristics within Siebel Product Configurator thereby preventing users from writing constraints or scripts to enable back and forth data exchange between attribute values and line item fields.
For example, you may want to create an attribute value to represent the Billing Account. The Billing Account is tracked in the line item field. The product administrator sets the property LineItemICField = Billing Account for the Billing Account Attribute.When the configuration session is started, the Billing Account attribute is defaulted to the business component Billing Account field. The end user has the option to overwrite the defaulted value. When the user exits Siebel Product Configurator, the user's selection is copied back to the business component.
Note: When you bind an integration component field of type Currency, you must use the Maximum List column of the Attribute Definition applet. This prevents the user from exceeding the maximum value of the Currency field for the business component field located in the integration component field.
To bind an attribute value to a line item
  1. Navigate to the Administration - Product screen, then the Product Definitions view.
  2. In the Products list, select and lock the desired product.
  3. In the Versions list, click the Work Space version.
  4. Click the Properties view tab.
  5. In the explorer display of the product on one side of the screen, select the desired attribute.
  6. In the Properties list, add a new record and complete the necessary fields as described in the following table.
    Field Comments
    Name
    Enter LineItemICField.
    Value
    Enter a value for the property. The value is the LineItem field name.
    Note: If the LineItemICField is mapped to a Currency field, then this field has a limit of 10 digits.
