Stopping and Starting the Siebel Application Container
If it is deemed necessary, then you can stop (shut down) and restart the Siebel application container using the methods in this topic. The application container for Siebel Gateway, Siebel Server (for Configuration Agent), Siebel Application Interface, and any other application container hosting Siebel CRM functionality are automatically started after installation. If application containers are not running, then you can perform the manual tasks listed in the troubleshooting sequence shown in this topic.
Application containers (Apache Tomcat) provided in installations of Siebel Gateway, Siebel Server (Configuration Agent), and Siebel Application Interface run as a service on Microsoft Windows, while the corresponding system process is named tomcat8.exe. On UNIX operating systems, the system process for Apache Tomcat is named javaw.
Note the following behavior for Microsoft Windows and for UNIX operating systems:
Caution: If you think you might need to shut down and then restart an application container, then, before you attempt to restart it, you must first check that the application container has shut down completely, for example, by using the Service Control Manager or the Task Manager in Windows. Otherwise, a port conflict failure might impede proper startup of the application container. Sometimes, examining logs might be the only way to indicate the nature of the problem.
Note: Decisions about whether to install Siebel CRM modules together or separately using the Siebel CRM installer must take into account the fact that modules installed together share the application container. Install modules separately to eliminate such dependencies and maintain availability for your Siebel CRM modules. If the Siebel Gateway and Siebel Server are collocated, then they share the same application container and do not require separate operations to stop or start the application container.
This topic includes the following information:
Related Topics
Starting the Siebel Gateway
Configuring Siebel Application Containers for Automatic Start on UNIX
Starting the Siebel Server Service on Windows
Customizing the Application Container for Siebel Application Interface
Verifying Installation for Siebel CRM
Troubleshooting Installation and Configuration for Siebel CRM
Related Books
Siebel System Administration Guide
