PreviousNextJavaScript must be enabled to correctly display this content
Configuring the Expiry Timer
You can configure the Expiry Timer Value which
determines the expiry of a subscriber entry, and the deletion of the expired
entries from the Whitelist, Blacklist, Ratelimit, and Redirect lists.
To
configure the Expiry Timer Value:
Navigate to the
required list for which the timer needs to be configured. For example, if you
want to configure the timer for the Blacklist, go to:
Settings >
Blacklist >
Configuration.
You can configure the expiry time for each list separately.
Subscribers of a list expire based on the Expiry Timer configuration of the
list.
In the
Expiry
Timer Value
section, add the value in terms of hours. The default
value is 48 hours. This means that a subscriber entry expires 48 hours after
its addition to the list. You can specify any value between 48 -1440 hours.
A warning or notification in the form of an email/SNMP trap is
sent out at 03:23 everyday. This notification contains a list expired
subscribers. If you have enabled
admin >
System
Settings >
Automatic
Expiry Delete
, then 24 hours after the expiry, all expired entries
are deleted from the list. If you have not enabled the Automatic Expiry Delete,
the administrator can delete the expired entries from the list. This action
cannot be performed by a non-admin user. For more information on enabling or
disabling the Automatic Expiry Delete setting, see
Configuring Automatic Expiry Delete.
