Creating a Configuration Session Specific Computed Attribute
You can define an attribute that is specific to the configuration session. The attribute value is computed during the start of the configuration session, but it is not synchronized to the line items or the database. The attribute is treated as a virtual attribute for a product and is accessible within the Siebel Product Configurator user interface, constraints, scripts and properties.
One example is when you want to capture an attribute value whose sole purpose is to trigger a product's constraints. For example, you create an attribute called Additional Fee with a domain value of Yes and No, where the default value is set to No. You then write a requires rule that selects products Late Fee and Finance Charge when Additional Fee = Yes. When the user launches Siebel Product Configurator, and sets the Additional Fee = Yes, the constraints are triggered and Additional Fee products are selected. Note that when you exit from Siebel Product Configurator, you will not be able to see the Additional Fee attribute displayed in the line item attribute applets. Thus reducing the number of attributes that are captured in the database primarily for computational purposes.
To create a configuration session specific computed attribute
Navigate to the Administration - Product screen, then the Product Definitions view.
In the Products list, select and lock the desired product.
In the Versions list, click the Work Space version.
Click the Properties view tab.
In the explorer display of the product on one side of the screen, select the name of the root product.
In the Properties list, add a new record and complete the necessary fields as described in the following table.
Field Comments Name
Enter NoSave.
Value
Enter a value for the property. The value is either Y or N.
In the explorer display of the product on one side of the screen, select the attribute.
Enter the same information for the attribute that you entered for the product in Step 6.
