Setting Up Attribute Eligibility Checking
This topic describes the high-level steps for setting up attribute eligibility checking.
Writing a Custom PSP Procedure to Check Eligibility
You can use a given procedure to evaluate one attribute or many attributes:
  • Use conditional statements to use one procedure to evaluate multiple attributes that have different evaluation criteria.
  • Or create one procedure for each attribute.
Typically, the custom procedure includes the following steps:
  • In a step of the PSP procedure, log the Context property set.
  • In a step of the PSP procedure, log the RowSet property set.
  • In a step of the PSP procedure, set all rows to Eligible by default before evaluating the row set:
    • This step uses the Row Set Transformation Toolkit business service, Conditional Action Transform Method.
    • Input arguments are shown in the following table.
      Input Argument Type Value Property Name
      On Default 1
      Literal
      {Row.Eligibility Status} = LookupValue('PEC_ELIG_STATUS_CD','Y')
      Row Set
      Process Property
      Not applicable.
      Row Set
    • The output argument is shown in the following table.
Property Name Type Value Output Argument
Row Set
Output Argument
Not applicable.
Row Set
  • In one or more steps of the PSP procedure, check attributes for eligibility:
    • This step uses the Row Set Transformation Toolkit business service, Conditional Action Transform method.
    • Input arguments include conditional statements that check whether the value entered is eligible.
    • Output arguments set rows to ineligible if these conditions are true.
  • In Administration - Order Management, then the Message Types view, define the error message.
  • In Administration - Order Management, then the Payload view, create payload variable records.
  • In a step of the PSP procedure step, assign context and rowset values to the message payload variables.
Creating the Attribute and Assigning It to a Product Class
Create the attribute and assign it to a product class in the usual way, described in Process of Creating Products with Attributes.
In the Administration - Product, Product Classes, Version, and then the Attributes view:
  • In the Check Eligibility field, select the checkbox for any attribute whose eligibility you want to check.
  • In the Eligibility Procedure field, select the custom PSP procedure that you created to check the eligibility of this attribute.
