Migrating Products Using Application Deployment Manager (ADM)
You can also migrate products using Application Deployment Manager. You use the Joint WorkSpace content object to migrate key fields and versioned content for product itself, and you use the Product (ADM) content object to migrate the non-versioned content of product.
If you are migrating non-standard fields, you must customize the Product (ADM) content object.
For information about how to use ADM, see Siebel Application Deployment Manager Guide.
