PreviousNextJavaScript must be enabled to correctly display this content
Add Rule Filter
A rule filter is used to apply a rule to a subset of
network calls. You can define a rule filter as regular expressions to filter
calls based on phone numbers, Hostnames, Usernames, and User-agent headers.
To add
a rule filter
In the window for
configuring rules, click
Add. For
example, if you want to add rule filter for Source-based traffic spike rule,
click
Add
in the Rule section. The
Add Rule
Filter window is displayed.
Figure 4-3 Rule
Filters
Configure the rule
filter using the Type, Match Value, and Redirect Target fields.
Field
Description
Type
Lists the data type for the user.
Match Value
Use to specify the value for the Type
selected above. For example, if you select the Type as from-phone-number,
specify the phone number in the Match Value field.
Redirect Target
Add the IP address to which the call
has to be redirected. This field is optional.
