Configuration Parameters Index
The following table contains an alphabetical listing of some of the configuration parameters from Siebel application configuration files such as siebel.cfg or uagent.cfg. This list shows the name of the section in which each parameter can be found and identifies where the parameter is documented (in tables in Description of Siebel Application Parameters and Parameters for Individual Data Source Sections). This list is not comprehensive.
Configuration Parameter Name
Section Name
Where Documented and Description
AccessDir
[Siebel]
AllowAnonUsers
[InfraUIFramework]
Siebel Security Guide
ApplicationName
[Siebel]
ApplicationPassword
Applicable security adapter sections, such as:
[LDAPSecAdpt]
ApplicationSplashText
[Siebel]
ApplicationTitle
[Siebel]
ApplicationUser
BaseDN
CancelQueryTimeOut
[InfraUIFramework]
Siebel Applications Administration Guide
CaptionPrefix
[Siebel]
CaseInsensitive
Applicable data source sections, including:
[LOCAL_SE]
[ServerDataSrc]
[GatewayDataSrc]
ClientRootDir
[Siebel]
CommConfigCache
[Communication]
Siebel CTI Administration Guide
CommConfigManager
[Communication]
CommConfigManagerName
[Communication]
CommEnable
[Communication]
CommLocalDriver
[Communication]
CommLogDebug
[Communication]
CommLogFile
[Communication]
CommMaxLogKB
[Communication]
CommMaxMsgQ
[Communication]
CommReleaseLogHandle
[Communication]
CommReqTimeout
[Communication]
ComponentName
[Siebel]
ConnectString
[LOCAL_SE]
[ServerDataSrc]
[GatewayDataSrc]
Parameters for Individual Data Source Sections (data sources)
ContactLogin
CredentialsAttributeType
DataSource
[Siebel]
DebugLevel
[EMail]
Siebel Email Administration Guide
DefaultMailClient
[EMail]
DisableExecuteRetry
[ServerDataSrc]
DisableReverseProxy
[InfraUIFramework]
DLL
[LOCAL_SE]
[ServerDataSrc]
[GatewayDataSrc]
Docked
[LOCAL_SE]
[ServerDataSrc]
DockConnString
[LOCAL_SE]
DockRecvTxnsPerCommit
DockRepositoryName
[Siebel]
DockTxnsPerCommit
[LOCAL_SE]
EditFieldCaption
[InfraUIFramework]
Configuring Siebel Business Applications
EditFieldType
[InfraUIFramework]
Enable
[DataCleansing]
[DeDuplication]
Siebel Data Quality Administration Guide
EnableFQDN
[Siebel]
Siebel Installation Guide
EnableInlineForList
[InfraUIFramework]
If the applet mode property is set to Edit List, then the functions Edit, New, and Query work in-line, that is, in the list applet, when EnableInlineForList is set to True. The default value is True. Set to False to turn off this behavior.
EnablePersonalization
[Siebel]
EnableScripting
[Siebel]
EnterpriseServer
[LOCAL_SE]
[ServerDataSrc]
eProdCfgNumbOfCachedCatalogs
[InfraObjMgr]
Siebel Performance Tuning Guide
eProdCfgNumbofCachedWorkers
[InfraObjMgr]
eProdCfgNumOfCachedAttrs
[InfraObjMgr]
eProdCfgNumOfCachedClasses
[InfraObjMgr]
eProdCfgSnapshotFlg
[InfraObjMgr]
FileSystem
[ServerDataSrc]
FQDN
[Siebel]
GatewayAddress
[ServerDataSrc]
GatewayDataSrc
[DataSources]
Parameters for Data Sources Section
Hidden
[GatewayDataSrc]
InsensitivityFactor
[LOCAL_SE]
[ServerDataSrc]
[GatewayDataSrc]
InsUpdAllCols
IntegratedSecurity
Local
[DataSources]
LocalDbODBCDataSource
[Siebel]
LoginView
[InfraUIFramework]
MaxCachedCursors
[LOCAL_SE]
[ServerDataSrc]
MaxCachedDataSets
[LOCAL_SE]
[ServerDataSrc]
MaxConnections
MaxCursorSize
[ServerDataSrc]
MaxDepthOfTheQuery
[InfraObjMgr]
MessageBarUpdateInterval
[Siebel]
MultiCurrency
[Siebel]
NonSQL
NumberOfListRows
[InfraUIFramework]
Siebel Object Types Reference
PasswordAttributeType
PersonalizationLog
[Siebel]
Port
PrefetchSize
[ServerDataSrc]
PrimaryEnterprise
[GatewayDataSrc]
RemoteSearchServer
[Siebel]
RemoteSearchServerPath
[Siebel]
ReportDataDir
[XMLPReports]
Siebel Reports Guide
ReportOutputDir
[XMLPReports]
ReportsDir
[Siebel]
ReportsODBCDataSource
[Siebel]
RepositoryFile
[Siebel]
RequestServerName
[InfraObjMgr]
This parameter is the name of the Siebel Server that services requests from the Siebel client.
RequiredIndicator
[InfraUIFramework]
Siebel Developer's Reference
ReverseFillThreshold
[LOCAL_SE]
[ServerDataSrc]
RolesAttributeType
Sample
[DataSources]
ScriptingDLL
[Siebel]
SearchDefName
[Siebel]
SearchEngine
[Siebel]
SearchInstallDir
[Siebel]
SecAdptDllName
SecAdptMode
[InfraSecMgr]
SecAdptName
[InfraSecMgr]
ServerDataSrc
[DataSources]
ServerName
SharedCredentialsDN
SharedModeUsersDir
[Siebel]
ShowMessageBar
[Siebel]
ShowWriteRecord
[InfraUIFramework]
Siebel Partner Relationship Management Administration Guide
SiebelExtMailClientAttDir
[EMail]
SiebelUsernameAttributeType
SingleSignOn
SqlStyle
[LOCAL_SE]
[ServerDataSrc]
SslDatabase
SystemSWFName
[InfraUIFramework]
SystemSWSName
[InfraUIFramework]
TableOwner
[LOCAL_SE]
[ServerDataSrc]
TempDir
[Siebel]
TreeNodeX (several parameters that are similarly named, for example, TreeNodeCollapseCaption)
[InfraUIFramework]
TrustToken
Type
[DataCleansing]
[DeDuplication]
UpperCaseLogin
UseDictionaryinTransactionLogging
UseAdapterUsername
UseRemoteConfig
UserSWFName
[InfraUIFramework]
UserSWSName
[InfraUIFramework]
Version
[Siebel]
WebTemplatesVersion
[InfraUIFramework]
XdoDir
[XMLPReports]
