Displaying Only the Project in Use
If you have a long list of projects in the Workspace Projects list, it can be useful to display only the project you are currently working on and to hide the other projects.
To display only the project in use
  1. Navigate to the Administration - Product screen, then the Workspace Projects view.
  2. In the Workspace Projects list, in the record for the project you are currently using, select the Use Project checkbox.
    Select this checkbox in only one record.
  3. Click Show Project in Use.
    Only the project you are currently using is displayed in the list.
To display all workspace projects again after displaying only the project in use
  1. In Workspace Projects list, click Query.
  2. Without entering any query criteria, click Go.
    All projects are displayed.
