Customizing the Application Container for Siebel Application Interface
You can perform various configuration steps to customize the application container (Apache Tomcat) for Siebel Application Interface in your Siebel CRM deployment.
These tasks apply only to the application container for a deployed instance of Siebel Application Interface. They do not apply for the application container for any module that uses URLs for internal purposes only, such as Siebel Gateway or Siebel Server.
Note: For each of the customizations described in this section, you must test your applications and verify that your customizations work as expected before you make these changes in your production systems.
This topic includes the following information:
Related Topics
Stopping and Starting the Siebel Application Container
Requirements for Installing and Configuring the Siebel Application Interface
