You can view the expired entries in the deleted_entries_mm-dd-yy file that is
created everyday with information on the expired entries. This file is
available under the
/tmp/expired_entries/
folder.
Select the entries
that you need to delete. You can a select a maximum of 20 entries at one time.
Click
Delete
Only the Administrator can delete the expired entries.
