Importing and Exporting Product Promotions
Product promotions can be imported and exported as follows:
- Navigate to the Administration - Product screen, then the Workspace Projects view. - In the Workspace Projects menu, select Export Contents. - The Export Full Structure option invokes method ExportFullVod of the ISS Authoring Import Export Service.
- Navigate to the Administration - Product screen, then the Product Promotions view. - In the Product Promotions menu, select XML Export option. - In this case, method ExportVOD of ISS Authoring Import Export Service is invoked. Note: The XML file generated contains the definition of the promotion. Only one promotion can be exported at a time.
For more information about methods of the ISS Import Export Authoring Service, see Siebel Order Management Guide.
