Changing the Context and Rowset Variable Maps
You can change the context and rowset variable maps used by the attribute eligibility procedure. The variable map is set as a parameter in the LoadInstance signal and the SetInstance signal. The name of the parameter is Context Variable Map. By default, it has a value of Cfg Eligibility Variable Map - Context.
The rowset for attribute eligibility is generated without a variable map. It contains only one property: value.
