Defining Product and Promotion Eligibility Rules
Before you can define product eligibility, you must define the product. Then add eligibility rules to it.
Before you can define promotion eligibility, you must define the product promotion, as described in the topic on product promotions in Siebel Pricing Administration Guide. Then add eligibility rules to it.
You can create two types of rules:
Available Rules. Specify the customers who are eligible to buy the product.
Not Available Rules. Specify the customers who are not eligible to buy the product.
