Configuring Server Components to Use System Alerts
Use the following procedure for configuring server components to use system alerts by setting applicable server component parameters.
To configure components to use system alerts
Navigate to the Administration - Server Configuration screen, then the Enterprises view.
Select the Component Groups view tab.
In the Component Groups list, select the Siebel Server component group of interest.
In the Components list, select the server component of interest.
In the Component Parameters list, query for and set the parameters described in the following table.
Parameter Name |
Parameter Alias |
Description |
Notification Handler |
NotifyHandler |
The name of the system alert profile, which specifies the notification medium and settings for the component alerts. Set this value to the alias name of the system alert profile that you defined previously. |
Disable Notification |
DisableNotification |
A Boolean value that enables or disables server component notification. The default value is False. |
Time to Wait for doing Notification |
NotifyTimeOut |
Specifies the amount of time to wait in milliseconds for connecting to the named pipe, which is a system element used in notification communications. If the named pipe does not reply within the specified time, then the notification is terminated. The default value is 100 milliseconds. |
Notification Action on Task Exit |
NotifyOnTaskExit |
An integer value that determines if notifications are sent in case of error. A value of 0 disables error notifications. A value of 1 enables error notifications. The default value is 0. Set this parameter to 1 to configure system alerts. Note: This parameter is an advanced parameter, which might not be set for display in the GUI. |
