Migrating Products Among Environments
Some businesses develop new versions of products in the same environment that they use for product that are already in production. Other businesses use separate environments for development and for production.
If you use separate environments for development and production, you can migrate product data from the development to the production environment in either one of two ways:
Migrating Products Using Import and Export in Workspace Projects View. This method allows you to move versioned data and related objects.
Migrating Products Using Application Deployment Manager (ADM). This method allows you to move both versioned and unversioned data.
Note: You cannot use EAI to import versioned data.
