Configuring Rules
Fraud Monitor uses configurable rules to find call patterns which are considered fraudulent and classify the severity of the incident with a points system. On the Rules section, you can decide which rules are used, configure them, and restrict their use.
Click the
navigation bar on the right-hand side of the page that lists the set of rules
you can use.
Figure 4-1 Navigation Bar on the Settings Page
Description of "Figure 4-1 Navigation Bar on the Settings Page" -
Click on a rule to
open up its configuration panel in the left panel.
Every configuration panel has Add, Edit and Delete, which you can use to configure a specific rule.
Use the check box
next to the rule name in the left panel to enable or disable the rule. The
check-box is enabled by default.
Figure 4-2 Example of Rules Configuration
Description of "Figure 4-2 Example of Rules Configuration" - Click Add to add the rule definition. The Add Rule window is displayed.
In the
Add Rule
window, define the rule using the threshold, point type, and Familiarity limits
fields.
Field Description Point Type Select Dynamic or Static. For more information, see Configuring Points Accumulation. Threshold Threshold is the limit. If the threshold is crossed, then users accumulate points. Enter it in terms of percentage for a dynamic metric, or an integer for a static metric. Familiarity limit Familiarity is the difference in time relative to the time when the network user was seen by Fraud Monitor for the first time. Use the > or < prefixes to specify an upper or lower limit. For example, if you enter > 2, it means that a rule is only applicable if the user's timestamp is at least less than 2 hours in the past.
if you enter "<2", it means that a rule is only applicable if the timestamp for a given user is not yet 2 hours in the past.
If you do not specify the familiarity limit, then the rule is always applicable.
This is optional.
Assign a
Rule Weight The
default is value
1.00. The rule
weight can be used to make some rules more important than others.
Based on the Alert settings configured, if any user crosses the notification threshold on any rule, an incident is raised and a notification is sent to the user.
