Correcting Product Definitions and Retesting
If the scenario is invalid, you must correct the definitions of products and prices and retest the scenario.
For example, if one of the component products is not available on the date that this scenario is testing, you must modify your product list so the product is available on that date.
This task is a step in Process of Testing Products with Scenario Tester.
