Configuring Mediation Engine
The configuration section under Setup lists the Mediation Engine connections. Fraud Monitor analyzes the data from the connected Mediation Engines.
The Fraud Monitor details needs to be configured for the Mediation Engine. See the Configuring Fraud Monitor chapter.
Once the connection is established between Mediation Engine and Fraud Monitor, the connection details are displayed in this configuration screen. You can also view the connection failures details on this page.
Name: Indicates the machine name.
IP: Indicates the IP address to which Fraud Monitor tries to connect for analyzing the data.
Status: Indicates whether the Mediation is connected or disconnected.
Date: Indicates the date and time when the Mediation Engine is connected or disconnected.
After adding or changing a connection, Fraud Monitor tests the connection. Any errors will display in a dialog box.
