Defining Inclusive or Exclusive Eligibility for Products
A given product can use only inclusive or exclusive eligibility rules. Before you define the rule, you must define which type of eligibility the product uses.
To define inclusive or exclusive eligibility for a product
  1. Navigate to the Administration - Product screen, then the Products view.
  2. In the Products list, in the record for the product, select or deselect the Inclusive Eligibility checkbox, if necessary.
