Validating Scenarios
After setting up the scenarios, you can validate them.
Note: In addition to the verification described here, you can batch validate scenarios, as described in Batch Validating Scenarios.
This task is a step in Process of Testing Products with Scenario Tester.
To validate scenarios
  1. Navigate to the Administration - Product screen, then the Workspace Projects view.
  2. In the Workspace Projects list, select the workspace for this scenario test and select the Use Project check box.
  3. Click the Scenarios view tab.
  4. In the link bar of the Scenarios view, click either Test Quotes, Test Service Orders, Test Sales Orders, or Test Agreements.
  5. In the Scenarios list, select one or more test quotes, test service orders, test sales orders, or test agreements.
  6. Double click the test scenario and perform the usual tasks for that type of document.
    For example, if you are testing a quote, you must add products to the quote, look at the products, look at the prices, and so on.
