| Oracle® Communications EAGLE Application Processor Alarms and Maintenance Guide Release 16.3 E96331 |
![]() Previous |
![]() Next |
Alarm Type: TPD
Description: This alarm is generated if an upgrade is not accepted or rejected after the upgrade.
Severity: Minor
OID: 1.3.6.1.4.1.323.5.3.18.3.1.3.33
Alarm ID: TKSPLATMI33
Alarm Value: 5000000100000000
Recovery
To clear this alarm, the upgrade should be accepted/rejected via the platcfg menu.
